Author Topic: Are the stems of gateron inks the same as those on the gateron milky blacks?  (Read 1414 times)
Offline hconda
As the title suggests, I am wondering whether the stems on gateron milky blacks are the same as those of the ink blacks. For context, I bought some v1 inks but I was not told that they were of the silent variant, but I'm not complaining since I got a pretty good deal off them. So I was thinking, maybe the inks had the same stem as the blacks. On another note, I was also thinking about adding different stems to replace the silent stems but I've seen some tests on UHMWPE and I'm honestly not digging it. If someone can confirm or deny that the stems are the same that would be great, and I'd also like to hear some other ink black frankenswitches suggestions that you may have
Offline MIGHTY CHICKEN
they are not
