Author Topic: Question about QMK...  (Read 3122 times)
Offline geauxflying
« on: Thu, 08 July 2021, 00:31:14 »
About to try out VIAL, but curious to learn what I'm doing wrong here.
I've tried a number of syntax variations. The keymap.c file is created from a JSON export from QMK configurator with encoder code pasted in to the keymap.c. To be sure it wasn't a problem caused by my copy/paste, I tried to compile it based on a direct export from QMK configurator and got the same error.
I ran QMK doctor, it says my setup is fine.
Offline blondie
Re: Question about QMK...
« Reply #1 on: Thu, 08 July 2021, 14:42:57 »
I believe you want to provide the directory in which your keymap.c file resides as the option to -km, not the name of the file (which probably needs to be keymap.c).
For example, I have the Ploopy trackball, and I compile with this command:
Code: [Select]
qmk compile -kb ploopyco/trackball/rev1_005 -km ploopy
And the keymap is found here:
Code: [Select]
23> ls keyboards/ploopyco/trackball/keymaps/ploopy/
keymap.c  readme.md
There is no greater knowledge than the knowledge of one's self. There is no greater truth than the truth of moral conviction. And there is no greater keyboard than the one beneath my fingertips.
Offline geauxflying
« Reply #2 on: Thu, 08 July 2021, 15:39:45 »
Brilliant... I'll try that! Thank you. What is the significance of the "rev1_005" in your compile command?
Offline blondie
« Reply #3 on: Thu, 08 July 2021, 18:08:45 »
This particular product had different revisions. If you look under the keyboards directory, there are a lot of different keyboards. The value you provide to the -kb is the path within the keyboards directory to what you want to build. I see boston has no subdirectories under it except for the keymaps. But the Ploopy has a bunch of directories and subdirectories for different products and their revisions.
