Author Topic: Clear vs. Brown switches  (Read 2789 times)
Offline Jarmel
« on: Thu, 26 August 2010, 16:11:34 »
I just ordered a tactile Deck Legend and was wondering if I should have gotten the Das Silent which has brown.  I do a lot of gaming and typing so black was out of the question although I badly wanted the Toxic Deck.
Offline itlnstln
« Reply #1 on: Thu, 26 August 2010, 16:13:43 »
It should be fine.  What keyboard were you using before?
Offline Infinite north
« Reply #2 on: Thu, 26 August 2010, 16:18:10 »
I personally think clears should only be used for typing, the spring tension is even heavier than black springs so trying to hold shift down for long periods of time is very taxing on the pinky finger. I feel like the extra tension makes for a better cushion for heavy typists, this is all relative though and your opinion could vary greatly.
Offline Jarmel
« Reply #3 on: Thu, 26 August 2010, 16:22:31 »
Rubberdome, G19.
Offline itlnstln
« Reply #4 on: Thu, 26 August 2010, 16:26:52 »
If you're coming from a rubber dome, you should be fine.  You would probably find the browns to be too light.
Offline Jarmel
« Reply #5 on: Thu, 26 August 2010, 17:37:21 »
However isn't lighter better for typing?
Offline washuai
    • http://home.earthlink.net/~haruai/
« Reply #6 on: Thu, 26 August 2010, 18:23:51 »
Quote from: Jarmel;217039
Depends on what you want it better for - speed, less fatigue, fewer accidental presses, etc.
Theoretically, typing on browns, should be faster than clears, once you're acclimated.
Lower force (browns) should give you less fatigue.  It really depends on how you type and how fast you type.  Lower force, usually, but doesn't always equal less fatigue.
You could more easily accidentally activate browns, if you're resting your paws on the board.  Correcting mistakes, means slower.
You can feel the tactile point better with clears, which could lead to better typing, than the more subtle browns.  I feel browns fine, but not everyone does.
I definitely love, when I get that light, barely touching, the keys feeling of flying across the browns, when I am on a roll and not bottoming out.
⌨(home)Realforce 87U ⌨(backup) Filco Majestouch 104 Brown ⌨(backup)Cherry G80-8200LPDUS ⌨(work)Leopold FC200RT/AB
☛CST L-Trac-X ☛Logitech Wireless Optical Trackman ☛ Razer 3500 dpi ☛MS Explorer DeathAdder
Lay-a-bouts:  ⌨Full 109 Key Virtually Indestructable  Keyboard ⌨Compaq Radio Quack GYUR84SK
Wishlist: ⌨KBDmania Pure ⌨Déck 82 ice/frost/toxic/royal ⌨Ricercar spos G86-62410EUAGSA ☠ ✞⌨miniGuru(s) ☠
 ✐Intuos or Cintiq
Offline ironman31
« Reply #7 on: Thu, 26 August 2010, 18:26:17 »
Sometimes. As long as you get used to it and can type without bottoming out all the time. That's the only time I feel like typing on the browns is unique from any other keyboard.
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/AT,  Noppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
« Reply #8 on: Thu, 26 August 2010, 20:34:51 »
Clears are perfectly designed for typing, the keys are fairly low force until actuation. the springs only start to feel heavy after the tactile bump, this forces better finger control.
Offline itlnstln
« Reply #9 on: Fri, 27 August 2010, 07:39:19 »
It's all subjective.  A lot of GH members' "fastest" keyboard is a Model M, which is not exactly the lightest keyboard in the world. For me, the lighter the keyboard, the better.  I am not a particularly fast typer, but I type all day, so I like switches that prevent fatigue.
