Author Topic: Steelseries 6Gv2 vs Razer Blackwidow  (Read 12778 times)
Offline SmallWalrus
« on: Wed, 25 August 2010, 20:39:16 »
Which of these two keyboards will you prefer for general typing tasks, and in general?
I've been pondering about the differences of these two 'boards and I do gravitate a bit more towards the Steelseries, because that supposedly has a metallic chassis. Perhaps someone who has touched one in real life might be able to comment on whether that genuinely contributes to the "heft" of the keyboard and overall build quality, or if it was a marketing gimmick?
The Ducky keyboard community mass order thread
Get one set of keycaps free for a limited time only! :)
Offline Arc'xer
« Reply #1 on: Wed, 25 August 2010, 21:37:24 »
Steelseries is just a branding name ironically the same kind of thinking has persisted since the company opened up. Many people think their mouse pads and their offerings have steel in them they don't.
The only metal is the back plate for the switches.
But all the SS G-type(6/2, 7) are linear mx black, while razer seems to be offering blues apparently.
Offline Zen
« Reply #2 on: Thu, 26 August 2010, 11:56:33 »
You should try both if possible, they are VERY different boards,
steelseries has linear 70 grams activation-force and 4mm actuation,
the razor tactile 50 grams and 2mm .
If you are used to a clicky-board you may
easily dislike typing on linear switches, but they are great for gaming IMO
No, the steelseries boards don't have metal-chassis, but they are heavy and stiff .
Offline SidiMye
« Reply #3 on: Thu, 26 August 2010, 12:19:32 »
The Steelseries 6GV2 maybe doesn't have a steel chassis but the plastic used is really sturdy and thick like it could take a punch, I've opened up this thing multiple times now and its really well made. Types good also after a less then a month of use, and for games its great..
Steelseries 6GV2 Black Cherry
Offline washuai
    • http://home.earthlink.net/~haruai/
« Reply #4 on: Thu, 26 August 2010, 15:16:51 »
Quote from: Zen;216914
Cherry blacks (steel series) actuate at 2mm, just like cherry blues (blackwidow), but both can go full 4mm of travel.  Refer to the wiki article, for your switch info.
Blues versus blacks for typing- I'd have to go with blues, tactile, clicky and lower force.  I wouldn't avoid a board with blacks, but it wouldn't be my daily driver for non-gaming.
If you want luxury aluminum, check this thread.  The $500 proposed price tag, is a good example of how you know the steelseries doesn't pack steel.
« Last Edit: Thu, 26 August 2010, 15:19:45 by washuai »
⌨(home)Realforce 87U ⌨(backup) Filco Majestouch 104 Brown ⌨(backup)Cherry G80-8200LPDUS ⌨(work)Leopold FC200RT/AB
☛CST L-Trac-X ☛Logitech Wireless Optical Trackman ☛ Razer 3500 dpi ☛MS Explorer DeathAdder
Lay-a-bouts:  ⌨Full 109 Key Virtually Indestructable  Keyboard ⌨Compaq Radio Quack GYUR84SK
Wishlist: ⌨KBDmania Pure ⌨Déck 82 ice/frost/toxic/royal ⌨Ricercar spos G86-62410EUAGSA ☠ ✞⌨miniGuru(s) ☠
 ✐Intuos or Cintiq
Offline lmnop
« Reply #5 on: Thu, 26 August 2010, 16:30:16 »
i-Rocks KR-6250 has a steel casing.
the prototype has PCB mounted Cherry MX Red Linear switches but all translations indicate the final product will have Cherry MX Black Linear switches.
« Last Edit: Thu, 26 August 2010, 16:33:34 by lmnop »
Offline lmnop
« Reply #6 on: Thu, 26 August 2010, 16:36:18 »
if you doubt it's steel.
someone at Computex scratched it good.
« Last Edit: Thu, 26 August 2010, 16:56:35 by lmnop »
Offline lmnop
« Reply #7 on: Thu, 26 August 2010, 16:57:40 »
Offline AvengeR
« Reply #8 on: Thu, 26 August 2010, 17:00:51 »
gamers tend to think they need "gaming grade" products to be able to play the way it should be, or get better at it.
Don't look there if you want a good kb, peripheral or anything really, besides few exceptions.
(on the other hand I use a qck heavy mousepad, but in the end its just a regular oversized cloth mousepad and that could be better)
« Last Edit: Thu, 26 August 2010, 17:03:39 by AvengeR »
Offline lmnop
« Reply #9 on: Thu, 26 August 2010, 17:16:31 »
Quote from: AvengeR;217032
I don't think they know the materials that make up a keyboard. I don't think they even care.
Offline lmnop
« Reply #10 on: Thu, 26 August 2010, 17:34:51 »
last week I was trying to convert someone and he said something like "PBT, ABS I don't care as long as the plastic holds it." after I managed to stop fantasizing about choking him I said "..." and posted this video.
