Author Topic: [IC]DSYK--Lumberjacks---GB Began  (Read 10741 times)
Offline kakasa
« on: Sun, 25 July 2021, 09:45:50 »
Intro
Hi,Geekhack, I had visited geekhack for a while time.After seeing so many design for keycap,as  fan of keycaps ,i also wanto to share with your guys.My design keycap.
We hope you like this set and we would be happy to read your opinion in the form below
Inspiration
Wood & lumberjacks
Inspired by the dangerous but meaningful work of traditional lumberjacks.
Color Pallet
Kit
Base(134 key):
Numpad(25 key):
Novelties(35 key):
Accent(25 key):
Space1(11 key):
Space2(11 key):
A complete set of above all support:
•MX HHKB, 60%, 65% (With 1.75u Shift,2u Shift)
•75%
•80%
•96/980
•104 keys
•Support WKL
•Split Backspace
•Split Spacebar(2u, 2.75u, 2.25u)
•Alice
•Extra B (Alice)
•Extra 2.25u Shift (660 Support)
•Dark yellow:ESC, Enter intersperse
Renders
Sample
Deskmat
900*400*4mm
Cloth cover, Rubber Back, Overlock
lumberjack deskmat
logging deskmat
lumberjack deskmat
Collabs
Resin Keycap
Metal Keycap
Social
Feel free to join the:Discord
Any suggestion,please fil IC Form
GB Date/Timeline
Dec 21,2021 ---Jan 21,2022
Vendors
US-boardsoure.xyz
UK-KeebCats
SEA-Hex Keyboards
Pricing
To Do List
Gather feedbacks about that design and colourway
Work on render
Pubilsh Deskmat design and collect feedbacks
Collaborations
Actually get a vendor
Get Samples,Announce Pricing,Fix a Group Buy Date
hi,geekhack,thanks drunken,Mr Chrome for comments about that design and colour.
If you'd like to show some support for this keycap set, please consider adding this banner to your profile signature
Code: [Select]
[url=https://geekhack.org/index.php?topic=113959.msg3071296#msg3071296][img width=319 height=120]https://mochong.oss-cn-shenzhen.aliyuncs.com/item/m1-0010/signature1.png[/img][/url]
« Last Edit: Wed, 22 December 2021, 06:27:16 by kakasa »
Offline drunken_sailor
  • I'm from KeebCats!
    • KeebCats
Re: [IC]DSYK-- Wood & lumberjacks
« Reply #1 on: Sun, 25 July 2021, 10:23:31 »
I love the idea! Some of the novs seem to have strangely thin lines compared to the others. And please... full UK-ISO! GLWIC :)
Offline kakasa
« Reply #2 on: Sun, 25 July 2021, 11:01:26 »
lines? where?
    • KeebCats
« Reply #3 on: Sun, 25 July 2021, 13:57:26 »
lines? where?
The stroke weight of some of the novelties; they all seem to differ and it looks a little jarring to me.
Offline Havattack
« Reply #4 on: Sun, 25 July 2021, 17:58:15 »
I'm not feeling the modifier colors. Making them the same colors as the alphas, or swapping the accent  colors with the mod colors would be a better option. (I's say the former, but i like mono sets.)
Offline kakasa
« Reply #5 on: Sun, 25 July 2021, 19:26:13 »
lines? where?
ok i will adjust that design.
Offline kakasa
« Reply #6 on: Sun, 25 July 2021, 19:39:25 »
yes, i will consider to change colour as your adviced
Offline HappyB0T
  • I'm a Piggie
« Reply #7 on: Sun, 25 July 2021, 19:43:22 »
lines? where?
+1 for the line weight consistency. The actual designs themselves work.
Offline sup3r170va
« Reply #8 on: Sun, 25 July 2021, 22:44:19 »
i like the colour scheme. pls consider GMK.
Offline Havattack
« Reply #9 on: Tue, 27 July 2021, 15:39:33 »
Please do NOT consider GMK. Other then the stupid wait times, they are a company with stupid polices. (Suck it Mito)
Offline kakasa
« Reply #10 on: Wed, 28 July 2021, 07:44:45 »
yes GMK waitting time is too long already
Offline juniper37559
« Reply #11 on: Wed, 28 July 2021, 12:19:01 »
The colorway is good for dyesub pbt. Only one side will be dyesub. Please consider some new pbt manus that has pretty decent leadtime. If you want double shot abs/pbt, please give domikey or wuque studio a try. We need more manus to compete with gmk and epbt.
Offline Mr Chrome
« Reply #12 on: Wed, 28 July 2021, 15:56:22 »
The soft brown and white is actually a very nice colour combo, reminds me of minimalist interior design. The renders need work (why is the accent brown in the board renders different to the pantone?) but it’s a promising start.
But I think the novelties need a complete overhaul. All of them seem like a different art style altogether. It looks like you found free icons and put them all to use. Maybe take a look at sets that have very consistent novelty styles? (e.g. Stargaze)
I like the tree-ring cap, though.
“This plastic rectangle is alright. The plastic rectangles on top of it, though...”
Offline kakasa
« Reply #13 on: Fri, 30 July 2021, 00:13:15 »
Firstly,that colour about accent is still in considering, I am not sure Brown colour or before colour is better,but as for my i perfer that brown.
Seconedly,I will try to consider to change noveltives design, Maximally takeing set with consistent stlyle.
 thanks for your suggestion.
Offline NS.Greenie
Re: [IC]DSYK-- Wood & lumberjacks---NEW RENDER AND DESKMAT UPDATE
« Reply #14 on: Sun, 08 August 2021, 00:58:19 »
I like the colour scheme, but want to make sure that the real thing is consistent with the rendering.
Offline MILKYWAY KEYS
  • PBT keycap manufacturer
    • MilkywayKeys
« Reply #15 on: Tue, 10 August 2021, 04:58:27 »
It looks good!
