Author Topic: I'm looking for a specific keycap theme but can't find it, please help!  (Read 4586 times)
Offline L3w1ss
Hey guys!
I'm quite new to the Mechanical keyboard community, and I'm building my own keyboard for the first time.
I've got everything for the keyboard,
my case is going to be a KDBfans Tofu 60% Deep purple,
my PCB is going to be a DZ60 Rev 3.0 60%,
the foam is going to be delivered with the PCB,
The plate is going to be a DZ60 CNC Aluminium/Brass (I don't really know what are the pros and cons of each, so I'll do that research later)
The switches are going to be basic Cherry Mx Browns, should I get some different ones for my spacebar, shift etc.. ?
My stabilisers are just PCB mounted cherry stabilisers,
and my Cable is going to be a KBDfans purple handmade USB cable
but here is where i'm stuck, I can't find good keycaps that fit what I want to do.
the attachment is what i'd love to find, but I've been searching for a good amount of time and cannot find keycaps like that, that aren't retired or sold out and are going to be back in half a year.
Does any one have some magical keycap sites for a European like me?
Thanks for any help provided, it helps a ton!
P.S. I'm French so sorry if I miss-wrote anything x)
Offline Faceman76
Amazon has generic PBT caps in various colors.  For this you'll need two sets.
Sent from my SM-G975U using Tapatalk
1800s and heavy springs
Offline kevinthemighty
Re: I'm looking for a specific keycap theme but can't find it, please help!
« Reply #2 on: Mon, 02 August 2021, 23:04:48 »
Dang, Drop just released their Drop+Marvel Black Panther keycaps, but it looks like the inverse of what you're looking for. Tough break.
Offline Volny
« Reply #3 on: Tue, 10 August 2021, 05:59:16 »
If you like the DSA (uniform) or SA (non-uniform, very tall) profiles, then try pimpmykeyboard.com. There you can buy sets in all sorts of different colors. For example you could order black alphas and purple modifier keys.
