Author Topic: [GB] GMK Symbiote — Incubation successful... (COMPLETE)  (Read 340029 times)
Offline pikku-allu
  • IG: @kinnalek
« on: Wed, 09 June 2021, 04:04:17 »
270225-0
⯈  Connecting...
⯈  0% ❘❘❘❘❘❘❘❘❘❘❘❘❘❘❘❙❙❙❙❙❙❙❙❙❙❙❙❙❙❙❙❚❚❚❚❚❚❚❚❚❚❚❚❚❚❚❚❚ 100%
⯈  S:\>_ Uplink established...
⯈  S:\>_ Containment protocol S.Y.M.B. activated
⯈  S:\>_ Subsystems status: EMERGENCY POWER ONLINE. SYSTEMS CRITICAL.
DATA_LOG_S20210609:
All containment efforts have failed.
Symbiote spread out of control.
Introducing GMK Symbiote, an unknown life-form that possesses the ability
to combine with mechanical objects, metamorphosized into a new type of hybrid organism.
What started as a symbiotic relationship, turned into complete absorption of the host machine.
A retrofuturistic sci-fi themed mechanical keyboard keyset with pale & organic colors.
Features translucent Membrane keys and new Standard Galactic Alphas.
Airlock PURGE ⇠
WARNING! ᒲᒷ⅂ ̣ ᔑᒲㇷ∷!𝗂₸ㇷᓭฆᓭ ฆリ !𝗂∷ㇷ⊣∷ᒷᓭᓭ 🞻SYS ERR!
270227-1
⯈ S:\>_ Purge unsuccessful, total infestation imminent
Projected contamination ground zeroes:
├── US: Omnitype
├── EU: Oblotzky Industries
├── UK: Proto[Typist]
├── CA: Deskhero
├─┬ OCE: Daily Clack
│ └───── Daily Clack - Deskpads
├── SEA: Ilumkb
├── CN: ZFrontier CN
└── ASIA/INT: ZFrontier EN
Data recovery still processing... ◰◱◲◳
Estimated incubation period end: Q4_2023
⯈ DATA_LOG_UPDATE... https://omnitype.com/blogs/timelines/gmk-symbiote
Central Core
The central core of the machine, infected by the Symbiote. Retains type variant ISO-UK.
Combine with other forms to reach maximum potential of the evolution cycle.
270229-2
Standard Galactic
It tries to communicate with you using strange glyphs; The Standard Galactic Alphabet (SGA),
originally created for the Commander Keen video game series. Replaces keys from A-Z.
270231-3
Metamorphosis
Allows the Symbiote to adapt to even more types of different hosts.
A metamorphic transformation that grows various tentacle lengths in the process.
270233-4
Anomaly
A specialized form of the Symbiote able to combine with even the rarest of host machines.
270235-5
Mutation
A mutation that spreads to all available vertical host columns.
Includes mutation variants [M1-M10].
270237-6
Containment
Activate containment protocol S.Y.M.B. in an attempt to prevent the Symbiote from consuming everything.
270239-7
Sequence
The Symbiote sequence. Purpose unknown. Infects the entire F-row or any vertical column.
Trait [F13] does not offer protection against the sequence.
270241-8
Membrane *TRANSLUCENT*
The Symbiote develops external translucent membranes across the surface of the host.
(The keycaps are doubleshot just like everything else with the keyset, with the inner plastic shot
visible through the milky translucent plastic of the outer shell).
270448-9
Recovered render data
Finder Works Hyphen
CannonKeys Satisfaction 75
Polycarbonate Norbaforce
RAMA Keycap - Protomodifier
├── Produced by RAMA WORKSฎ
├── Cherry profile Escape key (row 1, 1.00 units wide)
├── Compatible with MX style switches
└── Made of Aluminium, anodized (Protomodifier Purple), enamel infilled (Strange Pink)
Deskpad specifications
├── Size: 900 x 400 x 4mm
├── Bottom: Rubber layer
├── Top: Cloth material
├── Edges: Stitched (Graphic Printed Over Stitching)
└── Variants: Sequence (Biosynthetic Pale Purple) & Tissue (Strange Pink)
270245-10270247-11
Colors
├── Protomodifier Purple
├── Strange Pink
├── Biosynthetic Pale Purple
├── Nucleus White (an off-white very light pink)
└── Translucent Membrane Pink
Signature:
Code: [Select]
[url=https://geekhack.org/index.php?topic=113264][img width=302 height=120]https://i.imgur.com/NQx4TPh.gif[/img][/url]
« Last Edit: Thu, 26 September 2024, 06:53:11 by pikku-allu »
Offline pikku-allu
  • IG: @kinnalek
ᓵㇷリᓭ⚍ᒲᒷ
« Reply #1 on: Wed, 09 June 2021, 04:13:55 »
Some of you might have seen early captured footage of the Symbiote and are wondering why it looks slightly different now. It underwent a metamorphosis since then.
Symbiote has taken over this repl░░░ᓵㇷリᓭ⚍ᒲᒷ ᓵㇷリᓭ⚍ᒲᒷ ᓵㇷリᓭ⚍ᒲᒷ
DATA_LOG_S20230922:
Incubation complete.
⯈ Connecting...
⯈ S:\>_ Status: GMK SYMB░░░IO░TE [COLORMATCHING COMPLETE - MOVING TO PRODUCTION]
█▎▌▛▞▙▗▝▟░░ Color samples:
⯈ GMK Symbiote — First look (NOT RENDERS)
Album: https://imgur.com/a/X2yA19n
(note: artificial lighting)
« Last Edit: Thu, 28 December 2023, 13:21:18 by pikku-allu »
Offline of_sam
Re: [GB] GMK Symbiote — Infestation imminent
« Reply #2 on: Wed, 09 June 2021, 07:24:12 »
Very cool
Obligatory you put B in the base kit but not enough shifts to support an Alice layout.
« Last Edit: Wed, 09 June 2021, 07:29:37 by of_sam »
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline lalostad98
« Reply #3 on: Wed, 09 June 2021, 07:27:12 »
well done
Offline Bachoo
« Reply #4 on: Wed, 09 June 2021, 07:28:57 »
Amazing renders as always  :thumb:
Offline ttom
  • Formerly tvaro
« Reply #5 on: Wed, 09 June 2021, 07:32:57 »
Absolutely naughty
Best renders in the game, so stoked to see it all come together :eek:
Hoarder Collector and designer
Classifieds
Offline Ella
  • Why is it called an oven
« Reply #6 on: Wed, 09 June 2021, 07:36:05 »
The presentation is out of this world! (haha get it?)
Offline sirieous
  • help
« Reply #7 on: Wed, 09 June 2021, 07:36:14 »
oh das neat
Offline Afresh
« Reply #8 on: Wed, 09 June 2021, 07:40:22 »
2 days, nice. I was expecting other colors, interesting.
Offline Ella
« Reply #9 on: Wed, 09 June 2021, 07:40:38 »
Oh, just noticed that the Membrane kit has transparent keycaps, that's very cool!
Offline Entity.
  • Entity#1234
« Reply #10 on: Wed, 09 June 2021, 07:41:23 »
Love it :)
Offline Lil
    • designedbydark
« Reply #11 on: Wed, 09 June 2021, 07:44:05 »
Sick
Offline Izeri
« Reply #12 on: Wed, 09 June 2021, 07:46:58 »
That's hot, could you explain more how those novelties are done? Also insane renders as always  :eek:
Offline Daesya
  • 💜 purple supremacy 💜
    • social mediass
« Reply #13 on: Wed, 09 June 2021, 07:49:35 »
Absolutely insane... this is just chief kiss :-*
Offline densus designs
  • * St. Jude Supporter
« Reply #14 on: Wed, 09 June 2021, 07:49:44 »
love it
Offline huey
« Reply #15 on: Wed, 09 June 2021, 07:57:13 »
bless you for putting UK-ISO in base. GLWS.
Offline Carcha
« Reply #16 on: Wed, 09 June 2021, 07:59:48 »
Absolutely stunning. Definitely going to grab some kits. <3
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #17 on: Wed, 09 June 2021, 08:01:04 »
Looks awesome! Can't wait 'til 2024 for the color-matching completion!
Offline grezeh
« Reply #18 on: Wed, 09 June 2021, 08:03:10 »
Hyped for Galactic alphas!
Offline brunosan_.
« Reply #19 on: Wed, 09 June 2021, 08:14:07 »
Looks very good :thumb:
Offline mr_foggy
  • neue = nope
« Reply #20 on: Wed, 09 June 2021, 08:30:51 »
the colorway is not for me but this is one of the best thought-out sets and best presented ICs I've seen in a while. GLWGB
Offline dallman5
« Reply #21 on: Wed, 09 June 2021, 09:13:36 »
Looks really interesting, but I'm having a hard time gauging the colors. Any chance for a color comparison to other sets like you did in the past for GMK Dracula?
LF: OG Cherry APL (lasered), Artisans
Current collection:
Norbatouch (Galaxy Blue) | Mira SE (Lunar Grey, WKL) | HHKB Pro 1 (KB300BN) | Noxary X60 (Grey, HHKB) | KBDFans 5 Degree (Silver) | AEK64 (Grey) | Norbaforce (Tactical Black, WKL)) | Realforce 86U (White) | TGR 910 RE (Polycarbonate) | LZ-SQ (Black) | LZ-CLS (Grey, WKL) | Duck Orion v1 (Silver, WK)) | Nissho KB106DE | HHKB Pro 1 (KB300B) | LZ CLS-S (Blue, Poker) | Realforce 87U 10th Anniversary) | Realforce 104UK | TGR Alice (Grey on Pink) | Singa (Blue, WKL)  | Quantrik QXP (Blue Grey, WKL) | LZ-GH v2 (Black, WK) | KMAC Happy (Red, Poker)) | IBM Model M SSK (APL) | TGR 910 SE (Pink on Blue) | GSKT-00 (Silver, Poker) | OTD Koala (Silver, WKL) | Realforce R2 PFU Edition (Ivory) | IBM 3279 Beamspring (APL) | TGR Tris (Blue) | LZ-GH v2 (Blue, WKL)) | TGR Jane v2 (Blue-grey, WKL) | LZ-MP (Shine Grey, WKL)  | TGR x Singa Unikorn (Purple) | Justsystems x Realforce 108UG) | IBM Model F Unsaver (APL) | TGR Jane V2 CE (Multicolor, WKL) | Realforce 87U (Blank Black) | Lin Montage (Light Blue, WKL) | GSKT-00 AEK R2 (Grey, HHKB) | Leopold FC660C (Blank Black) | Duck Viper v3 (Grey on Black) | Rama Works M6-C RWxRW | LZ-GH v1 (Black, WKL) | Gok 7v (Grey) | biso x beaming Kei (SS, HHKB) | zacheadams x bisoromi little z | Matrix Noah (Silver/Grey, WKL) | Lin Whale (Pink, WKL) | TGR Alice (Polycarbonate) | Rama Kara (Noct) | Lin Whale75 (Burgundy, F13) | Realforce 89 (Ivory) | Hand Engineering Haus (Bluegrey) | Haytco CAKE60_R1 (Pantone 4167C) | LZ-XE (Grey, WKL) | Noxary X60 V2 (Grey, WK) | Daji Ochocuatro (Grey, WKL) | HHKB Hybird Type-S 25th Anniversary (Snow) | LZ-REs (Grey, WKL) | Matrix 8xv 3.0 (Blue-Black/Deep Grey, WKL) | Realforce 23UB | Biso RS60 (Black, WK) | TGR x MXF Koala (Grey/Black, WKL)
Italics = Incoming, Black = Gone
Offline dededecline
    • Linktree
« Reply #22 on: Wed, 09 June 2021, 09:25:12 »
The concept here is really cool and I'm super into the idea of the standard galactic alphas but the mods being English text + icon kinda ruins that for me. I'd prefer fully icon mods as a way to lean into the theme and allow the galactic standard alphas to shine without requiring new molds.
Offline Fredington
    • Instagram
« Reply #23 on: Wed, 09 June 2021, 09:43:42 »
ne prices avail?
Offline autocast
« Reply #24 on: Wed, 09 June 2021, 09:56:44 »
Spawn more overlords
Thank you for including many and varied R4 1.5U modifiers — helps MacOS/HHKB
Offline atlanticise
« Reply #25 on: Wed, 09 June 2021, 10:16:23 »
I wish membrane were a whole ass base kit
Offline Lufenia
« Reply #26 on: Wed, 09 June 2021, 10:22:30 »
Is the translucent keys double shot?!
Offline aethernet
« Reply #27 on: Wed, 09 June 2021, 10:25:58 »
woww. membrane kit is epic
Offline nebluh
« Reply #28 on: Wed, 09 June 2021, 10:29:02 »
damn thats cool
Offline andreiborisov
« Reply #29 on: Wed, 09 June 2021, 10:39:39 »
pikku-allu does not disappoint, this is epic
Offline TyPo.mk
« Reply #30 on: Wed, 09 June 2021, 10:59:56 »
270255-0
Are the membrane key caps going to look like this?
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
« Reply #31 on: Wed, 09 June 2021, 11:09:25 »
Why is everything you make unbelievable, I'll be getting most kits.
Offline Que7797
« Reply #32 on: Wed, 09 June 2021, 11:30:03 »
Wow, Pikku's renders never cease to amaze me.
Nice to see icon+text as well!
Offline cutegunz
« Reply #33 on: Wed, 09 June 2021, 11:47:16 »
Phenomenal, I especially love the membranes kit.
« Last Edit: Wed, 09 June 2021, 11:50:34 by cutegunz »
Offline Achromous
  • noesc.co.uk
    • NOESC
« Reply #34 on: Wed, 09 June 2021, 12:06:49 »
With the translucent caps do you have any prototypes of them? I'm not sure in reality if the legends will come out that crisp with the level of contrast between the 1st and 2nd shot, is the translucent shot polycarbonate or an ABS blend?
I've been testing similar things (below is a transparent PC with GiD) not using a pigmented polycarbonate but at least from what I've seen/tested legends have not come out as crisp as that render without a much higher contrast.
(Just to clarify above image is about worst case scenario for being able to have legible legends since it's a transparent PC. From a normal viewing distance the ESC is not visible)
Offline Hi !!
  • Kiimari
« Reply #35 on: Wed, 09 June 2021, 12:31:44 »
Sick Renders! Also would like to know more about membrane keys
Offline pikku-allu
  • IG: @kinnalek
« Reply #36 on: Wed, 09 June 2021, 12:39:52 »
Thank you everyone for the kind words, makes this all worth it. Criticism and questions are appreciated just as well.
Yes, everything is doubleshot. I did use the GMK Laser translucent keys as reference when creating the renders. Can't say for certain exactly how the Membrane keys will look like, the inner structure may differ slightly for example. There is a disclaimer in the kit image.
There should be enough contrast between the legends and the rest of the keycap like in the renders though. The inner structure, and therefore the legend, is the same color as the alpha legends. The outer layer is colored translucent plastic (not transparent) which will make the inner structure appear darker aside from the legends it doesn't cover. As far as I know the plastic GMK uses is all ABS.
I was considering icon mods at one point, but ended up going with text+icon. The text novelties (Containment) are also designed around text+icon mods.
Yes, I will be adding a comparison. The colors are warmer than most purple sets.
« Last Edit: Wed, 09 June 2021, 12:45:25 by pikku-allu »
Offline rt_es
« Reply #37 on: Wed, 09 June 2021, 12:55:42 »
Will there be any collabs or artisans?
Offline Achromous
  • noesc.co.uk
    • NOESC
« Reply #38 on: Wed, 09 June 2021, 13:00:41 »
Thanks for the transparency, pardon the pun. I hope they come out how you envisage.
Offline kema
  • Designer
    • kevinmadesign
« Reply #39 on: Wed, 09 June 2021, 13:04:08 »
These renders are so damn good, love the translucent keys ✨
Offline itsazly
    • website place
« Reply #40 on: Wed, 09 June 2021, 14:32:26 »
Well, I'll be picking this up around my bday, so happy birthday to myself. ᓵ𝙹リᓭ⚍ᒲᒷ
Offline micho
« Reply #41 on: Wed, 09 June 2021, 14:39:40 »
I love the look of the Standard Galactic and Membrane kits. Personally, I think the Membrane kit would look good with or without the legends.
Offline trukeeb
« Reply #42 on: Wed, 09 June 2021, 14:47:18 »
This is sick
Offline senbae
« Reply #43 on: Wed, 09 June 2021, 15:49:38 »
Interested to see this compared to bingsu colors
Offline vheissu
  • Pragmatic Geometrist
Re: ᓵㇷリᓭ⚍ᒲᒷ
« Reply #44 on: Wed, 09 June 2021, 15:58:31 »
ᓵᔑリ'⅂  ∴ᔑฆ⅂  ⎓ㇷ∷  ᒲᒷ⅂ᔑᒲㇷ∷!𝗂₸ㇷᓭฆᓭ
Offline IOVERCALLHISTIOCYTES
« Reply #45 on: Wed, 09 June 2021, 16:15:33 »
I sorta wish this had gone to IC even for a few days, so the initial post could be screengrabbed for posterity as what the top tier of set hype / renders looks like
Offline pixelpusher
« Reply #46 on: Wed, 09 June 2021, 16:18:51 »
WTB keycaps that are either blank or have legends you can see.  Thanks.   :thumb:
Offline antx1701
« Reply #47 on: Wed, 09 June 2021, 16:33:40 »
I want to say I'm in, because I love the idea, love the execution, but I feel like it's not dark enough for me. Those alphas got my eyes hurting.
Offline pixelpusher
« Reply #48 on: Wed, 09 June 2021, 16:35:31 »
Oooh, a mono kit with alpas the same as the mods.  That actually be badass.
Offline Alejo1707
  • Gimme some more caps!
« Reply #49 on: Wed, 09 June 2021, 16:35:43 »
COUNT
ME
IN!
