Author Topic: [IC]Blinding Light Switch  (Read 7401 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Tue, 15 June 2021, 04:28:48 »
Yes, you are right!
The idea is inspired by the famous song.
The orange transparent body, the red stem and the 3-step springs. All parts of the switch are inspired by the weekend's blinding lights music video.
The switch will be factory-lubed. As for the type of feeling, you can take the Sakura Snow switch as a reference.
Well, the final technical data will be released when it is announced by the end of June. We think the final switch will be tactile and between 62g to 65g. After all, it takes its hat off to the song Blinding Lights.
The tempo, the fuzzy synths and the hopscotching drum-machine line are reflected on the switch. More importantly, the new wave style is the switch intends to bring to the community.
Follow Blingding Lights switch topic on KPrepublic discord and get pre-discount when releasing.
« Last Edit: Wed, 16 June 2021, 02:55:20 by KPrepublic »
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: [IC]Blinding Light Switch
« Reply #1 on: Thu, 17 June 2021, 03:08:40 »
Force graph for blinding lights switch
Estimated released at the end of June.
« Last Edit: Thu, 17 June 2021, 03:10:14 by KPrepublic »
