Author Topic: [GB] Momoka Sugar Orange PBT Keycaps  (Read 4472 times)
Offline flashquark
    • Flashquark.com | Mech Key Depot
« on: Sun, 13 June 2021, 14:11:07 »
Announcing the start of the group buy for Momoka Sugar Orange Keycaps!
Momoka is a brand new keycap manufacturer that created brand new OEM molds, resulting in super crisp, defined keycap edges and a stem that has a perfect fit onto switches.
Join Group Buy Here
Chat with Us on Discord
Photos
Info
This set comes with 134 keycaps that make the set compatible with a variety of different sized boards such as 60%, 64, 68, 84, 87, and obviously full-sized boards.
Check out the all keycaps sizes in the pic above.
The keycaps are made with PBT plastic material, but are unique in that they do not have that rough, scratchy surface that is usually associated with PBT keycaps.
Legends and color are applied through a dye-sublimation process.
Pricing
$56.99/set
Shipping
We are offering this group buy to all locations internationally. Shipping is $5 everywhere.
(Choose the cheaper of the two shipping options shown in your cart while checking out if you see more than one)
Group buy runs until July 15, 2021.
Estimated shipping is 3 months after GB close. (Oct, 2021)
« Last Edit: Fri, 18 June 2021, 14:59:27 by flashquark »
https://flashquark.com | Keyboards, Keycaps, Switches, and other MK accessories.
Re: [GB] Momoka Sugar Orange PBT Keycaps
« Reply #1 on: Fri, 18 June 2021, 09:31:26 »
Approved :thumb:
Offline surplusofchairs
« Reply #2 on: Fri, 18 June 2021, 09:40:13 »
gb link is broken but i assume its on flashquark?
Offline flashquark
« Reply #3 on: Fri, 18 June 2021, 15:00:15 »
Yes, its on Flashquark.
Sorry, It looks like I did indeed format the link wrong, but its working now!
