Author Topic: Unocomp Customizer 103  (Read 2625 times)
Offline RamaBot
« on: Fri, 27 August 2010, 19:56:19 »
Just got myself a new Customizer 103 after the death of my Model M.
It feels like a model M but more so.
It took less than 48 hours to ship from the states to my hovel in the UK.
It has a lovely sound. Like the model M but without the ringing.
It has 2 part keycaps.
It is lovely.
After the death of my model M I bought a cherry g80-3000 to try out the blue cherries. They are not for me.
Even thought he cherry is a quality keyboard it was too lightweight for me.
The keys had a sort of puny feel to them. Like crushing little beetles.
« Reply #1 on: Fri, 27 August 2010, 20:02:21 »
Just curious in case I have to import a new Unicomp to the Netherlands: how much did you pay for shipping and dues and taxes?
Also: I understand the appeal of the Model M; it's definitely in my top 2 boards, but my quest recently was for lower force switches and smaller size.
« Last Edit: Fri, 27 August 2010, 20:04:23 by Superfluous Parentheses »
Current collection: HHKB Pro 2 black on black, HHKB Pro 2 white/grey blank, [strike]Dell AT101W[/strike] (sold to SirClickAlot), 1992 Model M, Key Tronic Ergoforce KT 2001, BTC 5100 C. Dead boards: MS Natural Elite, MS Natural 4000.
Offline ironman31
« Reply #2 on: Fri, 27 August 2010, 20:20:56 »
Quote from: RamaBot;217478
It is lovely.
Exactly what happened to your model m? Do they ever just die from old age? aside from plastic rivets breaking
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/AT,  Noppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
Offline RamaBot
« Reply #3 on: Sat, 28 August 2010, 04:12:48 »
Shipping was $43 using Fed-EX. I have no idea about the taxes yet
A couple of keys started to be a intermittent. Then one stopped working alltogether.
I tried a few things to fix it but no go. I will always keep it for the memories and the parts.
Offline ch_123
« Reply #4 on: Sat, 28 August 2010, 05:12:15 »
If you are prepared to rip open the old Model M you can fix the broken keys easily enough, and the ping will go away. You can also fix the spring tension while you are at it if you order new ones from Unicomp.
Offline RamaBot
« Reply #5 on: Sat, 28 August 2010, 11:02:41 »
Quote from: ch_123;217564
I have had it apart a couple of times to re-furbish it. I have also swapped the springs and keycaps around to see if that made any difference. It didn't.
I think I will just have to leave it alone for a while now so the wife doesn't go ape**** about me buying a new unicomp when I could have fixed the model M.
I will have a go at it in a few weeks. Then if I fix it I will have two lovely keyboards.
Offline ch_123
« Reply #6 on: Sat, 28 August 2010, 12:40:55 »
Experience shows that the contacts on the cable that links the membrane to the controller are a common point of failure. If you get a silver gel PCB trace repair pen, and 'draw' a new trace from the membrane to the contact, you'll get the thing working again.
Whilst not as reliable as other contact mechanisms, membranes make it up for it by being ridiculously easy to fix if they die.
Offline RamaBot
« Reply #7 on: Sat, 28 August 2010, 13:07:55 »
Quote from: ch_123;217620
Thanks very much for that tip. That's one I'd never heard before. I will, without doubt try it out.
Offline ch_123
« Reply #8 on: Sat, 28 August 2010, 13:48:39 »
I used this one to fix two different IBMs. I may/may not get around to posting up a guide at some point... If I don't, let me know and I'll give you some pointers.
