Author Topic: [IC] ePBT Cosmic  (Read 4758 times)
Offline Sehpu
[IC] ePBT Cosmic
« on: Wed, 19 May 2021, 14:38:43 »
Back to the drawing board it is! I will work on a better showcase for the set including more kits before posting again, I will play with the colors more to bring out the purple more for the base of the set as there is plenty of comparisons to Dracula.
« Last Edit: Wed, 19 May 2021, 15:02:58 by Sehpu »
Offline Nukz
  • ig: nukzak
Re: [IC] ePBT Cosmic
« Reply #1 on: Wed, 19 May 2021, 14:39:41 »
dracula
Offline lalostad98
« Reply #2 on: Wed, 19 May 2021, 14:43:10 »
1- its darcula
2- its five side dyesub pbt
3- wtf is this base kit compat
« Last Edit: Wed, 19 May 2021, 14:44:46 by lalostad98 »
Offline huey
« Reply #3 on: Wed, 19 May 2021, 14:45:44 »
Take a step back. Look at other ICs and understand why people do the things they(regarding kitting), then come back a try again.
Offline NovaRMK
« Reply #4 on: Wed, 19 May 2021, 14:47:37 »
Look guys, look! It's another under-developed and half-assed IC! I mean, this has the be the 10th one in a row
Offline Izeri
« Reply #5 on: Wed, 19 May 2021, 14:47:46 »
Nice stepped cap
Offline NovaRMK
« Reply #6 on: Wed, 19 May 2021, 14:49:44 »
Also
Offline dandruff
« Reply #7 on: Wed, 19 May 2021, 14:55:51 »
1- its darcula
I rarely bash a whole kitting and try to give benefit of the doubt... but I have to agree with you here... I've never seen a base kit compat like this one...
Edit: Also + sign on numpad go brrrrrrrrrrrrrrr
Offline klexoslethal
« Reply #8 on: Wed, 19 May 2021, 14:56:28 »
Also
but but but... the mods are a different black :-[ /s
Offline novelflyer
« Reply #9 on: Wed, 19 May 2021, 14:57:05 »
That base kit...
Offline LittleAad
  • Hello
« Reply #10 on: Wed, 19 May 2021, 14:58:44 »
how you gonna do reverse dye sub on ABS, please correct me if im wrong but the ABS would melt/deform like crazy, no?????? And yes, its pretty similar to dracula.
Offline Baka Bot
« Reply #11 on: Wed, 19 May 2021, 15:00:31 »
Is this what we have come to? is this what we do in the streets? please tell me this is a nightmare
Offline Sehpu
« Reply #12 on: Wed, 19 May 2021, 15:02:11 »
Thank you, I checked out a few posts on the IC section before posting and there were quite a few underdeveloped kits so I thought it might have been okay to post this but I can see where the feedback is coming from so I will put more work into finalizing the set before reposting.
« Last Edit: Wed, 19 May 2021, 15:04:25 by Sehpu »
Offline Izeri
« Reply #13 on: Wed, 19 May 2021, 15:03:34 »
1- its darcula
It's one of the public resources offered to starters, which is by no means supposed to be an actual kit
