Author Topic: [GB] KBDFANS MOUNTAIN ERGO KEYBOARD KIT  (Read 12242 times)
Offline kbdfans
« on: Thu, 01 July 2021, 02:01:09 »
KBDfans MOUNTAIN ERGO KEYBOARD KIT
Group buy date: July 1st, 2021
The first batch will provide 300 sets as pre-sale and will complete production in 3 months.
Mountain Ergo Sound Test
Introduction
Designed by KBDfans Wei, the inspiration of the design is from the peaks perfectly textured.
The black&white is the most classic combo for it.
Conquer a mysterious mountain peak could be the most ordinary's daydream.
The Ergo design base on Human factors and ergonomics.
You know the "Mountain Ergo" doesn't have a usual first impression like other standard keyboards, but do you really care?
The Mountain Ergo
Keycaps in the picture: ePBT Shadow
Design Details
Color options: Aluminum Black, E-white
Typing Angle:Left 5°, right 3°, case 7°
Click here for: Tmk firmware,programmable
Aluminum Top and Bottom case
bottom weight: E-white or Alu Black
Plate: Aluminum material
Ergonomic design,PCB and Plate are split.
PCB: solder version and hot-swap version; Type-C interface; Solder version does not support LED, indicating light support.
Mac,Windows,Linux compatible
Plate Details
Real Life Pictures
Keyboard Structure
Offline stein3
Re: [GB] KBDFANS MOUNTAIN ERGO KEYBOARD KIT
« Reply #1 on: Thu, 01 July 2021, 21:09:08 »
What layouts are supported on the respective PCBs?
Offline lecorsair
« Reply #2 on: Thu, 01 July 2021, 21:36:09 »
Looks like it's a fixed layout based on the plate. Difference in pcbs is hotswap and soldered.
Offline beekey
« Reply #3 on: Thu, 01 July 2021, 23:57:05 »
I would be interested if split backspace is supported, for the rest I think you are right, looks fixed.
Offline ElementalWheel
« Reply #4 on: Fri, 02 July 2021, 13:21:52 »
I'm ok with fixed layout as for something like this specific I would require at least US ISO. Cant pass on this beautiful design from the alps as skiing lover lol
Offline xiec1
« Reply #5 on: Sat, 03 July 2021, 00:34:04 »
What is the material of E-white?
Offline james97
« Reply #6 on: Tue, 13 July 2021, 21:50:10 »
Love the sound of keycap clicking. Does it support cherry keycap ?
Offline yhs
« Reply #7 on: Wed, 14 July 2021, 06:25:07 »
Wat?
