Author Topic: [IC] GMK Pickle  (Read 48441 times)
Offline saam
[IC] GMK Pickle
« on: Sun, 11 July 2021, 09:56:20 »
You are sitting at a picnic bench waiting for your deli sandwich to be delivered. It is a hot July day and you’re enjoying a chilled bottle of pop. Then, suddenly you see your order come around. A plate with a wax-wrapped sandwich cut in half, glistening in the sun as it’s brought to you. It’s placed on the table. A deli sandwich, a plate of fries, and a pickle spear right between. The dill and vinegar smell takes over, wafts of the deli sandwich with its fresh bread and accompanied fries join in. It’s a cacophony of tingling delights. You grab the pickle spear, take a bite.... crunch....... Perfection. Now you can evoke this feeling every day at your desk without worrying about crumbs in your
board.
Presenting... GMK Pickle
Kits:
Explanation of the kitting: The kitting is meant to be basic, easy to understand, and easy to pick what you need (ahem, you need all of the kits). We support the more popular 40's, ISO, and ANSI, all in the base kit! I have chosen the spacebars kit to clean up Alice and to support some other spacebar needs. The novelties were kitted in a way that made sense to me, I know right.
Base kit
Novelties kit
Spacebars Kit
Board renders:
Amano by h40
Charon by Charue Design
F1-8x by Geonworks
Gherkin by Rogue_Jellybean
U80 by ramaworks
Maja Vulcan X KBDFans
Deskmats:
Comparison Chart:
To do list: Collaborations, Find Vendors, Possibly more renders, Improve Kitting
More renders of the boards with different colors and angles can be found here: GMK Pickle Full Render Gallery
I hope you all enjoy it as much as I do!
A very special thanks to the following:
Thatsdho and Stwabee for the renders and graphic design work, great job!
Krugerlive for helping me with kitting, advice, writing IC, and so much more that I cannot fit in this.
This keyset would not be in such tip top shape without you. Thank you so much Kruger!
DotMatrix for the help with kitting and formatting the IC.
The CK regulars, for listening to my long boring messages about a set they do not care much about.
Steve_Laroo for help with kitting the 40's.
Arydz for help with polishing up the IC and my horrible grammar.
IC Feedback Form: IC Form
It would be great for y'all to fill this out! I will read all of them individually and take notes, I will do my best to see what is wanted the most! Thank you.
Thanks for checking this out, have a great rest of your day/ night.
Stay crunchy!
« Last Edit: Mon, 12 July 2021, 13:55:04 by saam »
Sam E
Offline saam
Re: [IC] GMK Pickle
« Reply #1 on: Sun, 11 July 2021, 09:57:03 »
Upcoming changes to kitting gained from feedback:
-Removing accent keys in base kit.
-Adding 1u R3 pipe key, 1u tilde key, and a short left shift for ISO.
-Will be looking into adding 1.5u novelties, my silly brain forgot, smh.
-The 3 keys for 40's support will be the following: R3 1.25 tab, R3 1.5 enter, and R2 1.75 Backspace..
-40's kit's will be icon, not text/icon, keeping in line with the base kit.
- Adding alternate alphas. The color of the alternate alphas is the current mod color.
Thanks to Panda and Riker for the amazing feedback
More feedback will be added here, keep it coming!
(Renders were resized, sorry about the previous sizing.)
« Last Edit: Tue, 13 July 2021, 20:40:46 by saam »
Sam E
Offline Yuinth
Re: [IC] GMK Pickle
« Reply #2 on: Sun, 11 July 2021, 10:13:17 »
Didn't think I would like a pickle themed set. Can't wait for the collabs.
Now I'm hungry.
GLWIC & GB.
Offline gypsyunit
Re: [IC] GMK Pickle
« Reply #3 on: Sun, 11 July 2021, 10:16:46 »
Looks good, GLWIC
Offline ad4m
Re: [IC] GMK Pickle
« Reply #4 on: Sun, 11 July 2021, 10:18:13 »
glwic, i was working on a cucumber set too, unfortunately hard drive died on me with no backups
anyways, i like cucumbers, so i like this set
Offline doggo1dance
Re: [IC] GMK Pickle
« Reply #5 on: Sun, 11 July 2021, 10:38:32 »
pickle rick
Offline not tj
Re: [IC] GMK Pickle
« Reply #6 on: Sun, 11 July 2021, 10:51:21 »
FINALLYYYYYY POGGGG
Offline krugerlive
Re: [IC] GMK Pickle
« Reply #7 on: Sun, 11 July 2021, 11:36:15 »
Yes!!  It is finally pickle time.
This set could not be more pickle, I love it.
Offline heyimpanda
Re: [IC] GMK Pickle
« Reply #8 on: Sun, 11 July 2021, 11:46:59 »
nice work sam
- base 40s support has text + icon backspace and enter but the rest of the set is icon mods?
- are the 'accent' enter & esc supposed to be alpha colored?
- consider 2x 3u spacebars in spacebar kit
- ne f13 avail nvm it's to the right of the 65 mods
- please consider compressing the images
- why is there a shift next to the stepped caps, is this supposed to be control? or is this some 40s thing I'm not familiar with
glwic :)
« Last Edit: Sun, 11 July 2021, 11:58:22 by heyimpanda »
Offline LittleAad
  • Hello
Re: [IC] GMK Pickle
« Reply #9 on: Sun, 11 July 2021, 11:48:15 »
your kitting is a bit wonky... you have alpha colored "accents" and you dont have proper terminal iso support. That pickle jar novelty may have trouble with spec with the small gaps it has.
1.5u novelties would be cool to see. GLWIC
Offline Armyofkeyboards
    • www.armyofkeyboards.com
Re: [IC] GMK Pickle
« Reply #10 on: Sun, 11 July 2021, 11:49:15 »
I like pickles. GLWIC
Offline Senpai_deezy
Re: [IC] GMK Pickle
« Reply #11 on: Sun, 11 July 2021, 11:55:16 »
glwic, would like to see a bit nicer renders and something like a dark green case for this set to shine. Good work
Offline treeleaf64
    • treeleaf64
Re: [IC] GMK Pickle
« Reply #12 on: Sun, 11 July 2021, 12:51:51 »
The treeleaf and the  Pickle
 There is one thing they have in common
We are both green
Yay!
Everyone must pay the cat tax
Offline Benchiridion
Re: [IC] GMK Pickle
« Reply #13 on: Sun, 11 July 2021, 13:24:55 »
I enjoy this a lot
Offline h40
    • h40.io
Re: [IC] GMK Pickle
« Reply #14 on: Sun, 11 July 2021, 13:55:50 »
I would like to see this actually on Amano, not just rendered. GLWIC.
Offline Cylent
  • Formerly cylentshadows
Re: [IC] GMK Pickle
« Reply #15 on: Sun, 11 July 2021, 14:01:49 »
I appreciate the amount of effort and professional renders put into this set, but I just can't get behind the alpha color, it looks like that one time I chugged a Rockstar energy drink and peed light green.
Offline rikercd
Re: [IC] GMK Pickle
« Reply #16 on: Sun, 11 July 2021, 14:21:08 »
nice work sam
glwic :)
I have said this before but I'll put it here for posterity:
"Accent" colored escape and enter keys don't make a whole lot of sense for a set with no accent colors. I'd personally prefer to see the 40s support expanded in favor of those two keys.
Couple of additional notes from myself:
  • With no accent color, the spacebar kit might be too niche to meet a large MOQ
  • ISO layout needs a 1u R3 pipe key, also typically has a 1u tilde key and a short left shift
  • Missing 1.5u novelty mods
  • 40s support might need a little work. Coral has 2 different 1u tab keys, a 1.25u tab key, short enter kits in multiple sizes, etc.
  • Seconding panda on the 40s mods. Backspace and enter keys are inconsistent with the base kit
Nice work Sam, this set works really well and I think it will be successful if you work out the minor kitting issues.
Offline mymeepo
Re: [IC] GMK Pickle
« Reply #17 on: Sun, 11 July 2021, 14:42:21 »
Your description of the inspiration was cute. Made me laugh. GLWIC
Offline honorless
Re: [IC] GMK Pickle
« Reply #18 on: Sun, 11 July 2021, 16:55:01 »
...Shout-outs to the Gherkin render with the big bezel alu case lmfao. Did your renderer design that?
Those three 40s keys should be a R2 1.75u Backspace, an R3 1.25u Tab, and an R3 1.5u Enter. They...do not appear to be that size in your render.
Normally "4-key ISO" is ISO Enter, R4 1.25u Shift, R3 1u |\, and R4 1u <>; no tilde involved.
Having two "macro columns" in your novelty kit is rather nice for ortho and colstag boards, since this is likely too niche of a set to support a standalone ortho/40s kit. But I do wonder if there are enough pickle enthusiasts out there to support such a kit at all.
Out of curiosity, are the 1.25u novs dilly beans?
Offline hkf
  • your #1 fan
Re: [IC] GMK Pickle
« Reply #19 on: Sun, 11 July 2021, 17:11:23 »
Most of the real comments have been said already, but I have a few alternative considerations:
  • Colour comparisons for your colours next to the other ones, its quite hard to do real comparisons
  • B in base kit. It's a small concession for those that don't get the space kit (or the space kit does not meet moq, as mentioned above)
  • 2u numpad alt colours are superfluous at best. Any consideration for a 2u numpad novelty instead?
  • It bears mentioning AGAIN because this is a real problem, please consider image compression:
Can you find an example of this? Most 4 key ISO support I've seen includes a R3 ~#.
Offline honorless
Re: [IC] GMK Pickle
« Reply #20 on: Sun, 11 July 2021, 18:10:47 »
...Agreed that you need to make the images smaller too, m8.
Sure. For brevity's sake I'll stop at ten:
  • Analog Dreams R2
  • Arch
  • Handarbeit R2
  • Hazakura
  • Lavender
  • Lazurite
  • Moonlight
  • Parcel
  • Wasabi R2
  • Zooted
Maybe you're thinking of UK-ISO, which is also a common approach, but requires more than four keys.
Offline hkf
  • your #1 fan
Re: [IC] GMK Pickle
« Reply #21 on: Sun, 11 July 2021, 18:54:55 »
  • Analog Dreams R2
  • Arch
  • Handarbeit R2
  • Hazakura
  • Lavender
  • Lazurite
  • Moonlight
  • Parcel
  • Wasabi R2
  • Zooted
Yes, I am thinking of UK-ISO. My bad, not as cultured :(
Offline Olyz
Re: [IC] GMK Pickle
« Reply #22 on: Sun, 11 July 2021, 19:40:11 »
look good. I actually see the theme in the base set.
Offline Pickleguy
Re: [IC] GMK Pickle
« Reply #23 on: Sun, 11 July 2021, 20:28:24 »
OH MY GOD YES!!!!!!!
Offline Brioric
Re: [IC] GMK Pickle
« Reply #24 on: Sun, 11 July 2021, 22:24:23 »
Nice set, makes me want to eat a jar
« Last Edit: Sun, 11 July 2021, 22:26:17 by Brioric »
Offline paperassgasket
Re: [IC] GMK Pickle
« Reply #25 on: Sun, 11 July 2021, 22:33:16 »
Love seeing 3-key 40's in base, it's kind of a big dill.
Please consider dual 3u spacebars at least in the spacebar kit.
Offline Lazesummerstone
  • ҠѤӋϚΔΡѕ
    • MY Keycap set - Transmutation
Re: [IC] GMK Pickle
« Reply #26 on: Sun, 11 July 2021, 22:35:56 »
I feel like as a kid I hated pickles but as I've gotten older they've really grown on me. Now that there's finally a keyset to go along with my newfound appreciation for pickles I am so happy. This is truly a set for the refined, mature individual.  :cool:
Offline saam
Re: [IC] GMK Pickle
« Reply #27 on: Sun, 11 July 2021, 23:11:10 »
Hey! We will be adding 2x 3u spacebars, thanks for the feedback.
Sam E
Offline HappyB0T
  • I'm a Piggie
Re: [IC] GMK Pickle
« Reply #28 on: Sun, 11 July 2021, 23:11:44 »
No long dark green spacebars ? That is the most pickle looking key :'|
Offline saam
Re: [IC] GMK Pickle
« Reply #29 on: Sun, 11 July 2021, 23:38:35 »
Hey! I totally see what you are saying, and I will totally look more into it.  I just personally did not like the way it looked, it just looked off. I will try and check it out more, but honestly I do not see it being included.  :(
Sam E
Offline HappyB0T
  • I'm a Piggie
Re: [IC] GMK Pickle
« Reply #30 on: Mon, 12 July 2021, 00:48:22 »
The set = a pickle not one key :D
If the space was dark green then it would just look like the mods and it wouldn't look like a pickle. I see what you mean.
Light monochrome alphas / mods with Dark Esc + Enter + Arrows + Space would work but uh that isn't what you rendered and probably doesn't look as good anyhow. BUT the space would look like a pickle.
Offline Kokaloo
  • 🤘(• ω •)🤙
Re: [IC] GMK Pickle
« Reply #31 on: Mon, 12 July 2021, 01:33:52 »
too many sams
Offline Izeri
Re: [IC] GMK Pickle
« Reply #32 on: Mon, 12 July 2021, 04:03:47 »
Agree, the problem are kit images being 16000 x 9000.
Offline question Mark
Re: [IC] GMK Pickle
« Reply #33 on: Mon, 12 July 2021, 04:26:35 »
You can find the case with big bezels on Thingiverse, if you search for Gherkin cases.
Offline saam
Re: [IC] GMK Pickle
« Reply #34 on: Mon, 12 July 2021, 09:15:23 »
Got it, I will be compressing all images and updating it sometime today.
Sorry about that...
Sam E
Offline mymeepo
Re: [IC] GMK Pickle
« Reply #35 on: Mon, 12 July 2021, 09:55:11 »
I agree that the big ass spacebar that has the color of a literal pickle is essential here. You can just add it to the spacebar kit
Offline saam
Re: [IC] GMK Pickle
« Reply #36 on: Mon, 12 July 2021, 12:25:22 »
Noted, now that I am seeing more interest, I will try and fit it in there. The spacebar kit is being redone.
Sam E
Offline Arithmetics
Re: [IC] GMK Pickle
« Reply #37 on: Mon, 12 July 2021, 13:47:25 »
 I turned a GMK set into a pickle, Morty! Boom! Big reveal: It's a pickle. What do you think about that? I turned a GMK set into a pickle! W-what are you just staring at me for, bro. I turned it into a pickle, Morty!
Offline k4jtek
Re: [IC] GMK Pickle
« Reply #38 on: Mon, 12 July 2021, 15:31:01 »
Not really like this set, but I appreciate the idea so much. Good luck with it!
Offline mymeepo
Re: [IC] GMK Pickle
« Reply #39 on: Mon, 12 July 2021, 15:46:43 »
OP also deserves praise for the quality of the IC
Offline arydz
Re: [IC] GMK Pickle
« Reply #40 on: Mon, 12 July 2021, 23:24:12 »
amazing job sam, super proud of you! some edits I would make:
- fix the legends on the 3 40% compatible key to be icon, not icon/text
- remove the accent keys as they match w/ alphas
- add ISO left shift
- add R3 pipe
- add alpha colored tilde
« Last Edit: Mon, 12 July 2021, 23:29:56 by arydz »
Offline HappyB0T
  • I'm a Piggie
Re: [IC] GMK Pickle
« Reply #41 on: Mon, 12 July 2021, 23:28:14 »
Imagine selling 2 spacebar kits to someone just so they can put all of them in a real but clean pickle-jar just to meme. I think your efforts will be rewarded.
Offline HappyB0T
  • I'm a Piggie
Re: [IC] GMK Pickle
« Reply #42 on: Mon, 12 July 2021, 23:29:45 »
Imagine selling 2 spacebar kits to someone just so they can put all of them in a real but clean pickle-jar just to meme. I think your efforts will be rewarded. Hey 7u and 6u spacebars - you now have a home :D
Offline powwu
    • Discord
Re: [IC] GMK Pickle
« Reply #43 on: Tue, 13 July 2021, 19:05:24 »
gherkin is the only valid board for this to be on
...and maybe frog too we'll see
Offline saam
Re: [IC] GMK Pickle
« Reply #44 on: Tue, 13 July 2021, 20:14:29 »
Now I am trying my absolute hardest to get a green frog!
Sam E
Offline cherpalla
Re: [IC] GMK Pickle
« Reply #45 on: Tue, 13 July 2021, 20:47:43 »
Some bumpy membrane accent keys would be kinda cool for this
c h e r
Offline Ustinj
Re: [IC] GMK Pickle
« Reply #46 on: Tue, 13 July 2021, 22:02:40 »
colors are very reminiscent of a pickle, nice picking
Offline KKoNaM
Re: [IC] GMK Pickle
« Reply #47 on: Tue, 13 July 2021, 22:37:28 »
nuts
Offline Mark The Weeb
Re: [IC] GMK Pickle
« Reply #48 on: Fri, 16 July 2021, 12:05:57 »
Love the amount of effort youve put int this ! renders are top notch ! Personaly it is not my thing i feel like the apha colour is slightly too "neon" :thumb:
Offline qwuzzy
Re: [IC] GMK Pickle
« Reply #49 on: Fri, 16 July 2021, 19:15:36 »
Never thought I'd see a keycap set that I could define as revolting.
