Author Topic: [GB] PIXELSPACE STUDIO X KBDFANS ENDLESS-80 MECHANICAL KEYBOARD DIY KIT  (Read 8659 times)
Offline kbdfans
Group Buy Date:June 5th to July 5th, 2021
Estimated shipping date: will be announced after the GB ends
Introduction
GO TO GROUP BUY LINK
"ENDLESS-80", yes, it is a spaceship that travels through the endless universe. The original intention of the author of "pixelspace studio" when designing this kit. The author is a science fiction fan. He is interested in all kinds of science fiction works, so the overall style of the keyboard is more "sci-fi" and "cyberpunk." They spent four months designing the front side RGB lighting effect to make it look better and more connotative. For the light trough of the CAPS lamp, the team also select plenty of different kinds and finally chose this kind of retro PC design to fit the overall package. The overall style, "A gift from the future," is a gift from the future!
     E-beige case+ E-yellow weight        E-beige case+ Purple weight
     E-yellow case+ Brown weight        Black case+ Green weight
     Grey case+ Brown weight        Purple case+ Green weight
        Black case+ Red weight
Specification
  • Top Mount
  • Typing angle: 5 degree
  • Layout: 80% TKL Layout, the solder PCB support multiple layouts (7U space bar, 6.25U space bar, ISO enter keys), Hot-swap PCB only support 7U space bar
  • PCB support QMK/VIA
  • RGB Light Diffuser is designed for Caps lock
Include
  • Aluminum top and bottom case x1
  • Aluminum type-c cover X1
  • Aluminum nameplate x1
  • Aluminum painted weight bar x1
  • Aluminum light slot x1
  • 1.5mm Aluminum(Brass,PC) Plate x1
  • 1.6mm Hot-swap PCB x1
  • PCB for RGB x1
  • Polished acrylic LGP(light guide plate) x1
  • Acrylic black light covers x1
  • 4MM PORON foam x1
  • 3MM PORON foam x1
  • Light Indicator (Red/Purple/Green) x3
  • Silicone rubber feet x 5
Layout Pictures
Stucture
Endless 80 Sound Test
More Effect Pictures
« Last Edit: Fri, 08 October 2021, 00:20:33 by kbdfans »
