Author Topic: [IC] ePBT Travelling | GB LIVE  (Read 61520 times)
Offline growler
Re: [IC] ePBT Travelling
« Reply #50 on: Sat, 10 July 2021, 13:38:59 »
Did no one point out the misspelling in the title? Anyway, might as well call it Big City, or Landmark, or Concrete Jungle.
after a quick google search, it appears that "travelling" (two L's) is the correct UK spelling.
This man knows
Sent from my SM-G980F using Tapatalk
Don't just stare at it ...
Offline doggo1dance
« Reply #51 on: Sat, 10 July 2021, 22:03:50 »
a simple google search isnt that hard y'know
Offline 0sumgaim
« Reply #52 on: Sun, 11 July 2021, 00:06:28 »
nice. would buy
Offline sangww
« Reply #53 on: Tue, 20 July 2021, 13:30:20 »
must get this :) a nice simple high quality gray set is surprisingly hard to come by. Good luck!
Offline highdocc
« Reply #54 on: Thu, 29 July 2021, 09:09:16 »
Bases: R1 pipe key should be moved to R2 to cover us-iso support.
Novelties: Need at least one 1u R2 novelty to cover the nav column in 65/75s layout. I recommend moving the 2nd 1u novelty of R3 to R2.
The kits will be changed ASAP, thanks for the feedback.
I forgot to point out that R1 does not have any 1u novelties for the nav column neither. So I recommend moving 1 of the R4 keys to R1.
Resolved!
Offline Cylent
  • Formerly cylentshadows
Re: [IC] ePBT Travelling - Revamp! New Kits!
« Reply #55 on: Thu, 29 July 2021, 09:43:18 »
These changes are an improvement, good job!  :thumb: I still don't vibe with the white on grey mods, but I'm sure others will like it.
I still don't understand the katakana alt alphas, but if you have them, why not make a 40s mods kit that combines with it?
Offline pool
« Reply #56 on: Thu, 29 July 2021, 21:20:16 »
The world according to keycap set designers
« Last Edit: Thu, 29 July 2021, 21:24:01 by pool »
Offline balance
« Reply #57 on: Sat, 31 July 2021, 14:26:43 »
This set looks hella good! GLWIC
Offline conternecticus
« Reply #58 on: Sun, 01 August 2021, 05:42:20 »
Please consider other manufacturers with better lead times.
Edit: Wait, you're going with ePBT now. That's great! Very interested. This set can be mixed well into some other sets I'm having, GLWIC!
« Last Edit: Thu, 05 August 2021, 00:18:36 by conternecticus »
Offline _IanOfEarth
« Reply #59 on: Mon, 02 August 2021, 15:26:37 »
Why does the modern kit have black legends when the rest of the kit has white legends?
Offline kajahtaa
« Reply #60 on: Sun, 22 August 2021, 18:01:11 »
ne nomad kit avail?
Offline MOO·OON
« Reply #61 on: Mon, 23 August 2021, 21:42:34 »
well done, It's beautiful and exquisite. :thumb:
Offline Nukz
  • ig: nukzak
Re: [IC] ePBT Travelling - Deskmat! Vendors Announced!
« Reply #62 on: Sat, 11 September 2021, 14:20:10 »
love the new update! keep the work up!
Offline _rubik
« Reply #63 on: Sat, 11 September 2021, 17:57:28 »
*makes set about traveling the world*
A journey where you travel all around the world
*adds Japanese sublegends*
At least the deskmat looks cool.
« Last Edit: Sat, 11 September 2021, 17:59:00 by _rubik »
Offline andtar2
« Reply #64 on: Sun, 12 September 2021, 00:25:45 »
There is one wrong key in International kit, R1 ": ;" should be "; ,"
Seems to be an error in some default file from the kit rendering software(?) that is propagating everywhere.
Offline highdocc
« Reply #65 on: Wed, 15 September 2021, 00:22:54 »
Thanks ;)
Offline matthewdias
« Reply #66 on: Sat, 18 September 2021, 18:02:30 »
echoing cylent here, it would be nice to see 40s become a full mods kit so it could be paired with alt alphas to be a lot more affordable.
Offline Unenlightenment
« Reply #67 on: Mon, 20 September 2021, 12:35:45 »
I kinda liked the white on grey alphas but I'll probably still get this since I think this will look nice on a board I'll be getting
Offline //gainsborough
  • MATRIXの日常
« Reply #68 on: Mon, 20 September 2021, 13:20:59 »
awww dang.  I loved the white on grey look =/  New update does look good, but RIP original set, haha.
Offline jagger27
  • ne 1.5U supers???
« Reply #69 on: Mon, 20 September 2021, 15:06:38 »
Can the diamond supers be changed to ⌘? Does anyone actually like the diamond?
Offline konstantin
  • Formerly constexpr
« Reply #70 on: Mon, 20 September 2021, 16:04:19 »
I love me some diamonds.
That being said, your suggestion is not a bad one — if applied only to the 1.5u keys in the Modern kit.
Offline _rubik
« Reply #71 on: Mon, 20 September 2021, 16:55:30 »
I'm partial to diamonds because they're system-agnostic. That said, I feel like there's a very fine line between "modern kit" and "osx kit" these days.
Offline jagger27
  • ne 1.5U supers???
« Reply #72 on: Tue, 21 September 2021, 11:57:27 »
That would be okay.
I just feel like the diamonds are slapped on because that's what someone did 100 GBs ago and no one puts any thought into why. As far as I can tell, it's a throwback to Sun Microsystems keyboards which otherwise had text mods. The diamond on those keyboards was square, solid, and tiny. The "weight" and feel of the outlined diamond in this set doesn't match the rest of the symbols. If you want the MacOS look, do it right. Don't **** around with weird symbols for no reason. It's not as if ⌘ is an Apple trademark.
Or if you want to shut me up altogether, just put 1.5U Super text mods in base and I'll be on my way.
« Last Edit: Tue, 21 September 2021, 18:26:00 by jagger27 »
Offline highdocc
« Reply #73 on: Tue, 21 September 2021, 13:16:14 »
The white on gray was not initially in the set , it was also a change.
« Reply #74 on: Wed, 22 September 2021, 16:41:00 »
Could you add a row 4 equal key to the numpad kit?
Offline DeMechanica
Re: [IC] ePBT Travelling - GB Date Announced!
« Reply #75 on: Thu, 14 October 2021, 05:16:19 »
Loved the white on grey GMK set, sad to see it go. Might have to run something like it myself, if I can find the time.
Offline menuhin
« Reply #76 on: Fri, 15 October 2021, 11:51:27 »
How many of these places are in Europe + former European colonies?
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline vishydesigns
« Reply #77 on: Fri, 15 October 2021, 11:58:16 »
absolutely LOVE the novelties, not really sure of the reasoning behind the alt alpha kits. But this set looks great! keep it up :thumb:
Offline highdocc
« Reply #78 on: Sun, 17 October 2021, 08:45:04 »
Most of these places are in Europe.
Also I chose these novelties exactly , because these are the places I visited myself and which I love the most.
Offline highdocc
« Reply #79 on: Wed, 08 December 2021, 02:34:49 »
Just posted new renders on 4 new boards!
Offline highdocc
« Reply #80 on: Thu, 09 December 2021, 07:05:11 »
haha thanks :D
Offline andromache
« Reply #81 on: Thu, 09 December 2021, 09:31:34 »
The European centric novelties make the sublegend kits you're offering for this set even more confusing.
Offline TyPo.mk
Re: [IC] ePBT Travelling - GB December 15th
« Reply #82 on: Thu, 09 December 2021, 12:07:58 »
I also really like modo
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #83 on: Thu, 09 December 2021, 19:08:57 »
oh it's still a weeb set
Offline highdocc
« Reply #84 on: Tue, 14 December 2021, 16:33:26 »
thank you :D
Offline XiXora
Re: [IC] ePBT Travelling - GB Live
« Reply #85 on: Wed, 15 December 2021, 19:05:06 »
R4 [><] is a duplicate of base, I assume this should be R4 [|\] key for UK ISO.
This seems to happen with every ePBT Intl kit? Is there some template everyone is copying?
Offline highdocc
Re: [IC] ePBT Travelling | GB LIVE
« Reply #86 on: Wed, 22 December 2021, 13:14:05 »
I modified the kits renders, in order for the colours to look more realistically!
Offline rndr
    • Keyboard Enthusiast Writeups
« Reply #87 on: Sun, 09 January 2022, 12:00:05 »
Skipping this as the colors and the theme don't match. Also, they aren't appealing to me.
