Author Topic: [IC] Dino104 | GB September 14th  (Read 54203 times)
Offline granola bar enthusiast
Re: [IC] Dino104 | Finalizing IC
« Reply #100 on: Wed, 04 May 2022, 14:15:13 »
10u spacebar is going to be amazing, pretty cool design
Offline paperassgasket
« Reply #101 on: Tue, 24 May 2022, 16:32:21 »
I agree.
Chonky bar for a chonky board seems appropriate.
Offline LegendsWorks
  • thocc
« Reply #102 on: Tue, 24 May 2022, 18:10:33 »
ok but does it thocc
Offline nFaiz
« Reply #103 on: Fri, 26 August 2022, 00:35:36 »
The gb will start september 14th. nKeys.mx is the new NA vendor.
Offline BRSxIgnition
Re: [IC] Dino104 | GB September 14th
« Reply #104 on: Fri, 26 August 2022, 13:39:07 »
I assume no hotswap option?
Offline Handke
« Reply #105 on: Fri, 21 October 2022, 02:24:36 »
poly of flexible plate available?
Offline diqkiq
« Reply #106 on: Sat, 22 October 2022, 23:02:31 »
Interested
Sent from my Pixel 6 Pro using Tapatalk
Filco Majestouch TKL, Noppoo Choc Mini, Realforce 87 55g, Model M TKL, Ducky Shine 3 TKL, KC60, Planck.
Offline arr1
  • Ñ supporter
« Reply #107 on: Thu, 27 October 2022, 16:00:59 »
Good work. If only I was into full sized keyboards...
« Reply #108 on: Thu, 27 October 2022, 16:02:34 »
i refuse to read the rest of the comments so this is probably already asked but is it still made in the us
Offline volvo244t
« Reply #109 on: Sat, 04 February 2023, 20:20:38 »
I hope a hollow, plastic version will follow.  Because clicky switches need a big, hollow, plastic chassis to sound good.  My completely stock Keychron K10 plastic version with box jades is close, but no cigar...
Closest thing I can find on the market is NCR-80, which is TKL.  No 100%, no care.
Sent from phone using K10 with box jades because I can.
edit:// yes, big bump, because I literally just found out about this.  SOOOOORRY!
« Last Edit: Sat, 04 February 2023, 20:23:35 by volvo244t »
Keychron C2 - box pinks - mt3 jukebox
Keychron K10 - box crystal jades - mt3 dasher
Keychron V6 QMK - gat cap v2 milky yellows - marrs green clones in oem profile?
IBM Model M - 1391401 - blue label - 3/9/93
