Author Topic: Hello  (Read 1833 times)
Offline Ethere4lGo4t
Hello
« on: Tue, 25 May 2021, 12:51:03 »
Hi, my name is Elijah, and I recently stumbled upon the Planck EZ on the internet. I've been thinking about getting a mechanical keyboard for a long time, and this just seemed to be "the one", so i purchased it and am now waiting for it to arrive. The only problem with it though was that it had a limited selection of switches and none of them fit my needs, so I started doing some research on buying keyswitches, and i guess you could say that that was when I "fell down the rabbit hole". (in case you are wondering what keyswitch i setteled upon, it is the boba u4s, which i will also lube) I am now convinced that mechanical keybords are one of the best things in the universe, and i just CAN'T wait for my planck EZ to arrive!
Offline MIGHTY CHICKEN
Re: Hello
« Reply #1 on: Tue, 25 May 2021, 13:09:48 »
Welcome to the hobby! It sure is a deep rabbit hole
