Author Topic: [IC] ePBT Ping | GB LIVE!!!!  (Read 107121 times)
Offline Plopmk
  • Plop Laboratories | Making atrocious keycap sets
    • plopmkd@gmail.com
Re: [IC] ePBT Ping | GB LIVE!!!!
« Reply #50 on: Wed, 17 November 2021, 07:34:42 »
DailyClack will go live Promptly
Offline Plopmk
    • plopmkd@gmail.com
Re: [IC] ePBT Ping | Patch v1.1
« Reply #51 on: Wed, 17 November 2021, 08:17:01 »
Reminds me a lot of bento. but i like the work you have done on the novelties and design, not so much the colors
You're probably thinking of Olivia
Offline kajahtaa
« Reply #52 on: Wed, 17 November 2021, 17:42:17 »
Nomad will have 3 1u R4 return?
Offline tigerali
« Reply #53 on: Thu, 18 November 2021, 14:20:37 »
Can someone help me figure out what sets I'd need for the ergodox?
Offline puddingfarmer
« Reply #54 on: Thu, 18 November 2021, 14:31:06 »
Are the row numbers correct in the "nomad" kit? That's a lot of R4
Offline Plopmk
    • plopmkd@gmail.com
« Reply #55 on: Thu, 18 November 2021, 22:48:51 »
That was a typo, I just fixed it earlier today and should hopefully be updated on the vendors' site by now
« Reply #56 on: Fri, 19 November 2021, 14:47:51 »
Fantastic; thank you!
« Reply #57 on: Fri, 19 November 2021, 16:34:55 »
This layout?
You need a lot of 1.5 and 2u caps and there are no 1.5u in row 1 profile in this set.  That said there are 6xRow 4 and 2xRow 2 1.5u in the Base kit so you could use 2 of them on Row 1, it would just feel weird.  There are 2 row 3 1.5u in the Nomad kit, so you could buy 2xNomad kit to have enough 1.5us.  Then in base there are shift and backspace caps to cover 2x2u, and you would need either Num kit or Minibars to cover the other 2.  The bottom row 1us could be covered between Base and Minibars, I have no idea what profile you want on the thumb keys but you have plenty of 1us left in the base.
So Base, Minibars, and 2x Nomad should cover it.
Personally I would look for another set with an Ergodox kit or a lot of blanks as sideways legends and mismatched profiles would annoy me but it's your board :thumb:
Offline hiddensong
  • this too shall pass
« Reply #58 on: Sat, 27 November 2021, 23:58:28 »
Gorgeous set. No stepped ctrl or F13 makes it a pass for me, alas. Great colors though. perfect blue and red shades, Kudos, indeed!
Offline antsinyourpants
« Reply #59 on: Thu, 02 December 2021, 10:36:37 »
Only two hours of sobbing?
Love the set! Eagerly waiting for RamenStop to arrive :)
Offline niakulah
« Reply #60 on: Sun, 12 December 2021, 23:08:48 »
Can we get an R3 1u backlash/pipe in the ISO kit please?
Plop listened! I had no choice but to buy. RIP this month's budget.
