Author Topic: Gateron Crystal switches  (Read 9476 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Sun, 04 July 2021, 03:28:50 »
SPEC
Crystal Red
Travel distance=4.0 mm MAX
Actuation=2.0+/-0.5mm
force=45g+/-10gf
bottom force = 50g
duration = 80 million clicks
Crystal Blue
Actuation=2.3+/-0.5mm
force=60g+/-10gf
bottom force = 53g
duration = 60 million clicks
Crystal Brown
force=55g+/-10gf
bottom force = 55g
Crystal Yellow
force=50g+/-10gf
bottom force = 60g
Crystal Silent Red
force=45g+/-10gf
bottom force = 50g
Crystal Silver
Travel distance=3.4 mm MAX
Actuation=1.2+/-0.3mm
force=45g+/-10gf
bottom force = 50g
JOIN DISCORD get more info
« Last Edit: Mon, 05 July 2021, 00:36:21 by KPrepublic »
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: Gateron Crystal switches
« Reply #1 on: Sun, 04 July 2021, 03:31:30 »
« Reply #2 on: Sun, 04 July 2021, 04:36:55 »
Are these linear, clicky or tactile?  The actuation distances look to be copying the Cherries of the same colour but maybe not.
« Reply #3 on: Sun, 04 July 2021, 18:38:17 »
800 million is a crazy high number of clicks - more than 10 times most switches :eek:
Offline MIGHTY CHICKEN
« Reply #4 on: Sun, 04 July 2021, 20:10:44 »
All of the above
Red Yellow Black Linear
Blue Clicky
Brown Tactile
Offline KPrepublic
  • * Moderator
    • KPrepublic
« Reply #5 on: Mon, 05 July 2021, 00:36:59 »
sorry for the typos.
Should be 80 million clicks.
« Reply #6 on: Mon, 05 July 2021, 03:17:46 »
Ah, yes, that sounds more like it.
Thank you for the correction :)
