Author Topic: Djinni Series MCU Boards - M.2 Swappable MCU Board for easy Design/Upgrades  (Read 4356 times)
Offline King Icewind
    • Keys of Kings
IMGUR Link
The Green Djinni is the first board of a series of Djinni MCU boards designed for
-Easier and quicker designing of keyboard PCBs
-Reduced BOM for keyboard PCBs
-Upgradeability
—Nearly every PCB can be upgraded to a new Djinni such as a Blue Djinni (Bluetooth; board is near completion), or Red Djinni (more flash memory) along with future versions
-Reparability
-Various M2 connector heights allow either fairly low profile keyboards or use with MX/Choc hot swap connectors
-Works with Kailh Choc and MX key spacing
Just to note: these were ordered from Oshpark, hence the purple board. Production versions PCB colors will be the same as the name (Green Djinni = Green board, Blue Djinni = Blue board)
I still need to assemble these and do initial testing. I have three different keyboards designed that will utilize the Djinni. So, I am excited to begin testing.
Green Djinni specs:
Microcontroller: STM32F302RBTx - Cortex M4 72mHz
Flash: 128KB
I/O pins: Max 45
3.3V Regulator along with 3.3v out to mainboard
Piezo Buzzer
I will post back with future updates or to answer posts.
Additionally, I have a separate series of boards that also utilizes a M2 connector for RGB controllers. These boards have the same benefits and dimensions of board as the Djinni Series. The board is designed but waiting on a prototype to arrive. More info on that soon.
« Last Edit: Sat, 24 July 2021, 12:35:44 by King Icewind »
Offline nevin
Sounds wondeful!
Will keep an eye on this project.
