Author Topic: [IC]Flame 60% Gasket keyboard VENDORS ANNOUNCED  (Read 58147 times)
Offline CLAP_STUDIO
« on: Mon, 21 June 2021, 01:15:37 »
FLAME 60% IC From CLAP Studio
Good day to my fellow geekhackers, today I present you the Flame. This is a gasket mount designed keyboard supporting WK and WKL layouts.
270946-0
270948-1
270950-2
270952-3
Keyboard specs:
6063 aluminum
6.5° degree typing angle
PCB: QMK/VIA Compatible, Daughter Board Type C design
Gasket mount (poron gaskets)
3.5MM dampener between plate and PCB
1.5-2MM bottom case dampener
Keyboard layout
270954-4
Keyboard parts:
Top, bottom case (aluminum anodized+e finishes)
Middle frame Brass+sand blasted finish
Bottom plate (brass+sand blast)
Plates (Aluminum, Fr4 supported full and half)
Badge (aluminum anodized) E-white or yellow ish-white is yet to decide due to the machining complications.
PCB Solder NO RGB
Weight and dimensions:
Width: 297.75MM or (11.7 inch)
Depth: 108.25MM or (4.2 inch)
Front height: 20MM or (0.7 inch)
Weight (without any kind of plate): 1.6KG or (3.5LBS)
Case finishes:
Anodized: Black, blue, wine red
E-white
E-yellow white ish or aka soya
Maybe more colors later depending on the prototypes and anodization.
Render colors might slightly differ from the final anodization.
Disclaimers:
All of the images are of 3D renders for illustration purposes only. The final colors may differ slightly.
Vendors:
Deskhero CAD
Prototypist UK
Zion Studio SEA
Keyspensory US
Candykeys EU
Daily clack AUS
Projected GB format: Limited FCFS/Raffle
Projected Pricing: 380-450USD
GB Date: TBD
To do list:
1.   R1 prototypes have already been tested, minor issues with the fr4 plate, need to fix the flex cuts to improve the overall typing feel.
2.   Minor issues with the mid piece, brass is a little bit bendy, will try different machining methods in R2 prototypes. Aluminum does not have any issues at the moment.
3.   Anodizing is almost almost perfect no issues at the moment.
4.   PCB are in the production, waiting for the prototypes.
5.   Need to test PC plate as well as alu plate.
6.   Test the fitting of the packaging, waiting for prototypes
Prototype photos are sent in the discord server!
Lastly I want to thank every one for viewing this IC, hope you all stay safe and healthy!
Update 2021/7/12
As a lot of asked for mounting and interior design info, I guess I'll just make some more renders to understand! Hope you guys like it!
Update 2021/09/07
The R2 prototypes are done and ready for GB.
Prototypes will be sent to Alexotos, Apiary and Mechmerlin for live build.
The dates will be published in the discord server.
More renders
277812-7
277814-8
277816-9
« Last Edit: Thu, 28 October 2021, 01:20:10 by CLAP_STUDIO »
Offline derpturtle
Re: 【IC] Flame 60% Gasket keyboard
« Reply #1 on: Mon, 21 June 2021, 02:07:22 »
Noice
Offline SDKCAMPING
« Reply #2 on: Mon, 21 June 2021, 02:09:52 »
kind of makes me think of a 60% Jane V2, that's interesting!
« Last Edit: Fri, 27 August 2021, 13:32:31 by SDKCAMPING »
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline fflux
« Reply #3 on: Mon, 21 June 2021, 02:31:32 »
Looks great. 6.5° is not my preference, but I'm still gonna keep an eye on it.
Offline 360Ceeee
« Reply #4 on: Mon, 21 June 2021, 02:41:43 »
It‘s nice for me
Offline darthcapn
« Reply #5 on: Mon, 21 June 2021, 03:16:22 »
Looks a lot like something in between the tomo and the jane.
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline hangul
« Reply #6 on: Mon, 21 June 2021, 08:16:53 »
interesting
Offline Visionaire
« Reply #7 on: Mon, 21 June 2021, 08:38:01 »
Not really a fan of the side seam, or the transitions on the bottom. A bit too sharp / squared edges for me. Good luck!
Offline yoniwolf1202
« Reply #8 on: Mon, 21 June 2021, 08:39:29 »
Do you think you can share some photos of the R1 prototypes? I feel like it might be beneficial to show them since you already have them.
Offline hzsh
  • aspiring renderman
« Reply #9 on: Mon, 21 June 2021, 09:01:21 »
The royal blue is a really nice shade, plus the option for WKL is great to see as well. The bottom plate is super clean with the small black logo. Great job designing this, it's very clean and unique!
Offline Neely_12
« Reply #10 on: Mon, 21 June 2021, 09:04:38 »
I like that you have a proto already. Board looks pretty nice, and I would love to see some actual pics of the proto. I would also like to see a better pic of the side profile
Offline Doria_cc
« Reply #11 on: Mon, 21 June 2021, 09:12:44 »
It s fantastic!I love it!I love the blue!
Offline treeleaf64
    • treeleaf64
« Reply #12 on: Mon, 21 June 2021, 09:48:09 »
Plus it's made by  C L A P S T U D I O
Everyone must pay the cat tax
Offline Kansir
« Reply #13 on: Mon, 21 June 2021, 09:48:41 »
That design is so clean, sorry wallet I need this one, definitely in
Offline aRtFiLm
« Reply #14 on: Mon, 21 June 2021, 10:07:31 »
Good!
I want HHKB layout.
Offline Rafa_n
« Reply #15 on: Mon, 21 June 2021, 10:44:53 »
I don't really like the sharp edges or the seam but the bottom looks really nice, very Jane-esque. You should put more prototype pictures in the main post.
« Last Edit: Mon, 21 June 2021, 10:46:54 by Rafa_n »
Offline AstralYT
« Reply #16 on: Mon, 21 June 2021, 14:03:04 »
That Flame logo looks like a bug to me, I would much rather prefer some text.
Offline Luciqueii
  • 【Luciquell & Co.】
« Reply #17 on: Sun, 27 June 2021, 13:34:08 »
Interesting one, looking forward.
Offline synthtastic
« Reply #18 on: Sun, 27 June 2021, 15:58:07 »
Looks nice!
Expensive plastic makes me sigh.
Offline BurganovAziz
« Reply #19 on: Mon, 28 June 2021, 02:04:43 »
RESERVED!!!
Offline nero99666
« Reply #20 on: Mon, 28 June 2021, 02:25:15 »
Offline Dianzi_ma
« Reply #21 on: Mon, 28 June 2021, 07:01:29 »
Let me see(•̀ᴗ• ) ̑̑
Offline QuaintSafe
  • cablecraze.net
« Reply #22 on: Mon, 28 June 2021, 08:46:09 »
Really like the design, is the midpiece visible around the whole board through the seam?
Offline rokon07
  • Reddit: u/rokon-07 | Discord: rokon07#2203
« Reply #23 on: Mon, 28 June 2021, 16:10:19 »
Nice clean design. Glwic
Keycult 1/60 Rev.1 | KL90 | Keycult 2/65 Red| Keycult No2 Contemporary Red | Sat75 | Rama M60a
Offline CLAP_STUDIO
« Reply #24 on: Tue, 29 June 2021, 03:57:56 »
Thank you so much!
Offline CLAP_STUDIO
« Reply #25 on: Tue, 29 June 2021, 03:59:24 »
Yes I will update the post with some photos!
Offline CLAP_STUDIO
« Reply #26 on: Tue, 29 June 2021, 04:00:10 »
Yes it it~
Offline LASERman Projects
  • Soldering is my native language.
« Reply #27 on: Fri, 02 July 2021, 09:53:49 »
Will full Tsangan be available (WK 7U)?
Offline jerryxrj
« Reply #28 on: Sat, 03 July 2021, 02:13:28 »
Nice keeb!
Offline CLAP_STUDIO
« Reply #29 on: Sat, 03 July 2021, 03:04:06 »
Yes it will  , with 7U ;)
Offline CLAP_STUDIO
« Reply #30 on: Sat, 03 July 2021, 03:05:16 »
The edges are not as sharp as illustrated, they are rounded to prevent the sharpness feel, thank you for kind words!
Offline Leo66
« Reply #31 on: Sun, 04 July 2021, 02:56:29 »
good keeb!
Re: [IC] Flame 60% Gasket keyboard
« Reply #32 on: Mon, 12 July 2021, 11:18:24 »
oooooof
Offline _rubik
« Reply #33 on: Tue, 10 August 2021, 18:32:41 »
oooooof
ooof indeed. I'll be watching this one :thumb:
Offline Dran
« Reply #34 on: Sat, 14 August 2021, 14:59:36 »
I like this. It's very clean. Easy on the eyes.
Offline LunoVonFancala
« Reply #35 on: Sat, 21 August 2021, 09:22:39 »
EU vendors? 64 keys PCB? PCB supporting soldred RGB LEDs?
Offline Plurrkeebs
« Reply #36 on: Sat, 04 September 2021, 15:39:40 »
so wow so pog so mucho
Offline 360Ceeee
Re: [IC]Flame 60% Gasket keyboard
« Reply #37 on: Tue, 07 September 2021, 08:34:19 »
Looks great, buy one when GB
Offline gilobeat
« Reply #38 on: Tue, 07 September 2021, 08:42:20 »
what's up!
Offline CLAP_STUDIO
« Reply #39 on: Thu, 09 September 2021, 03:32:29 »
Yes there will be EU vendor, they will be announced very soon!
Offline CLAP_STUDIO
« Reply #40 on: Thu, 09 September 2021, 03:33:08 »
Offline CLAP_STUDIO
« Reply #41 on: Thu, 09 September 2021, 03:52:46 »
Thank you!!
Offline CLAP_STUDIO
« Reply #42 on: Thu, 09 September 2021, 03:54:09 »
We originally wanted to go for 8 however we felt that the bottom would look way too thick! But thanks for the suggestion!
Offline LinandCat
« Reply #43 on: Thu, 09 September 2021, 04:59:25 »
nice broooooo
Offline CLAP_STUDIO
« Reply #44 on: Thu, 09 September 2021, 07:26:13 »
Offline IMZO
  • Matrix shill, and TKL WKL Lover
« Reply #45 on: Fri, 24 September 2021, 03:11:37 »
i think the edges are too sharp
Current boards: Jane V2 CE , Matrix 1.2og Silver WKL , Matrix 2.0add coating black WKL, Matrix 2.0add WKL Coating yellow, Satisfaction75 R1 Cloud white, Korno65, Bloop65, HHKB Pro 2 white,Lin Whale Pink WKL, Gok 7v White, Gok 7v Black, Orion V3 Silver WKL, Orion V2.5 Red WKL, Geon F1-8x Silver WK, Haus65 BlueGray, Plume65, Vertigo, Frog TKL WKL GreenF13
Offline beekey
« Reply #46 on: Sat, 25 September 2021, 01:09:44 »
Will HHKB top be an option?
Offline CLAP_STUDIO
« Reply #47 on: Sun, 26 September 2021, 05:23:24 »
Due to the inner screw design, HHKB wont be an option. Sorry mate
Offline CLAP_STUDIO
« Reply #48 on: Sun, 26 September 2021, 05:24:07 »
The edges seem to be sharp however in real life they aren't ;)
Offline sally
Re: [IC]Flame 60% Gasket keyboard VENDORS ANNOUNCED
« Reply #49 on: Fri, 05 November 2021, 11:02:23 »
Just came across this board, looks amazing! Please GB ASAP
