Author Topic: [GB] Orange Boy Ergo - Budget Alice-like DIY Kit  (Read 9445 times)
Offline MechWild
« on: Fri, 16 July 2021, 09:42:30 »
MechWild Site
MechWild Discord
GB Dates: 12PM ET July 16th - August 8th
Fulfillment: Expected to start early October.
Vendor: Mechwild
The Orange Boy Ergo (aka OBE) is our take on a super budget ergo / Alice-like kit. Not everyone has hundreds of dollars to spend on something they might not enjoy. We went with a layout that includes arrow keys since most people need them. There’s also 3 macro keys on the left hand side but you could have a knob and 2 macro keys instead.
A couple top views
And a bottom view
If you’re familiar with our previous products, you won’t be surprised that this is yet another through hole kit. The biggest difference as far as the component list goes will be the BlackPill. The BlackPill is a very affordable dev board option that supports USB-C from the start and its installation is essentially identical to more common dev boards such as the Pro Micro.
In the interest of keeping this kit as cheap as possible, we’re making some parts optional. The base kit will start at $40 and there will be several add-ons offered. The OBE is designed to be used without a switch plate (we recommend using 5-pin switches in general), but we are also offering a switch plate for an additional cost. We’re also not including a knob and encoder in the base kit, but those are available to add onto the kit as well.
    Base kit contents:
    • Black Pill dev board
    • EEPROM + resistors
    • PCB
    • Bottom Plate
    • Diodes
    • Status LEDs + resistors
    • Standoffs
    • Screws
    • Rubber Bumpons (feet)
      Features:
      • MX Switch support
      • USB Type-C
      • QMK/VIA/VIAL support
      • Optional encoder
      • Status LEDs (Num Lock + Caps Lock)
      • RGB LED strip headers
      • Aluminum feet cutouts
      • Reversible bottom plate
      The OBE has a few layout options, not too many. You can do a giant right shift and/or split backspace.
      « Last Edit: Fri, 16 July 2021, 10:37:56 by MechWild »
      Re: [GB] Orange Boy Ergo - Budget Alice-like DIY Kit
      « Reply #1 on: Mon, 19 July 2021, 10:56:32 »
      Approved :thumb:
      Offline EdgeOfInfinity
      « Reply #2 on: Fri, 23 July 2021, 00:19:36 »
      ready to try my 1st ergo
      Offline Bluerooster
      « Reply #3 on: Wed, 28 July 2021, 03:35:14 »
      That's a beautiful board, will it be possible to have the DXF files, or at least the KLE raw data?
      I'd would love to make a case for this keeb :)
      Inviato dal mio ONEPLUS A5010 utilizzando Tapatalk
      Offline wowaweewa
      « Reply #4 on: Wed, 28 July 2021, 05:07:41 »
      Rotary knob and arrow keys on an Alice layout...awesome!
      Offline deviant324
      « Reply #5 on: Wed, 28 July 2021, 20:32:06 »
      About to get my order fixed
      Will there be a build guide for the board or will there not be anything more going on beyond soldering on your switches/hotswap sockets?
      Offline MechWild
      « Reply #6 on: Thu, 29 July 2021, 21:13:05 »
      Yes, there will be a build guide posted when we're ready to start shipping units out.
      We've got plate files for all of our products right here: https://github.com/MechWild/public-design-files
      Offline FreeCopy
      « Reply #7 on: Fri, 08 October 2021, 23:21:47 »
      Mine came in today. Going through the build guide now. Had to get after it a few tries to get the Pill working but it's on it's way. Thanks!
      Keyboards
      Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
