Author Topic: [IC] ePBT Hellas | GB ENDED  (Read 41030 times)
Offline Biscuit
« on: Fri, 09 July 2021, 09:35:27 »
GB live on 20 November till 20 December
ETA Q4 2022
GB page: https://geekhack.org/index.php?topic=115373.msg3095339#msg3095339
All updates and information will go through here
Introducing EPBT Hellas
A keycap set inspired by the city of Athens in Greece. I have been there multiple times, and it is my favorite city in the world.
Because of the beautiful ancient architecture, history and overall ambience of the city
Hellas=Greece btw
Updates
August 2nd 2021
Changed kitting:
Added a Latin only kit
Removed off-centered spacebars
Added another 2 3U spacebars
Changed 2nd pipe R3 to alpha color
Changed 2nd tilde to mod color
Removed extra Alt Gr
Removed m in international kit
Moved accent arrows to base
Changed colors:
I changed the mod pantone to 283U, this color matches closer to the renders.
283U is more saturated than 644U and comes a bit closer to that typical Greek blue you see, but is still closer to navy.
I have changed the image where I compare the pantones but kept the old color for comparison.
I have also updated the pictures of the pantone, the new ones are taken in different lighting for better representation of the colors.
The render color has not changed.
Deskmats:
Added new deskmat
vendors:
Added Stackskb as Indian vendor
August 11, 2021
Changed novelties:
Changed the sizing, thickness and fixed some minor issues
Changed the novelty line color on the blue novelties to alpha color
Replaced the accent colored novelties on row 4 for mod colored
Flipped the owl for symmetry for left and right
Moved the A -TH-E novelties up one
So A=Row1, TH=Row2, E=Row3
Moved the Olive Branch to Row 4
Added renders
(on the board renders it says "super" on the key, and on the kitting "code".
It is supposed to be "code".)
maybe i should not have said anything
Removed owl on deskmat and added another pattern at the bottom
August 22nd 2021
Changed kitting:
added 2u spacebar in 40s
added 1u spacebars and accented alice spacebars in spacebars kit
Changed renders:
Made the renders less bright and adjusted the accent color that matches closer to the pantone. Mind that everyone’s monitor still displays color differently.
Changed color:
Chose a lighter alpha color (656U)
August 25th 2021
Added more renders
September 12th 2021
Added more board renders
Changed novelties
Olive novelty changed
Made the A novelty more narrow
Extended base on statue
made owl slightly thicker on the feet
Put more space in the temple and extended it
November 3rd 2021
Announced Thok collab design
November 6th 2021
Deskmat samples in and replaced with renders
Added Q in latin kitting
Forgot to update (16 november)
Added Y and Z sublegends in international kitting
Pricing announced
THOK and Captus collab announced
Left: render by me on Ikkie68 by Wuquestudio. the statue is Laocoön and his sons.
Right: Gentlemen65 by jKeys design
Everyone’s monitor displays color differently, the colors in the renders are therefore an estimate.
Of course, blue is blue, but the brightness and saturation may not be completely accurate. But I have tried to make the colors as accurate as possible, but to some it might look slightly different due to their monitor.
I have included these pictures above with the color provided by pantone on their site(which is not accurate) and picture of the pantones in real life
"meander"
Deskmat designed by mooN
The temple you see underneath is the temple of "Hephaestus"
Global/AS: KBDfans
US: Dangkeebs
EU: Keygem
CA: Keyspresso
UK: Prototypist
OCE: Daily Clack
SA: FancyCustoms
India: StacksKB
SEA: Ilumkb
KBD8XMKII by KBDfans
Maja by Vulcan
M60 by Rama Works
U80 by Rama Works
Koyu by Rama Works
Saka68 by CMM.studio
Whimsy by PRKNS
Thanks
There were a lot of people who helped me shape this keycapset.
SpikedSynapse, Sab²er, Cylent, Imperfectlink, MarkTheWeeb, (A)Ducks, ThickJimmy, Cthalupa, Afresh, deserve a special thanks.
To do
Finish and post 2nd deskmat
make renders
apply feedback
find collaborations
make even more renders
Minor kitting changes
Redo renders for improved lighting and color representation
Contact
Discord: biscuit#5472
biscuit.keyboard@gmail.com
If you'd like to show your support for this keycap set, please consider adding this banner to your profile signature.
Code: [Select]
[url=https://geekhack.org/index.php?topic=113732.0][img width=266 height=120]https://i.imgur.com/dajxEM7.png[/img]
« Last Edit: Wed, 29 December 2021, 07:38:54 by Biscuit »
Offline Biscuit
Re: [IC] ePBT Hellas
« Reply #1 on: Fri, 09 July 2021, 09:38:00 »
Hello, I made some updates on the IC.
changed novelties:
Changed the sizing, thickness and fixed some minor issues.
Changed the novelty line color on the blue novelties to alpha color.
Replaced the accent colored novelties on row 4 for mod colored.
Flipped the owl for symmetry for left and right.
Moved the A -TH-E novelties up one,
So A=Row1, TH=Row2, E=Row3.
Moved the Olive Branch to Row 4.
Added renders
Removed the owl from the deskmat and added another pattern at the bottom
More renders coming
In search of collaborations
And sorry for not responding to the geekhack comments
But know I have read them, appreciate it and that I have applied the feedback given combined with the feedback in the IC form.
« Last Edit: Fri, 13 August 2021, 06:18:46 by Biscuit »
Offline Alejo1707
  • Gimme some more caps!
« Reply #2 on: Fri, 09 July 2021, 09:41:50 »
Awww I thought it was gonna be Doom inspired, because of Hellas Basin
Sent from my GM1917 using Tapatalk
Offline growler
« Reply #3 on: Fri, 09 July 2021, 09:49:02 »
Pastel - check
PBT - check
Where do I sign up?
Sent from my SM-G980F using Tapatalk
Don't just stare at it ...
Offline zekth
« Reply #4 on: Fri, 09 July 2021, 09:58:05 »
R3 \| should be alpha colored not mod.
Might be cool to consider adding HHKB bottom row mods: 1.5U CODE x 2 + 1U ALT x 2
Not sure but your novelties might a be too close to the edge of the caps
Offline surplusofchairs
« Reply #5 on: Fri, 09 July 2021, 10:13:03 »
ooh, it’s a more muted/pastel version of epbt kavala clouds + sky. patiently waiting to see more renders  :)
Offline ManoliVisuals
« Reply #6 on: Fri, 09 July 2021, 11:18:07 »
I'm a simple man. I see Greek Themed set, I simp. (Seriously though, fantastic work!)
Offline k4jtek
« Reply #7 on: Fri, 09 July 2021, 11:42:26 »
Usually I don't like Greek themed things but this set looks very cool.
Sent from my Nokia 3310 using Taptalak
Offline andromache
« Reply #8 on: Fri, 09 July 2021, 12:36:54 »
Very pleasant colorway and I'm a fan of the Greek subs. Looking forward to seeing board renders. GLWIC!
Offline growler
« Reply #9 on: Fri, 09 July 2021, 12:57:24 »
I've always been a fan of Greek style
Offline JohnYYZ
  • KanataKeys.co
« Reply #10 on: Fri, 09 July 2021, 14:29:57 »
Beautiful renders!!! GLWIC
Offline cthalupa
« Reply #11 on: Fri, 09 July 2021, 14:33:12 »
Coffee table render is fuego. Great looking set, excited to see it in IC!
Offline Mecxs
« Reply #12 on: Fri, 09 July 2021, 16:49:55 »
That owl is ridiculously cute.
Offline Neely_12
« Reply #13 on: Fri, 09 July 2021, 17:14:20 »
The spacebar kit can be revised a bit. I wouldn't include the off-center bars, since so few people actually need them, and I would change the yellow 3u to white, so you can support layouts like the type k. Also, the base kit would look a lot cleaner if you moved the ISO enters off to the right side to free up a little space in that area. Overall, the colors are nice and simple, and the set is super clean. Good luck!
Offline tsquash
    • SquashKB
« Reply #14 on: Fri, 09 July 2021, 21:31:13 »
cute! glwic
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
« Reply #15 on: Sat, 10 July 2021, 00:47:05 »
Super cute! I was wondering if you could offer an Alphas-only kit with no sublegends?  :thumb:
Offline enomooshiki
« Reply #16 on: Sat, 10 July 2021, 02:10:24 »
very cute colors! good luck with IC!
Offline Arcoril
« Reply #17 on: Sat, 10 July 2021, 14:17:28 »
I tend to prefer more minimal looking alphas so I’d really like to see this too.
Offline Cylent
  • Formerly cylentshadows
« Reply #18 on: Sun, 11 July 2021, 14:03:42 »
We LOVE to see more Greek themed sets, especially sets that are classy too! I enjoyed seeing this set progress, GLWIC!
Offline rowie
« Reply #19 on: Sun, 11 July 2021, 16:18:11 »
Love this set so far. Is there any chance you can make the 1.5u novelties both be that bright cream so that it can look more symmetrically balanced in my bottom row 7u layout (tsangan layout)? Or at least create a demo using the current novelties on a 7u bottom row layout.  Will keep a watch on this thread.
« Last Edit: Sun, 11 July 2021, 16:22:54 by rowie »
Offline GLOVE
« Reply #20 on: Sun, 11 July 2021, 20:41:43 »
Comfortable color scheme
Offline enough
« Reply #21 on: Sun, 18 July 2021, 00:20:06 »
Nice work. Very tidy. Any chance you might be printing a set without the subscript? Regardless, hope you enjoy your break  :)
Offline Biscuit
Re: [IC] ePBT Hellas | New Deskmat/Vendor/Kitting and MORE!
« Reply #22 on: Mon, 02 August 2021, 14:01:13 »
Hey! I have made some updates to the IC.
Offline mattv
« Reply #23 on: Mon, 02 August 2021, 15:32:57 »
Nice blue set. Waiting for the gb  :thumb:
Offline Pyroo
« Reply #24 on: Tue, 03 August 2021, 06:54:14 »
consider having non 5 side dyesub mods in some kit so you can have functional mods
Bunny enthusiast
Offline knowtato
« Reply #25 on: Wed, 04 August 2021, 01:47:27 »
A base kit where the alphas/maybe everything is creamy Pantone 7506U would be very very clean
Offline jungleju1ce
« Reply #26 on: Wed, 04 August 2021, 23:07:16 »
This colour combo looks sick, though I think the old duller blue looks better. Also, is there any chance of an alpha set without the greek letters?
Offline chat and team
« Reply #27 on: Wed, 04 August 2021, 23:40:03 »
I LOVE THE COLORS~ KEVIN
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline Biscuit
Re: [IC] ePBT Hellas | Revised novelties/deskmat and RENDERS!
« Reply #28 on: Wed, 11 August 2021, 12:02:38 »
update message was here first, but is now moved to the top comment.
« Last Edit: Fri, 13 August 2021, 06:20:17 by Biscuit »
Offline Biscuit
Re: [IC] ePBT Hellas | Collabs announced and SEA vendor!
« Reply #29 on: Tue, 17 August 2021, 16:05:25 »
updated,
collabs announced and SEA vendor ilumkb
Offline Mark The Weeb
« Reply #30 on: Sat, 21 August 2021, 14:30:49 »
Hellas=Greece btw
Updates
August 2nd 2021
Changed kitting:
Changed colors:
Deskmats:
Added new deskmat
vendors:
August 11, 2021
Changed novelties:
Added renders
Click this Image
render by me on Iron165 by Smith+Rune
The temple you see underneath is the temple of hephaestus
Global/AS: KBDfans
US: Dangkeebs
EU: Keygem
CA: Keyspresso
UK: Prototypist
OCE: Daily Clack
SA: FancyCustoms
India: StacksKB
SEA: Ilumkb
Koyu by Rama Works
Maja by Vulcan
Collabs
Designs TBD
Thanks
To do
make renders
apply feedback
find collaborations
To do based on feedback
change 2nd tilde to mod
change 2nd pipe R3 to alpha
remove extra Alt Gr
make novelties smaller (further from edge)
Contact
Code: [Select]
I love what your doing with the set dude ! cant wait to pick one up
Offline milka158
« Reply #31 on: Sat, 21 August 2021, 17:56:49 »
I wish you'd keep the sublegends on the international kit.
Offline Biscuit
Re: [IC] ePBT Hellas | More board renders, Updated kitting
« Reply #32 on: Wed, 25 August 2021, 14:18:52 »
more renders and updated kitting
Offline Plurrkeebs
« Reply #33 on: Sat, 04 September 2021, 14:55:13 »
very nice very cool
Offline plomby
« Reply #34 on: Sun, 05 September 2021, 08:10:17 »
absolutely love the colors.
Offline anonympku
« Reply #35 on: Thu, 09 September 2021, 10:23:30 »
Love this set very much! Could you please offer an alpha kit without the Greek letters? Personally I prefer the tradition pure alpha area.
Offline Biscuit
Re: [IC] ePBT Hellas | More board renders and udpated novelties
« Reply #36 on: Sun, 12 September 2021, 06:38:39 »
Updated, more board renders and updated novelties
Offline Biscuit
Re: [IC] ePBT Hellas | GB date announcement-20 Nov
« Reply #37 on: Sun, 03 October 2021, 06:26:42 »
Gb date is 20 november
Offline unni
Re: [IC] ePBT Hellas | GB LIVE ON 20 NOV!
« Reply #38 on: Fri, 22 October 2021, 16:03:08 »
iso-south or itallian kit ?
(i am actually nordic-mac user. interested in 7,8,9,0 keys from italian layout, since 7 and 9 is different in nodic-mac layout than the provided ones in norde kit)
Offline Biscuit
Re: [IC] ePBT Hellas | GB 20 nov. THOK Collab design announced!
« Reply #39 on: Tue, 02 November 2021, 15:28:33 »
THOK update
Offline WhiskyBoi99
« Reply #40 on: Tue, 02 November 2021, 21:09:36 »
This looks great. Have you thought about getting a HIBI artisanal too?
Offline Biscuit
Re: [IC] ePBT Hellas | GB 20 nov. Deskmat Samples In!
« Reply #41 on: Sat, 06 November 2021, 06:29:08 »
Deskmat samples and added Q in in latin kit
Offline Biscuit
« Reply #42 on: Wed, 10 November 2021, 06:00:04 »
Captus design
Offline Biscuit
Re: [IC] ePBT Hellas | GB 20 nov. Pricing announced!
« Reply #43 on: Sat, 13 November 2021, 17:04:16 »
Pricing announced
Offline Biscuit
Re: [IC] ePBT Hellas | GB 20 nov. THOK cable and more pricing
« Reply #44 on: Tue, 16 November 2021, 07:00:15 »
Offline charlieconcarne
« Reply #45 on: Thu, 18 November 2021, 16:54:24 »
Yes, this with GMK civilizations incoming as well. I am set.
Offline Biscuit
Re: [IC] ePBT Hellas | GB TOMORROW! (20 nov, because time zones)
« Reply #46 on: Fri, 19 November 2021, 11:57:13 »
Need that one more post to be able to make a GB post
