Author Topic: [IC] New production run of Elmo AEK II USB aek2_usb PCBs boards for AEKII  (Read 19906 times)
Offline linuxleah
Yeah, Elmo did a fantastic job.
Offline linuxleah
Offline poisonedwater69
Are the still any kits left/plans for a 2nd run?
Offline linuxleah
I already have a second run of boards in-stock. :-)
In a few weeks, as soon as I'm reasonably sure that nobody's board was damaged in-transit, I will be putting up a group buy for kits based on the second run of boards. (They are green, as opposed to the first run, which are blue.)
I will also be offering up any of the blue boards I still have left.
All boards and kits will forever be sold at-cost. I believe the green boards worked out to ever so slightly cheaper than the blue boards, though I'll admit the colour is not as nifty. :)
Thats great news! I'll definitely be in for one! (maybe 2 because it'll be my first solder project) Are you going to make another thread or just continue this one?
Offline nevin
mine arrived unscathed. well packaged. thanks for the extra effort @linuxleah
haven't built mine yet. have a bunch of mods to the case/plate floating around in my head....
Offline linuxleah
I'm going to make a new thread and link to it from this thread.
Offline long_qt_pie
Re: [IC] New production run of Elmo AEK II USB aek2_usb PCBs boards for AEKII
« Reply #57 on: Mon, 06 September 2021, 00:31:29 »
Evening!  I just got around to build the board and so far its fantastic, very refreshing to have QMK.  Where can I find the VIA hex to flash? Also, do I need to press the reset button or is there a hot key wired to reset when flashing?  cheers!
Edit: I believe I found the right file, the kb_elmo_aek2_usb_via.hex. However when I hold down boot, hit reset, then release boot; i never seem to enter flashing mode (as what Im used to doing with QMK toolbox and being able to flash that hex.  Im probably just doing something wrong though
Edit2: So I think actually the bootloader may be corrupted; the flashed keymap works well but anytime I try to pull up the bootloader, either by esc then plugging in or pressing the boot and reset keys, it just goes blank and then back to the normal keymap.
« Last Edit: Mon, 06 September 2021, 01:20:48 by long_qt_pie »
Jetfire | Mech 27 v1 | Mira SE | Singa | Orion 2.5 | Eo87 | Lubrigante | MGA | IBM F XT | AEKII | Lightpad | Exent | Dolphin Rev 2 | F1-8x | Mr Suit
Offline linuxleah
« Reply #58 on: Tue, 07 September 2021, 10:31:59 »
Hmm. I DID have a bit of a problem flashing those chips, but it's been months at this point; Elmo himself probably knows more than I do. Can you ask him? (FYI: I informed elmo via reddit private message; hopefully he'll show up here. In the past he's been very responsive!)
« Last Edit: Tue, 07 September 2021, 10:33:57 by linuxleah »
Offline _rubik
« Reply #59 on: Tue, 07 September 2021, 18:16:56 »
Sad I missed this. Any plans on doing another production run in the future?
Offline linuxleah
« Reply #60 on: Wed, 08 September 2021, 07:13:13 »
Actually, some new boards are already ready and in-hand. I'll be listing them for sale, with or without component kits, within a week or so.
Offline linuxleah
« Reply #61 on: Tue, 21 September 2021, 00:46:38 »
Second run (green!) PCBs are now available; interest check at https://geekhack.org/index.php?topic=114675.0 !
Go git yew some boards!  ;D :D ;D
Offline linuxleah
« Reply #62 on: Tue, 21 September 2021, 00:50:01 »
New boards are ready for shipping!
