Author Topic: Beam Spring 104+SSK+122+62 Reproduction Project! Round 1 now shipping  (Read 370928 times)
Offline Ellipse
    • Brand New Model F and Beam Spring Keyboards
Re: Beam Spring 104+SSK+122+62 Reproduction Project! Round 1 now shipping
« Reply #150 on: Sat, 16 November 2024, 01:02:21 »
The beam samples have finally been completed!  Soon they will be on their way to me for full testing.
Below is the first photo of the completed Round 2 Beam Spring sample keyboards:
310987-0
Offline Ellipse
« Reply #151 on: Thu, 21 November 2024, 21:54:18 »
Here we have some additional photos of the final beam spring pre-production inner assemblies.  There is a mistake on the B122 in that the 5 extra holes should have been cut out above the cursor area and then covered with tape (the photos show the key spots visible without tape on some of the top inner assemblies).
311063-0
311065-1
311067-2
Offline Ellipse
« Reply #152 on: Wed, 04 December 2024, 20:58:12 »
The final beam spring sample keyboards arrived this week and have been tested.
They are excellent quality and have been approved for production!  Now everything remaining with the beam spring project has been approved for production.
We just have some firmware issues including mapping errors on the boards that need to be corrected (the keys register but are not properly mapped).
I very much like the quality and consistency of the beam module assembly and sounds.  I feel that the additional foam padding and slight enlargement of the top inner assembly module holes (more like the IBM originals but not so large that the keys wobble a lot - like on the IBM originals) refines the beam spring sound and eliminates much of the additional reverberation and higher-pitch sound found on the Round 1 boards.
Only 1 out of the ~244 modules needed adjustment for the two B122 boards I tested.  And thanks to the change to the press-fit washers, the beam modules can be disassembled and reassembled by hand.  It is far easier and faster to reattach the flyplate with everything out of the module!
Weights without keycaps:  B122 9.4 lbs, B104 8.0 lbs, BSSK 6.8 lbs, B62 4.9 lbs
Offline Ellipse
« Reply #153 on: Thu, 02 January 2025, 20:27:58 »
Beam spring production update:
The factory notes that they have completed production and assembly of 80,000 Round 2 beam spring modules.
The cases, bottom and top inner assembly plates, foam, PCBs, and other small parts were approved for production last month.
The Leyden Jar (for B122 and B104) and xwhatsit (for B62 and BSSK) controllers are all in stock, ready to be installed.
The PBT double shot MX keycaps for the beam spring keyboards all arrived to me with last year's container shipment, so they are all ready to ship.  These are the same keys from the same order as was done for the Round 1 beam spring keyboards.
I am hoping that they complete production and assembly of the remaining items over the coming months.
Again I want to reiterate that the quality of the sample beam spring keyboards received a month or so ago is excellent, and most noticeable is the significantly improved consistency of the key press of each beam module.
For those not following the project closely in the past year or so, the beam module supplier switched and brand new molds were created for the Round 2 beam modules.  These new beam modules, combined with the improved assembly quality, has resulted in excellent production examples.
Here's a photo showing how the modules are being stored while we wait for the other parts to be completed.  The modules are on layers in trays, with a cardboard separation between each layer of modules.
311709-0
« Last Edit: Thu, 02 January 2025, 22:01:36 by Ellipse »
Offline Ellipse
« Reply #154 on: Mon, 27 January 2025, 19:48:30 »
Everyone please do share their recommended MX key set options here so that I may share them as requested: 122+ key sets, various international language options, media keys, custom sublimated MX sets, etc. MT3 sets have been recommended but I am not sure if their largest sets are still available to order.
Offline CaptainFabulous
« Reply #155 on: Mon, 27 January 2025, 20:18:34 »
I prefer SA caps. Always wanted a set of Dashers but was never able to find them.
Offline Damage
« Reply #156 on: Mon, 27 January 2025, 23:01:00 »
AF SA keycaps like these are fitting for the beam spring look, come in 160-key sets with decent kitting, and are offered in various colorways. They’re double-shot ABS with a nice semi-gloss finish. Not bad for about 30 bucks.
https://www.amazon.com/GEKUCAP-Minimalist-Keyboard-Switches-Mechanical/dp/B0CTCCHZ9P/
If you prefer thick PBT in an SA-inspired-but-shorter style, KAT WoB from Keyreative is nice.
https://keyreative.store/products/kat-white-on-black-extensions
If you prefer a high-gloss look, JTK’s HSA (half-height SA) caps might do the trick:
https://clickclack.io/products/jtk-hsa-profile-keycaps
For a retro look in a mid-height profile made from double-shot PBT, check out MTNU:
https://novelkeys.com/products/mtnu-wob
For a lower-profile sculpted PBT set with a similar look and cylindrical key tops, these ISA-profile caps are nice and affordable:
https://www.amazon.com/Womier-Key-caps-Keyboard-Mechanical/dp/B0DCVDY5TS/
For something very much like to the ISA-profile caps but with spherically indented key tops, check out the CXA profile caps here:
https://cannonkeys.com/products/cxa-bow-wob
« Last Edit: Tue, 28 January 2025, 12:18:20 by Damage »
Offline Ellipse
« Reply #157 on: Sat, 08 February 2025, 14:58:02 »
Thanks for the recommendations.  Please keep sending them!
Here are the first professional style photos of the Round 2 classic style beam spring keyboards and F122 keyboard:
To see the high res photos, please go to the bottom of the post of all the newer F and Beam models:
https://imgur.com/a/brand-new-model-f-beam-spring-keyboards-new-models-EIebi75
The photos show each available layout with the factory keys:  ANSI, ISO, Split Shift and 2U Backspace, and Split Shift and Split Backspace.
Here is one photo of each available layout:
« Last Edit: Sat, 08 February 2025, 15:03:02 by Ellipse »
Offline Ellipse
« Reply #158 on: Sat, 01 March 2025, 03:27:25 »
Random question:  Does anyone know the font that IBM used on their F122 keyboard labels?
Production update:
The factory reports that they completed another 20,000 modules in the past few weeks, bringing the total to 100,000 out of the ~150,000 for the current production batch, but they still need to finish the case and the top/bottom inner assembly plates.  They are hoping to finish up production and assembly this year as noted earlier.
Here's a video posted a while back on how the cases are made:
Given the low volume of the beam spring project (about 1,500 keyboards for what may be the only production batch), all of these modules have to be assembled by hand, including the attachment of the thin metal part to the white part of the module.  Buying and setting up automation machines would far exceed the size of the project, for such a relatively small project.  Even the Model F barrels are installed by hand on the plates.  There still are many machines that help the factory workers, but these keyboards take quite a bit of labor to make.
I know things have taken longer than expected but the factory and I want to make sure everything is as good as possible. The latest examples from a couple months ago are excellent and they used modules from this completed production batch.  The modules are the most important part of the beam spring keyboard to get right and I'm glad that I did not approve mass production and assembly until they met my requirements.
« Reply #159 on: Sat, 01 March 2025, 13:31:59 »
Is the font of the F122 different? Pretty sure the F and M font is Helvetica.
Offline Ellipse
« Reply #160 on: Sat, 26 April 2025, 21:03:28 »
Apologies for missing your reply; IBM used a custom drawn font for the sublimated keycaps, but I am not sure which font was used for the F122 labels on the bottom of the keyboards.  Was it Helvetica, or some variant?  There may have been quite a few Helvetica TTF variants out there so I was wondering if it was a specific font, such as one that would have been offered for a word processor in the mid-1980s.
We have not had a factory video post in a while.  This above video shows how the factory adjusts the torque of each bolt for the beam spring keyboard inner assembly.  The tool they are using is a torque screwdriver, which allows you to specify the torque and it will let you know if the torque is too high and if the screws are too tight.  The purpose of this process is to optimize how tightly the bottom and top inner assemblies are attached to each other.  In our research over the past few years to get these keyboards to be in line with IBM's standards, we have found that having a slight looseness to the assembly, as shown in this video, results in a far nicer sound and typing experience.  You don't need a torque screwdriver for your own maintenance of these keyboards; you can just back off the tightness a few turns by eyeing it and keep things loose for optimal sound and performance!  In general, it should be looser than the point where the plates would start to bend unevenly around the areas of the bolt, where you would see some unevenness of the flat bottom plate.
Offline Ellipse
« Reply #161 on: Tue, 29 April 2025, 12:57:44 »
Production update:
The factory notes that they are finishing up production of the B104 next month, with assembly finishing up in mid-June.  They are going to check that everything is good with the B104, and then they will make the remaining 3 models, with assembly finishing up around the end of July, assuming no issues that require remaking parts.  They don't want to make a mistake and have to throw out all the costly aluminum sheets used to make these parts.
That would mean that the keyboards will be shipping from the factory all at the same time in August (not split in two shipments).  An early August shipment would mean that the keyboards would arrive to me around the end of September or early October.
Offline Ellipse
« Reply #162 on: Wed, 04 June 2025, 20:45:44 »
Production update:
The factory has completed the lasering and bending of the B104 top and bottom inner assembly plates (shown below); the next step is the coatings to finish these parts.
After they are coated they expect to start assembly, as early as the next week or so.  During the time of assembly they will be making the cases, which is a quick process now that they have all of the laser and bending settings worked out.  This is done to optimize warehouse space (another reason they order the boxes and protective foam as late as possible before shipping).
As I mentioned before, after the B104, they will work on the remaining 3 keyboard types (B62/BSSK/B122) and hope to finish up as planned.
It is great to finally see the beam spring keyboards coming together!
(edit - will repost later - photo posting is currently not working)
« Last Edit: Wed, 11 June 2025, 21:17:54 by Ellipse »
Offline Ellipse
« Reply #163 on: Fri, 13 June 2025, 19:16:10 »
Update on beam spring inner foam:
Everyone can now order an extra beam spring inner foam set at the below link, which has been updated today to add this item.  Same as with the Round 1 beam spring first aid kit, extra inner foam was not a part of the kit as it was with Model F First Aid Kits, so it would have to be ordered separately.
https://www.modelfkeyboards.com/product/beam-spring-extras/
If you are just ordering some extras, please feel free to place a new order and choose free/other shipping at checkout, right before clicking Place Order, to add to an existing shipment.
These are for the Round 2 classic style beam spring keyboards.  The cut out one goes below the inner assembly plate and on top of the beam modules (just like with the IBM originals) and the bottom one goes below the PCB.  Both are made of the same custom material as the newer batch of XT (non-crumbly style) Model F inner foam.
I also have some Round 1 beam spring foam sheets; these are just for the bottom one that goes below the PCB; feel free to email me if you want to order one.
Here's a photo of one of the first samples of the foam from a couple years ago - obviously it is a little rough compared to the production version.
(photo uploads currently not working; the above product page also shows the photo)
Offline Ellipse
« Reply #164 on: Thu, 19 June 2025, 00:51:44 »
Production update:
Today we have some more production photos, this time of the powdercoating process of the top inner assemblies and the completed bottom inner assemblies.
(unfortunately, I still seem unable to upload images to GH, so please check out the images over on the DT project thread)
https://deskthority.net/viewtopic.php?p=524652#p524652
Offline pixelpusher
« Reply #165 on: Fri, 20 June 2025, 11:17:54 »
The images aren’t showing for me on Deskthority.
« Reply #166 on: Wed, 02 July 2025, 18:08:33 »
I had to create an account and login to see the pics
Offline ander
  • I type, therefore I am
« Reply #167 on: Tue, 22 July 2025, 02:24:18 »
Joe: Fantastic progress—thanks for all the vivid updates!
Offline Ellipse
« Reply #168 on: Fri, 25 July 2025, 15:43:50 »
As an update, the factory continues production and assembly of the B104 keyboards and will soon start production of the other keyboard inner assembly plates and cases.  The modules and other parts were completed some time ago, so we are just waiting for inner assembly plates and the case, and them assembly of the BSSK, B122, and B62.
Offline Ellipse
« Reply #169 on: Sat, 09 August 2025, 15:09:12 »
As I noted earlier, they should be wrapping up this year on all production, but it has been slower than what they previously expected.
As a new update, they have finished assembling 200 B104 inner assemblies (just over 1/3 of the total) and are working on the remaining inner assemblies and cases.  The beginning assembly is always slower than the later assembly (the assembly speed ramps up after the initial time), so there is no set number of keyboards per day being assembled.  They have already started the B104 case production and expect it will be completed next week (they are currently being laser cut, bent into shape, and welded; see the updates page on the project website for photos and videos).
As always, if you want to get your keyboard as quickly as possible and help cover the project cost overruns, there is still time to skip the line of hundreds of keyboards through the custom/low serial product add-on.
Offline Ellipse
« Reply #170 on: Thu, 28 August 2025, 12:29:20 »
Production update:
Assembly and production of the beam spring keyboards continue, and we are still looking at shipping to start later this year, closer to year end.  The first photo below shows part of the quality control inspection process.  After assembly of the inner assembly, each key is tested with the signal level monitor tester of the Leyden Jar or xwhatsit utility and modules are identified for repair/replacement.
The factory has also finalized the boxes and outside foam, now that we are getting close to finishing up.  The design is back to the double-walled box design of the earlier rounds.  Below is the B104 prototype box that was approved this week.
Offline Ellipse
« Reply #171 on: Mon, 22 September 2025, 20:31:49 »
Production update:
Production and assembly of the keyboards continue.  The factory is still focusing on the B104's.  As mentioned before, they completed all parts except for the case and inner assembly plates a while back, and now they are working on these final parts and on assembly.
They will have completed about 100 B104's by the end of this month (September), and then they want to finish the remaining B104's by the end of October and start on the final parts for the B122, BSSK, and B62.  I'm hoping to be able to get a B104 shipment mailed out when they finish.  It may not be worth mailing 100 boards because they would be only of a few variations, since they make one variation at a time.
« Last Edit: Tue, 23 September 2025, 21:11:20 by Ellipse »
Offline Ellipse
« Reply #172 on: Tue, 21 October 2025, 23:11:40 »
Production update:
The factory continues production and assembly, but it continues to be slow.
They've been off for some time this month due to the Mid-Autumn Festival and subsequent break (often the workers take off more time than the official holiday).
Currently before they ramp up to full speed they are checking on a few last minute specifications with me.  They made over 100 cases and have been inspecting them and retooling as needed before proceeding with the remaining 1400 keyboards.  I have learned over the years that manufacturing is not a matter of finalizing a design and submitting it, and then just tracking the number of items produced per week, but a constant battle for quality control and making sure the specifications remain accurate throughout production.
Some examples of items that needed reconfirming or correcting, just as an example of the many small details that are updated behind the scenes to make things as good as possible.
The countersinking on the bottom cases (everything countersunk except the 4 holes for threaded bumpers).
The bottom case height was about 1-2mm too different from the bottom case (they need to add some spacers inside so that it is close to flush, and adjust the tooling as production continues).
They also need to be careful with the alignment of the keys around the border, especially since the metal parts are not made with die casting (sometimes the drilling is not precise enough and stuff has to be redone).
Tracking inventory for the end of the year update (some inventory is lost or discovered to be damaged - for example PCBs and beam spring plastic parts).
Offline Ellipse
« Reply #173 on: Tue, 04 November 2025, 19:40:32 »
As production and assembly continue, we have some new production images from the factory.  Here are the first photos of the beige and light blue production beam spring keyboards (they are the same color mixes and powdercoating as the Model M style case Model F keyboards).
315167-0
315169-1
315171-2
315173-3
315175-4
Offline Ellipse
« Reply #174 on: Wed, 05 November 2025, 12:43:13 »
Production update:
The factory notes that they have finished the production and assembly of the B104 inner assemblies, and they expect to finish the remaining B104 cases this month.  The other models will follow after the B104's are completed.
Their production process is to slowly complete a smaller batch of 100 first and work out any issues.  That process is done and now they moved to full speed production and assembly for the remaining boards.
Offline Ellipse
« Reply #175 on: Tue, 18 November 2025, 22:01:35 »
New project video:  Brand New Beam Spring Keyboards factory tour - powdercoating process
Just a quick walk around the factory's powdercoating area.  This video shows some of the B104 cases that are drying after being powdercoated.
Offline Ellipse
« Reply #176 on: Tue, 16 December 2025, 20:29:49 »
Production update:
The factory has completed the 100 or so B104's they noted last month.  Now they are working on completing the remaining B104's and other models.  It is going to take more time but they are aware of the high quality requirements and have been inspecting each keyboard for cosmetic defects, and discarding or repairing cases that do not meet the requirements.
While the laser/bending process to make the cases saves a huge amount of cost instead of making an injection mold (only some custom tooling is needed, as seen in the video posted some time ago), it is a far slower process than die casting as all the parts of the case need to be bent and welded together one at a time.  There is always a tradeoff between time and cost, if we keep quality as a constant.  These boards are already expensive so adding extra cost would reduce the number of folks who would be able to get one of these great old style boards.
Offline nickthaskater
« Reply #177 on: Tue, 23 December 2025, 19:17:23 »
Holy Moses. The black on beige looks incredible. Are the "extra" screw holes in the bottom for anything in particular?
Offline Ellipse
« Reply #178 on: Tue, 23 December 2025, 19:19:15 »
Yes, they are for the bumpers with bolts, to hold the solenoid driver PCB, and to hold the USB cable's P clip.
Offline ander
« Reply #179 on: Wed, 24 December 2025, 23:56:17 »
Joe, what a fantastic educational opportunity this has been for you and all of us. I can't speak for everyone, but I haven't minded at all waiting this long (nearly two years now, I think!) and having a chance to see how all this can still be done here in the 21st century. It's a unique adventure we keeb-heads get to share, thanks to you.
Offline Ellipse
« Reply #180 on: Thu, 25 December 2025, 02:04:45 »
Thanks ander for the kind words!  For everyone interested in the process to bring these keyboards back into production, feel free to check out this tech talk from several years ago, though it focused on the Model F project and not the beam spring project:
Offline Ellipse
« Reply #181 on: Mon, 29 December 2025, 19:38:35 »
Production update:
The factory expects to complete all or almost all B104 before the Chinese New Year (mid-Feb.).  Before they leave they will load what they have completed onto a container shipment, so the B104's can start going out to everyone in early April if all goes well.
The inner assembly plates were previously completed for all B104.  Just the cases and final assembly are remaining.  About 100 B104 keyboards were fully assembled as noted before, and an additional 100+ completed inner assemblies are waiting to be dropped into the cases when the next batch of cases are done.  You can see an earlier batch of completed B104 cases in the mini factory tour video in a recent post.
After they return in March, they will start working on the B122 cases.  After that, they plan to work on the B62 and BSSK cases; both B62 and BSSK are confirmed ready to proceed and they are making one more B122 pre-production sample to make sure all the tooling is correctly set up and the pieces are properly positioned after assembly.  And while they work on the cases, other workers are finishing up all the top and bottom inner assembly plates which need to be laser cut, bent to shape (top inner assemblies only of course, since the bottoms are just flat plates), and plated (bottom) or powdercoated (top).
The other keyboard parts were all completed (modules, PCBs, controllers, keycaps, etc.) so they just need to work on the cases and plates and then finish up assembly.  Based on the current rate of progress, they expect to complete the remaining 3 keyboard models in the two months after they return from break.  Their main bottlenecks are the laser cutting machines (they can only cut one per machine at one time) and the custom-tooled case bending machine (only one case can be bent at a time); see prior videos to see the Model F laser cutting (similar process) and beam spring case bending.
Now that all of the issues have been worked out (see prior posts for details), they are finally able to concentrate on finishing production and assembly.
Offline Ellipse
« Reply #182 on: Wed, 21 January 2026, 18:05:17 »
The first beam spring Round 2 pallet has been packed and sealed!  They are still trying to get as many B104's finished in the coming weeks before the Chinese New Year.  I've asked them to prioritize completing before CNY at least the quantity of each variation that has already been ordered, in case they can't finish everything.  That way, those who have ordered can have a variation that can ship in late April/May after the container shipment is delivered.
The MX keycaps with the black (modifiers) and white (non-modifiers) keycap colors are selling out too quickly; please order the "all black keys with white text" version if possible.
315939-0
Offline Ellipse
« Reply #183 on: Sat, 24 January 2026, 18:55:48 »
New project video:
2026 Brand New Beam Spring Keyboard production:  case bending assembly
You can still customize your Brand New Model F and/or Beam Spring Keyboards on the project website:  https://modelfkeyboards.com/
Production and assembly of the round 2 (classic style) Brand New Beam Spring Keyboards continue.  This recent factory video shows the bending of the side of the B104 cases.  The first B104 shipment is leaving the factory next month, before the Chinese New Year break.
Bending is done after flat sheets of aluminum are laser cut.  After they are bent, they are deburred and powdercoated; additional deburring may be done after powdercoating to remove extra material.
Each bending operation requires custom-made tooling attached to the machine, as can be seen in this video.
Offline Ellipse
« Reply #184 on: Wed, 04 February 2026, 21:28:45 »
The factory reports that all B104 inner assemblies have been completed (fully assembled) and that they are mailing about 300 B104 beam spring keyboards as part of the current container shipment departing next week.  Currently they are finishing up installing the inner assemblies in the last few dozen cases going out next week.  The bottleneck has recently been production of the cases, as detailed in previous recent posts.
The factory has completed just about all needed variations except for nearly all the black and industrial gray cases; most of those will be shipping in the container shipment departing in a few months from now.  If you picked one of those two case colors and want to get your keyboard in the shortest amount of time, you can request switching to Dark Blue, Light Blue, Regular Gray, or True Red by emailing me.  You can't switch to Off-White/Beige.
In other words, just about everyone who has ordered a B104 is expected to be in the current shipment, except the black and industrial gray case orders and possibly a few other exceptions; being in one shipment or another is not guaranteed.
Offline Ellipse
« Reply #185 on: Sat, 14 February 2026, 21:16:03 »
Last week the container was packed and left the factory.  The container ship is departing from the port early next week.  This one is the 8th container shipment for these keyboard projects.
316131-0316133-1316135-2
Offline Ellipse
« Reply #186 on: Fri, 27 March 2026, 15:56:36 »
Production update:
The first batch of B104 keyboards is expected to be delivered in the next couple weeks as soon as they can be taken out of the shipping container and space on the delivery truck can be reserved.  They departed the factory some weeks ago just before the new year break.
The remaining boards continue their production and assembly at the factory.  The current production update is that the balance of B104 keyboards is expected to be completed in the next few weeks and the BSSK and B62 are in the laser cutting process.  There are many factory operations that occur simultaneously to save time, such as the laser cutting machines and the powdercoating, assembly, and testing, so many keyboard variations undergo production and assembly at the same time.
The B122 will follow those two models in the queue for the laser cutting process (the bottleneck is the laser cutting process, which can only cut one piece at a time on each machine; see an earlier video posted on the project's YouTube page showing the laser cutting process).
Offline Ellipse
« Reply #187 on: Tue, 14 April 2026, 15:42:46 »
Container shipment update:
The container shipment was delivered last week without issue.
Over the coming weeks I will be confirming mailing addresses, updating the manual for the round 2 boards, inspecting inventory, and testing the keyboards with Rico's latest Leyden Jar firmware which offers some improvements to the calibration binning.  These are the first beam spring keyboards to use Rico's Leyden Jar controller!
As always there is still time to add on to your order any additional key sets, first aid kits, LED overlays and other parts to ship with your keyboard.  You can also order the skip the line custom/low serial product add-on.
In other words, shipping will not start for several weeks, and there are a couple hundred boards to ship, so this will take quite some time.  And as I mentioned with a previous update, please do not ask me which batch your keyboard is in or when your order will ship.  As per a previous update:
"The factory has completed just about all needed variations except for nearly all the black and industrial gray cases; most of those will be shipping in the container shipment departing in a few months from now.  If you picked one of those two case colors and want to get your keyboard in the shortest amount of time, you can request switching to Dark Blue, Light Blue, Regular Gray, or True Red by emailing me.  You can't switch to Off-White/Beige.  In other words, just about everyone who has ordered a B104 is expected to be in the current shipment, except the black and industrial gray case orders and possibly a few other exceptions; being in one shipment or another is not guaranteed."
Offline Ellipse
« Reply #188 on: Tue, 14 April 2026, 20:16:27 »
Here is a summary of the Round 2 improvements over the Round 1 beam spring boards:
An improved, dampened, and more refined sound while typing, due to:
•   Extra case material and foam on top of the modules (like on the originals) for added dampening.  The casing is made from custom-bent metal (see below factory videos) whose dimensions were based on scaling the measurements you kindly provided me.  The Round 2 keyboards were made to look like the classic appearance of the rounded case beam spring boards (basically all the boards except the angular 3278 and 3279 boards (a prototype was made of this design but most folks disliked it).  It's also inspired by the process used to make the IBM Displaywriter keyboard case (the bottom was stamped and folded, not die cast; the new beam spring boards were all stamped, folded, and welded with custom-made stamping tools).
•   Improvements during a long R&D process over the past few years (the injection molds for the modules was redone and the beam module metal materials were changed to make them sound closer to the originals; though as I mentioned in my updates, the goal of this project was to bring back the beam spring mechanism and not to exactly recreate the sound or feel as exactly as with the Model F project).
•   Also the inner assemblies are now closed with a torque screwdriver, which allows you to specify the torque and it will let you know if the torque is too high and if the screws are too tight.  The purpose of this process is to optimize how tightly the bottom and top inner assemblies are attached to each other.  In our research over the past few years to get these keyboards to be in line with IBM's standards, we have found that having a slight looseness to the assembly, as shown in one of the below videos, results in a far nicer sound and typing experience.  You don't need a torque screwdriver for your own maintenance of these keyboards, you can just back off the tightness a few turns by eyeing it and keep things loose for optimal sound and performance.
Additional improvements:
•   These are the very first beam spring keyboards with Rico's new open source RP2040-based Leyden Jar controller (same controller as on the F122's).  All the new Model F and beam spring boards still run Vial.  These now have enough memory and pins for 18 instead of 16 columns, improved matrix scanning speed, as well as additional Vial features, including layers and macros, that did not fit in the ATMEGA32U2 used in the xwhatsit controllers.  The other keyboards that do not require 18 columns (B62, BSSK, etc.) will continue to use the xwhatsit controllers until stock runs out, as I've noted on the forums.  I stocked up during the chip shortage many years back, before the Leyden Jar was released.
•   Improved QC - no one is expected to need to adjust the bend of the metal parts inside the module due to a factory QC error with some of the original modules that was disclosed at the time.  The most common issue is just a flyplate (the metal part connected to the flipper) that gets separated from the rest of the module while in transit.  This QC improvement was introduced with the second batch of Round 1 beam spring keyboards which have been in use for a couple years now without major reports of failures.
•   Reattaching the flyplate is now even easier than both the IBM and Round 1 originals where you had to use tape and a paperclip.  The modules now have a custom-molded press fit plastic washer on top so you can quickly and easily disassemble the module by hand and reattach the flyplate (or replace a damaged inner plastic part).  This was also introduced with the second batch of Round 1 beam spring boards which used a glued-on metal washer for each module.  Also in general the beam spring is much easier to take apart compared to a Model F; you only need to unscrew the bottom inner assembly plate instead of using pliers to separate it.  You can even leave the keys installed (except for the modules that you need to remove to fix, of course).  For these reasons, resolving issues requiring disassembly that come up over the years might be even easier and quicker to repair than many issues of the Model F.
•   The boards still come with a mini-first aid kit of 4 modules in anticipation that some may break while in shipping, though many folks order the 12 module full first aid kit.
And as always, for folks who have been waiting a while now and want to see the reasons behind the extended production timeline (and for everyone who is curious about the Beam Spring keyboard production journey), everything is explained in detail on the updates page on the project website.
The aforementioned beam spring Round 2 videos:
« Last Edit: Tue, 14 April 2026, 20:18:04 by Ellipse »
