Author Topic: [IC] Corgi65 Butt Keyboard!  (Read 38632 times)
Offline peirypeily
« on: Sat, 03 July 2021, 16:52:03 »
Hello everyone!
It's my first post here and I am thrilled to introduce you the Corgi65, the butt keyboard!
Corgi65 specs:
Top case options:  Option 66: Badge + WKL / Option 67: No badge + WKL /  Option 68: No Badge
Materials: Aluminum top & bottom case
Typing angle: 4 degree
Mounting method: Top mount
Plate: Silver aluminum, black aluminum, polycarbonate or Brass (purchased separately)
Case colors: E-white, Black, Grey,  Silver, Blue, Green & Pink
Badge colors: Black, Silver, Grey, Green, Blue or Pink
Weight colors: same as badge or Green, Blue, Silver & Pink
Note: PCB is not included in the kit, can be on request
Compatible PCB: DZ65 soldering(for all 66, 67, 68); DZ65 V3 hot swap(for 68); CZ67(for 68); CZ68(for 68) and more
What is in the kit?
1 x Aluminum top & bottom case
1 x Weight
1 x Plate - silver or black aluminum, polycarbonate or brass purchased separately
1 x 3.5mm poron foam
1 x Bottom foam
Let me know what you guys think  :^)
Thank you!
Hi again, just a quick update. I am so grateful of all the feedbacks from the interest check, thank you, it means a lot!
And as well about the badges, I understand that the butt or corgi is more prefered instead.
But the space does not allow much design to fit as I know of now but I will definitely keep looking into it, and as well the color as some of you have mentioned.
I've added ome inside pictures as well, hope you all like it.
Have a good one.
« Last Edit: Sun, 04 July 2021, 14:32:48 by peirypeily »
Offline Moabee
Re: [IC] Corgi65 Butt Keyboard!
« Reply #1 on: Sat, 03 July 2021, 17:05:05 »
Your IC form is broken.
Offline peirypeily
« Reply #2 on: Sat, 03 July 2021, 17:10:20 »
I gave up on the the text xD  should be good now thanks
Offline driftingbunnies
« Reply #3 on: Sat, 03 July 2021, 17:23:07 »
I think if the corgi butt is the main theme, it should either be the top right blocker or the weight. I rarely look at the rear of the keyboard.
Offline MIGHTY CHICKEN
« Reply #4 on: Sat, 03 July 2021, 18:01:13 »
this
Offline NOLA
« Reply #5 on: Sat, 03 July 2021, 18:15:40 »
I mean, how often are you picking up your keyboard to admire the weight? lol
Offline kioskhill45
« Reply #6 on: Sat, 03 July 2021, 18:27:23 »
But the corgi's rear is on the keyboard's rear
« Reply #7 on: Sat, 03 July 2021, 18:56:20 »
This is why i suggested to put it on the right blocker. Also, if nobody admires the weight, why do so many keyboards have designs on the weight? It's something that people like knowing that there is something nice there and generally people show others the bottom of their keyboard cause there is something cool there.
Offline Neely_12
« Reply #8 on: Sat, 03 July 2021, 19:10:37 »
I love the bezels on the top, and I like the design in general. I would have to agree with the others, but I can also see why having trouble to fit a deisgn of a corgi that is comprehensible would be a challenge. Either way good luck!
Offline treeleaf64
    • treeleaf64
« Reply #9 on: Sat, 03 July 2021, 22:01:39 »
I really like butt if you know what I mean
  Not sure if I like the doggie though
Everyone must pay the cat tax
Offline Pyroo
« Reply #10 on: Sun, 04 July 2021, 05:43:16 »
Looks great can you perhaps show internals and plate design/mounting points?
Bunny enthusiast
Offline Keeblet_257
« Reply #11 on: Sun, 04 July 2021, 07:55:48 »
keepingan eye open for further updates
Offline peirypeily
« Reply #12 on: Sun, 04 July 2021, 14:34:53 »
Hi hi, thanks for the advice, but the badge is quite limited as far as I know but I will definitely keep that in mind :D
Offline peirypeily
« Reply #13 on: Sun, 04 July 2021, 14:36:13 »
"But the corgi's rear is on the keyboard's rear" IS GOLD
Offline peirypeily
« Reply #14 on: Sun, 04 July 2021, 14:37:08 »
LMAOOOOO I mean .. I mean ..
If you know you know :^)
Offline peirypeily
« Reply #15 on: Sun, 04 July 2021, 14:39:05 »
Thank you ^^ and yeah the amount of the space on the top case is limited
Offline peirypeily
« Reply #16 on: Sun, 04 July 2021, 14:39:32 »
thank you ^^
Offline peirypeily
« Reply #17 on: Sun, 04 July 2021, 14:40:09 »
Internals pics are updated :D
Offline Corgi Butts
« Reply #18 on: Sun, 04 July 2021, 16:58:04 »
SIGN ME THE **** UP!
Offline Minahctrl
« Reply #19 on: Sun, 04 July 2021, 17:49:05 »
yes yes yes this is cute
wheres that cable from?
Offline EnlargedCrouton
« Reply #20 on: Sun, 04 July 2021, 18:49:07 »
i agree with this
Offline Spoopy
« Reply #21 on: Sun, 04 July 2021, 22:46:55 »
Very cute keeb! I really like the aesthetics and the sound tests I found online were solid! If pricing is around 200-300 USD I'm in!
Offline peirypeily
« Reply #22 on: Mon, 05 July 2021, 03:23:22 »
Offline asianfork
  • Alice
« Reply #23 on: Tue, 06 July 2021, 19:10:06 »
Very cute! Do you have a discord for updates? And will we also be able to mix and match badges?
« Last Edit: Tue, 06 July 2021, 19:21:12 by asianfork »
Offline konstantin
  • Formerly constexpr
« Reply #24 on: Tue, 06 July 2021, 19:22:05 »
And here I was expecting there to be a solid brass corgi-butt–shaped weight on the bottom. Actually, scratch that, I was expecting the whole back and bottom of the board to be butt-shaped.
Offline flying1911
    • Mechlovin' Studio
« Reply #25 on: Wed, 07 July 2021, 02:38:12 »
I like butts
Jane V2 | Jane CE | Jane V2 CE | Police | Kaze | KMAC 2 | BRG Haus | Sessantacinque | Ori CLS-2 FE | Dalco 959 Mini | Mechlovin' Unikorn | G81-3100 SAV | Model M SSK
Offline metalkeyboards
  • CNC Milled Aluminum KeyCaps from Tønsberg, NORWAY
    • MetalKeyboards SHOP
« Reply #26 on: Wed, 07 July 2021, 14:22:28 »
anything butt!
All METAL All DAY!
Offline Soraie
« Reply #27 on: Wed, 07 July 2021, 18:34:41 »
Would vouch for the opinions said as well. Corgi butt as the badge if possible and/or a larger bottom weight would be nice too
Regardless, I'm definitely in
Offline fantasyrulz
« Reply #28 on: Thu, 08 July 2021, 07:52:53 »
so cute!
would be better if you use the corgi butt logo at the back instead of the paw
but overall really great idea there  :thumb:
Offline mikn
« Reply #29 on: Thu, 08 July 2021, 19:01:53 »
yes move the type c to the center so we can plug the butt yes
Offline PC Concepts
  • PC Concepts Mari
    • Discord
« Reply #30 on: Thu, 08 July 2021, 19:48:08 »
Need this board in my life rn. ;D
Offline mr_foggy
  • neue = nope
« Reply #31 on: Sun, 11 July 2021, 18:55:48 »
Y E S
I will buy three. I need this is my life.
Offline GLOVE
« Reply #32 on: Sun, 11 July 2021, 20:44:20 »
Cute suit, and 65% comfortable
Offline literarylottie
« Reply #33 on: Thu, 12 August 2021, 14:50:08 »
Going against the grain a bit to say that I love the pawprint badge and wouldn't change it. I agree that the corgi butt should be the bottom weight, though.
Cute board, OP! Definitely keeping an eye on this.
Offline Navyjai
« Reply #34 on: Thu, 12 August 2021, 23:10:01 »
Missed opportunity to put the USB port in a more theme related area
Offline brazen
  • Brazen Studio, makers of the Mason60
    • IMG
« Reply #35 on: Fri, 13 August 2021, 06:19:44 »
Corgi Butt!  I have a big ol fluffy corgi at home who does indeed have a nice butt haha
Brazen Studio
IG:  @brazenstudio
Offline dexie
« Reply #36 on: Fri, 13 August 2021, 09:44:29 »
Is it possible to get corgi butt logo with a tail? I am kinda against tail docking.
ISO Life
Offline digits
« Reply #37 on: Fri, 13 August 2021, 12:52:55 »
sick! do you have a discord or something
Offline RyaneRyoko
« Reply #38 on: Sat, 21 August 2021, 20:50:54 »
Has the GB started yet or has ended?
I've seen people having this keyboard already as well as selling it.
Offline mr_foggy
  • neue = nope
« Reply #39 on: Sun, 29 August 2021, 09:51:57 »
same. I've been seeing some for sale. when did this GB run? haven't seen anything about it.
Offline bastijn
« Reply #40 on: Sun, 29 August 2021, 15:20:44 »
Would be better if you go big and put it on (back of the) weight like Nyaong75 or move it the USB port to corgi's rear.. Now it is a bit too polite.
"The purpose of computing is insight, not numbers." -- Richard Hamming
Offline sdaf2
« Reply #41 on: Tue, 31 August 2021, 21:11:49 »
Apparently it ran on https://studiogreenfield.net/ and looks like it even had a second run already, going by some of the posts in their discord.
Offline __init__
« Reply #42 on: Tue, 31 August 2021, 22:46:03 »
wtf, why even list it here if you're not going to update or provide information? Am I not understanding something correctly?
Offline sabomov
« Reply #43 on: Wed, 01 September 2021, 04:43:13 »
(UwU) Nice! glwic!
Offline patato251
« Reply #44 on: Wed, 15 September 2021, 07:18:05 »
I think the GB has just run in asia and not globally yet right? If you wanted to see where its being sold, a quick google search and you'll see it on etsy showing the whole kit being sold (not sure if maybe it was an earlier run or what it is tbh).
Checking studiogreenfield discord also looks like it potentially has only run in asia (but as I can't translate anything on there then please don't quote me, just observations)
Offline __init__
« Reply #45 on: Wed, 15 September 2021, 18:38:15 »
Ohhhhhh right. Thanks for the insight. I honestly didn't think of that.
Offline patato251
« Reply #46 on: Wed, 15 September 2021, 23:07:16 »
Allg, honeslty i didnt think of it too until looking into it further. Once again, as I can't translate whatever is on there, this is just me still lowkey guessing haha. From the looks on the etsy page and stuff tho the board is looking great, hopefully we hear some news about a GB soon if it really hasnt run yet  ;D ;D ;D ;D
EDIT: From what i saw from google translate and here https://www.zfrontier.com/app/flow/4ZAWEVQp6Go1 it looks like there was indeed a run for it, but considering there was no global info bout it ill assume it was asia/china only potentailly. A build vid posted about a month ago also said that a global GB would be starting soon (although that was 2 months ago and no news since then so not sure now. Heres the vid with the description saying that:
« Last Edit: Thu, 16 September 2021, 01:21:01 by patato251 »
Offline Jennisaurus
« Reply #47 on: Thu, 16 September 2021, 23:16:26 »
I saw this board being sold on an SG-based online store and found this thread to learn more about it! I'm glad that there is (hopefully) still going to be a global run of this at some point in the future! The corgi butt is just too cute ^^
Offline speedyzy
« Reply #48 on: Fri, 01 October 2021, 16:02:21 »
so cute :(
Offline aerOcraft
« Reply #49 on: Fri, 15 October 2021, 15:56:12 »
I don't know how I didn't think about it for when I filled out the IC, but you should have the USB port be the corgi butt, then it can be a corgi butthole. Lol.
