Author Topic: [GB] EPBT Cool Kids 2 + D60Lite Cool Kids edition  (Read 10903 times)
Offline biip
    • @biipmk
« on: Mon, 31 May 2021, 12:05:54 »
Did you miss the boat to be a cool kid? Now you have a second chance!
Already a cool kid? Let’s be even cooler!
Group buy info
From June 1st to 30th 2021.
Shipping ETA: Q1 2022.
Proxies:
Material:
  • 1.5mm thick dye-subbed PBT keycaps (Smileys are PBT double-shot) manufactured by EnjoyPBT.
Colors:
  • 030 60 50
  • 080 80 60
  • 150 70 40
  • 240 70 30
  • 080 93 05
Renders
boop65
boop65
Kei
Kei
Kits
Deskpads
Smileys line
Smileys pattern
Cool smileys
Line smileys but cool
Specs:
  • Layout: 60% WK and HHKB
  • PCB: DZ60RGB-WKL/DZ60RGB ANSI V2, RGB hot-swappable PCB ( QMK and VIA supportable, Type-C, support Windows, Mac, Linux )
  • Plate: Polycarbonate
  • Stabilizers: KBDfans transparent stabs
  • Gasket: 2 sets of gaskets, injection-molded silicone gaskets, foam gaskets
  • Mute mat: install between PCB and Plate
  • Bottom silicone pad:which is tightly fitted. Compared with kbd67lite, it is a newly added configuration.
  • Case: PC+ABS material, using an injection molding process, the surface is matte, opaque
  • USB-C Cable
  • Colors: Bottom Case (white); Top Case (White), USB Port (white) - color matched with ePBT Cool Kids
  • Typing angle: 6°
  • Structure:Gasket mount
Reminder: D60Lite and ePBT Cool Kids keycaps are sold separately.
Estimated Ship Date:2 months after the group buy
Cables
Custom Cool Kids cables will be available during the group buy through Keebstuff
Thanks for the support.
Signature:
Code: [Select]
[url=https://geekhack.org/index.php?topic=112754.0][img width=302 height=120]https://media.biipmk.com/epbt_coolkids/EPBT_CoolKids-signature.png[/img][/url]
« Last Edit: Fri, 04 June 2021, 04:44:54 by biip »
Offline biip
    • @biipmk
Re: [GB] EPBT Cool Kids 2
« Reply #1 on: Mon, 31 May 2021, 12:06:15 »
cool
Offline zekth
Re: [GB] EPBT Cool Kids 2 + D60Lite Cool Kids edition
« Reply #2 on: Tue, 01 June 2021, 09:20:13 »
Kids
Offline verity
« Reply #3 on: Tue, 01 June 2021, 13:47:20 »
Love my set of R1 Cool Kids, and ePBT definitely stepped its game up with their new spacebar molds. GLWGB!
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #4 on: Thu, 03 June 2021, 18:53:09 »
Offline scottdesigns
« Reply #5 on: Thu, 03 June 2021, 21:13:14 »
Cool
Offline dstaar
« Reply #6 on: Sun, 06 June 2021, 10:28:33 »
just noticed base kit is same price as R1, but much smaller size ......
Offline biip
    • @biipmk
« Reply #7 on: Sun, 06 June 2021, 10:33:22 »
The mold cost of Colorful Kit is shared equally in the base kit :thumb:
Offline dstaar
« Reply #8 on: Sun, 06 June 2021, 11:11:21 »
got it  :thumb:
Offline dvorcol
« Reply #9 on: Thu, 17 June 2021, 15:27:18 »
Offline dvorcol
« Reply #10 on: Fri, 25 June 2021, 18:21:09 »
Offline dvorcol
« Reply #11 on: Thu, 05 August 2021, 17:32:26 »
Offline biip
    • @biipmk
« Reply #12 on: Mon, 08 November 2021, 08:46:31 »
Quick update: Samples came in. Some keys are missing but no major issue so far.
I keep you posted.
