Author Topic: Re-program my keyboard  (Read 3153 times)
Offline johnmus
« on: Fri, 21 May 2021, 22:24:30 »
hi everyone, i have got this keyboard. But i don't know how to access bootloader to program it. Could you help me?
« Last Edit: Fri, 21 May 2021, 22:33:10 by johnmus »
Re: Re-program my keyboard
« Reply #1 on: Fri, 21 May 2021, 22:43:20 »
Near the black square chip there are two pins in a circle marked 'reset' - short those two pins and it will enter bootloader mode so you can flash it.  Hopefully you know what it is as you'll need to find the right firmware.
Offline johnmus
« Reply #2 on: Fri, 21 May 2021, 22:54:43 »
thank you, when i short like this. And does it will reset after i connect keyboard to computer?
« Last Edit: Sat, 22 May 2021, 20:10:33 by johnmus »
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #3 on: Fri, 21 May 2021, 23:31:22 »
You need to short it for just a moment While the pcb is connected to the pc.  That will make it reboot and enter the boot loader.  You can’t leave it shorted or it will just hang.
