Author Topic: [GB] Magnet 65% Gasket Mount / Bluetooth / Hot Swap (Deliver Finished)  (Read 9826 times)
Offline SFT StarDust
Hi, friends, after a long run of IC, making samples, testing, redesign , making samples, testing.....
and here we are , it's finalized , with elegant typing feel and nice sound, the Magnet keyboard.
A list of the finalized Specs:
MAGNET 65% keyboard
-Typing Angle: 5.7 degree
- Layout: 65% , WK
- Structure: Gasket mount, Individual battery cabin
- Plate: 2mm , optional PC/Aluminum plate(choose one in the case)
- Func: with  Bluetooth3.0+5.0, plus 2.4G wireless ,individual Type-C connector,  RGB lights, Hot swap switches,
- Anodic Aluminum and copper accessories, acrylic Bluetooth window (the glowing circle on the left side)
- Dimensions: L x W x H = 354 mm x 114mm x 30mm, about 1.3kg(with switches and keycaps)
- Colors: Black ,White, light Blue ,Dark Blue, Grey, Green, Pink
Futures :
 <Volcano like Individual indicator lights which shows all kinds of status including charging , Bluetooth connection status and so on >
<Acrylic Bluetooth window on the side with LED lights, like a thruster, which is elegant and at the same time ensure the wireless signal good >
<Changeable badges on the bottom side, and it got four different themes including Geology, Astronomy, Mechanics, Biology>
<Gasket mount with very limited space and poron foam under PCB, so it will keep the pleasant uniform typing feel and solid sound with no inner cavity echo>
What is the Price and what is included?
1 . Standard Version (Full Aluminum accessories )  399 USD
2. Golden Version  (Full Brass accessories) 499 USD
(The case itself is still Aluminum, just difference on accessories)
Metal Accessories including :
Volcano /Reactor(you can choose one of two), Badge at the side(do not go gentle...), Badges at the bottom(you can choose one of four), Bluetooth window, type-C interface.
Everything else is the same except the Metal Accessories, including:
- Hot Swap PCB, Bluetooth PCB, Type-C PCB and FPC connectors
- Plate( Aluminum / PC, you can choose one of two)
- 4500mAh battery
- Gasket Foam, Foam between PCB and Plate, Foam in the Cabin bottom
- light-transmitting  Acrylic , light leaking preventive foam
- Screwdriver, Tweeze, screws(M3 and M2)
- Foot pad
How to order?
www.spacefantasy.club
we'll release GB at our official website during 1st/July - 15th July.
Join Our Discord:  https://discord.gg/P82VjFssQW  to follow up the update.
The website is still need to update, I 'll complete it before GB start.
Need Extra keyboard parts?
- PCB(including Bluetooth and type-C) 69.9 USD
- Plate PC/Aluminum 30USD
- Volcano/Reactor  Aluminum version 30USD, Brass Version 45USD
- Badges at the bottom (Geology, Astronomy, Mechanics, Biology),  Aluminum version 30USD, Brass Version 45USD,All four pack : Alum  70 USD  Brass:  110USD ( include the one in the Case)
Timeline and Status
- GB Release 1st/July - 15th July
- Orders be made to Factory - 15th July
- Production complete - estimated end of Nov.
- Delivery  - estimated Dec.
I'll update the status here if anything changed.
UPDATE: All package delivered .  and some extra stock for sale .
Video:
Typing sound test by Taeha:
More Detail Pictures
*All the pictures in this post is Real Samples ,No Renders.*
« Last Edit: Wed, 05 January 2022, 20:34:41 by SFT StarDust »
Re: [GB] Magnet 65% Gasket Mount / Bluetooth / Hot Swap
« Reply #1 on: Fri, 02 July 2021, 04:20:59 »
Approval bump :)
Offline lukelex
« Reply #2 on: Fri, 02 July 2021, 04:29:16 »
Which firmware is supported?
Offline Albert21
« Reply #3 on: Fri, 02 July 2021, 10:08:27 »
"we'll release GB at our official website during 25th/June - 9th July." --> should be 25th/July to 9th/Aug ??
« Reply #4 on: Fri, 02 July 2021, 11:21:27 »
I think this one has been running since June 25th and will close on July 9th. (this GB post took a while to get approval.)
Offline Leo66
« Reply #5 on: Sun, 04 July 2021, 02:37:20 »
Have solder mod?
« Reply #6 on: Mon, 05 July 2021, 06:59:36 »
Not to tell someone how to run their GB, but answering questions in this post might be a good start...
I also have a question about weather the 'upgraded' accents are copper or brass, as the website shows the extra weights and accents listed as 'brass', but this post lists extras as 'copper'.
« Reply #7 on: Tue, 06 July 2021, 22:26:42 »
« Reply #8 on: Tue, 06 July 2021, 22:27:18 »
We've got a driver of our own to change keys.
« Reply #9 on: Tue, 06 July 2021, 22:28:21 »
I 've pushed GB to 1st July - 15th July
« Reply #10 on: Tue, 06 July 2021, 22:28:47 »
« Reply #11 on: Tue, 06 July 2021, 22:29:56 »
It's translation issue, I 've modify that .
« Reply #12 on: Wed, 07 July 2021, 23:15:46 »
GB is live now , welcome to join.
Offline growler
« Reply #13 on: Sat, 10 July 2021, 08:30:10 »
Not QMK/VIA ? :'(
Sent from my SM-G980F using Tapatalk
Don't just stare at it ...
Offline LASERman Projects
  • Soldering is my native language.
« Reply #14 on: Mon, 19 July 2021, 03:08:55 »
Not QMK/VIA ? :'(
AFAIK neither of them supports wireless boards.
