Author Topic: [IC] Chemical plant Deskmat | 2.0  (Read 4635 times)
Offline MOO·OON
« on: Sun, 13 June 2021, 12:18:12 »
Chemical plant
The design idea comes from the sewage discharged from the factory, which pollutes the ecological environment.
Although the colors of various pollutants are different, the harm to the environment is the same.
Specifications:
900mm x 400mm
microfiber top
stitched edges
rubber base
270509-0
270511-1
270514-2
270516-3
270518-4
270520-5
270522-6
Sample details
270578-7
270580-8
270582-9
« Last Edit: Wed, 16 June 2021, 22:11:29 by MOO·OON »
Offline iinko_mk
  • Status: broke
Re: [IC] Chemical plant Deskmat
« Reply #1 on: Sun, 13 June 2021, 12:22:29 »
ne images avail?
Offline Fraaaan
« Reply #2 on: Sun, 13 June 2021, 12:37:51 »
I feel like I'd like them more if there was some shading. You're missing critical info, though. We don't know the size and thickness of it. Do you have any pricing estimates?
Offline Keeblet_257
« Reply #3 on: Sun, 13 June 2021, 16:32:39 »
design itself looking good liking the black one but need more info. such as dimensions pricing and if there will be regional vendors
Offline MOO·OON
« Reply #4 on: Tue, 15 June 2021, 02:36:09 »
We wanted a simple and clean feel, so we didn't add shadows to the pattern. Pricing has not yet been determined, we are looking for overseas agents.
I have updated the specifications, there are some sample photos, and I am looking for an overseas agent.
Offline Keeblet_257
Re: [IC] Chemical plant Deskmat | 2.0
« Reply #5 on: Tue, 15 June 2021, 07:06:09 »
standard 400x900 okey. I probably would order the last one, the icy blue version, as well. As for Vendors UK has ProtoTypist and EU has mykeyboard candykeys or Keygem. I can't speak for other regions since I never payed attention. A pricing of about 20-30 seems reasonable if you wanted a price suggestion. any higher and I would probably have to order only one though other than that please update this thread with more renders that contains some popular boards and use a bigger size for letters and make the text more catching if you know what I mean. otherwise looking forward to see some updates :thumb: :thumb:
Offline wikkiwikki420
  • Location: Doo doo doo doo do doooo doooo do doo do doooo
« Reply #6 on: Wed, 16 June 2021, 04:30:44 »
If it turns out to be about 3mm thick... and around 900 x 340, that would be an easy buy for me... I am looking for mats to fit a cybermat and allow wireless charging. That said, I love the designs on the mat!!!
GMK Terror and GMK Slasher damn it.
Offline LupoLoopy
« Reply #7 on: Wed, 16 June 2021, 16:55:23 »
A suggestion to possibly make your life easier :)
Make a  60x900 shim out of 2-3mm cork sheet. Then you can use the standard 900x400 mats.
Offline MOO·OON
« Reply #8 on: Wed, 16 June 2021, 22:18:14 »
Thank you so much for your suggestions, the overall effect is much better after adjustment, thanks~  ;)
Thank you~, I’m glad you like them. :D
