Author Topic: Warped Space saver  (Read 2550 times)
Offline WhiteRice
Warped Space saver
« on: Sun, 22 August 2010, 11:33:28 »
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150477512961#ht_4444wt_1371
I talked to seller into  a small discount. You guys think it's worth it? Any way to  un-warp it?
Offline ch_123
Warped Space saver
« Reply #1 on: Sun, 22 August 2010, 11:45:55 »
[size=8]DEAR GOD WHAT IS IT WITH THAT GUY AND HIS OVERSIZED WRITING? YOU MAY BE ABLE TO GET A NEW CASE FROM UNICOMP, EVEN THOUGH THEY DON'T MAKE THEM ANY MORE, THEY HAVE SOME SPARE PARTS FOR THEM. THEY SELL, FOR EXAMPLE, THE TOP HALF OF THE INDUSTRIAL SPACE SAVERS AND THE KEYCAPS SPECIFIC TO THE SPACE SAVING KEYBOARD. NOT A BAD PRICE IF IT OTHER WISE WORKS FINE.[/SIZE]
Or something.
Offline chimera15
Warped Space saver
« Reply #2 on: Sun, 22 August 2010, 12:35:25 »
That's hilarious. lol
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Warped Space saver
« Reply #3 on: Sun, 22 August 2010, 12:56:38 »
Quote from: ch_123;215665
[size=8]dear god what is it with that guy and his oversized writing? You may be able to get a new case from unicomp, even though they don't make them any more, they have some spare parts for them. They sell, for example, the top half of the industrial space savers and the keycaps specific to the space saving keyboard. Not a bad price if it other wise works fine.[/size]
or something.
buy my rare vintage crappy rubber dome keyboard for only $100 and give me a 5 star rating the keyboard is very good i like it a lot buyer pays $30 shipping my cats name is sophia remember very much to give me a 5 star rating thanks for looking!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sorry, but not every Ebay-er was born to be a salesman...
Offline didjamatic
Warped Space saver
« Reply #4 on: Sun, 22 August 2010, 13:04:23 »
If it got hot enough to warp the outside like that, no telling what it has done to the inside.
Considering I sold one that was in great shape except for some dust and missing one foot for $70ish a few months ago, I think this one should sell in the $20-30 range at best.  It has a good cable and probably a good key set.  If the chip inside isn't a Dorito you could swap it into a terminal mini.
Offline EverythingIBM
Warped Space saver
« Reply #5 on: Sun, 22 August 2010, 15:31:14 »
It would be okay for like $20.
Since the ebayer doesn't KNOW what happened to it, they probably found it at a thrift shop or dump for nothing, and are now selling it for an outrageous price.
I'd just pass it until the guy wizens up and lowers the price. I'd rather spend that much for an unwarped keyboard.
SINCE it's warped, that almost means the internal assembly is as well, so simply getting a new case from unicomp may not solve the problem.
Offline ch_123
Warped Space saver
« Reply #6 on: Sun, 22 August 2010, 16:46:41 »
The seller says that the thing works fine, except for the case damage. Think about it, in order to damage the steel backplate, or even the PCB, you've have to apply enough heat that would burn through the entirety of the plastic casing.
Offline Rajagra
Warped Space saver
« Reply #7 on: Sun, 22 August 2010, 17:01:00 »
They were designed that way, all is explained when you enhance the image...
Offline phototristan
    • https://www.youtube.com/phototristan
Warped Space saver
« Reply #8 on: Sun, 22 August 2010, 17:11:15 »
Did someone mistake it for a pizza and put it in the oven or something?
Offline instantkamera
Warped Space saver
« Reply #9 on: Sun, 22 August 2010, 18:07:42 »
Quote from: Rajagra;215721
bravo.
Realforce 86UB - Razer Blackwidow - Dell AT101W - IBM model MCST  LtracX - Kensington Orbit - Logitech Trackman wheel opticalAMD PhenomII x6 - 16GB RAM - SSD - RAIDDell U2211H - Spyder3 - Eye One Display 2
Offline Necroleachate
Warped Space saver
« Reply #10 on: Tue, 24 August 2010, 10:06:34 »
I asked Chuck a week ago about the industrial space saving top and he said they're gone. Anyways only the top wouldn't make up for this one.
[SIGPIC][/SIGPIC]
Offline ch_123
Warped Space saver
« Reply #11 on: Tue, 24 August 2010, 10:16:44 »
I wonder if they found the bottom halves...
Offline itlnstln
Warped Space saver
« Reply #12 on: Tue, 24 August 2010, 10:29:12 »
Somehow, I read this wrong and was thinking this had something to do with saving warped space.  I don't even like Science Fiction.  Too much Through the Wormhole on the Science Channel.
