Author Topic: Beam Spring 104+SSK+122+62 Reproduction Project! now shipping  (Read 599853 times)
Offline Ellipse
    • Brand New Model F and Beam Spring Keyboards
Re: Beam Spring 104+SSK+122+62 Reproduction Project! now shipping
« Reply #200 on: Fri, 05 June 2026, 12:07:03 »
The Chyrosran22 new Beam Spring trailer was just posted!
Offline PlsCrit
« Reply #201 on: Fri, 05 June 2026, 14:00:08 »
Been using my B104 R2 for a couple weeks now and I love it  ;D! What an amazing project to come together... But damn did I not realize how truly big this thing is, I've (gently) placed my daily driver, which now lives at my office, on top for scale.
So far have been blessed with little to no issues, with one exception: small bits of plastic flake off some part of the beam spring module which settle down onto the pcb and cause keys to not register correctly. Has happened 3 times now which requires opening up the case and removing the debris. Not sure exactly what part they are from, but if I had to guess, the "beam barrel part B", or the keycap stem, or maybe even the bottom of the keycaps? The flakes are all white and plastic. I didn't want to mess with the module too much but in hindsight I should have attempted to locate the module the flake came from and inspected it to see which part is the culprit. Next time it happens Ill try to document it.
During keycap assembly some caps were harder to put on than others and required more force, this could have caused some plastic part around the stem or keycap to break off?
Edit**
Just re-read this part of the manual:
When putting the press fit washer back on the module, it is important that the module is pressed all the way down with a minimal amount of force; not so much force that you break one of the plastic legs of that white part inside the beam module.
Broken white “leg” on the beam barrel part B:  you may notice a broken off white part when removing a module for adjustment.  Sometimes this is hinted at when you can’t press a module down all the way.
This might be the same issue, however the broken off flakes I observed do not resemble the legs, it is possible its a sliver of the leg though.
« Last Edit: Fri, 05 June 2026, 14:57:32 by PlsCrit »
Offline Ellipse
« Reply #202 on: Fri, 05 June 2026, 15:23:23 »
Yes, you may have cracked or fractured parts of the legs when installing many of the keycaps (I have done this before, in my earlier testing of the early new beam spring keyboards years ago!).  You can sometimes detect it if the key module without an installed key wobbles a bit more than the other keys.
Absolutely little to no force is needed to install the project keycaps, as mentioned in the very first sentence of Action Step 6 Keycap Installation:
"Be extremely gentle when pressing each key down to install it; you can easily break or fracture the white part of the beam module if you press too hard."
Now to think how to fix what was done:  I recommend trying to more quickly expose which keys are bad, to avoid you having to keep fixing things as they make themselves known.  What I might do is take a large sturdy flat object (something like the key set box, protected on the bottom side with a cotton towel etc.) and use it to press all of the keys down gently many times, maybe 100 times or more, and then manually press each key a bunch of times from slightly different angles, taking note of which ones don't feel right or produce an inconsistent signal in the Level Monitor screen of the diagnostic tool.  Then replace those modules with some of your spares from the first aid kit.  As always be extremely gentle with this method so as not to break or scratch any keys.
« Last Edit: Fri, 05 June 2026, 15:37:35 by Ellipse »
Offline PlsCrit
« Reply #203 on: Fri, 05 June 2026, 18:24:33 »
Thank you for the reply, yes the corrective action you recommended is actually what I did earlier in an attempt to discover more keys affected. I opened the case twice this morning as a result of that, frustratingly a new key will become defective after Ive already put the case back together! haha
The modules under which I removed the loose pieces of plastic feel completely normal and have no detectable faults (by feel and by the leyden jar diagnostic tool) so Im deciding to leave them in for now. I guess Ill know if I really need to replace the module if the same ones fail repeatedly.
I thought I was pretty careful during keycap installation, I only applied as much force as necessary to install each one, but after finishing, I noticed many of the keycaps resting at different heights, I know its not the modules themselves as I inspected them all pre-installation to ensure they were all uniform in appearance, looking from multiple angles, pressing each one, etc... For the more egregious caps, I pushed them in a little more to get them more in line with the other caps. These modules definitely required more force than the others to have the keycap installed. There were only about 2-3 modules whose stems felt like they fit the keycap like a glove and required no force. Im assuming the factory that made these had some sort of tolerance for the dimensions of the stems, and similarly with the keycaps, and the slight variances resulted in some keycaps needing a more forceful install.
For the rest that are still higher than the others, Im hoping that days of typing will eventually move them down little by little. Im about to open the case for the 3rd time today now that Im finished with work and given the entire board your recommended mass press treatment (hopefully 8 hours of typing will have helped dislodge the rest of the pieces I havent discovered yet)
« Last Edit: Fri, 05 June 2026, 18:33:42 by PlsCrit »
Offline Ellipse
« Reply #204 on: Fri, 05 June 2026, 19:29:56 »
Thanks for the update.  As a general note, these key sets are all from the same one production batch made years ago, that started shipping with the Round 1 boards; they do not have reports of disintegrating, and neither do the beam modules.  If one key out of 100 was bad then that would be one thing but for many keys to be affected and only on your board and not the hundreds of others that shipped in recent years, that is another thing.
With gentle pressing, all keys should be installable to the same relative height, not perfect like an MX cap but more than acceptable.
I am posting as I don't want folks to think this is a product defect, as not one person has reported it after years and hundreds of beam spring boards shipped.  And for many modules, not just one or two to be affected, and only on your board, points towards a specific problem with one user.
Another idea may be to hold the board vertically and remove all the keycaps to see if there is some debris, and then do one final careful wiping of the large capacitive PCB and the beam flippers.  Before putting the keys back, check the tops of each beam module as there may be some small flashing, though this is not likely.
You may want to also cover the keyboard when not in use as you may have a dusty environment.
Offline Ellipse
« Reply #205 on: Fri, 05 June 2026, 19:45:32 »
"New Model F Labs B104 Beam spring keyboard with solenoid typing test"
https://www.reddit.com/r/MechanicalKeyboards/comments/1tuzrze/my_chonky_boy/
https://www.reddit.com/r/MechanicalKeyboards/comments/1tuzrze/my_chonky_boy/opgktah/
"They feel awesome, it's a very unique experience to type on it, something never been felt in my life, not even a Model F can resembles the key feel. Smooth, deep thock and click happening simultaneously, you can't really describe it accurately, just like having the premium curry in your mouth, you can tell what's the ingredients in it, but it's indescribable when all the chemistry happening in your mouth. I no longer crave for another keyboard (except the unshipped B62), I think this is the end of my keyboard journey."
Offline PlsCrit
« Reply #206 on: Sat, 06 June 2026, 00:49:56 »
Thank you for the additional tips! Also it is not my intention to discourage other users interested in the product, but rather an attempt to help other users with the same issue or point out new issues you may not have encountered yet. If we can identify the weaknesses and improve upon them everyone benefits. I get why you would be skeptical of one user reporting issues others have not, I encounter that daily at my job haha. Perhaps there are others, but they've encountered and solved the issue without saying anything here. If you're another user reading this who encountered the same issue, do NOT throw away your "broken" modules and continue reading!
So, after inspecting the entire module for a couple faulty keys I finally found the culprit. It's not the legs at all, it's the little plastic cap that secures the metal part to the beam barrel! I was relieved to find the cause, I could finally move on to repair and prevention.
See the attached photo for reference.
The problem: In the manual, there is a disassembled module that looks a little different, but structurally the same as mine. In the manual, this plastic part is much thicker than on the modules I have (as well as a different colored o-ring & a metal washer but maybe that module was a prototype or something). It seems somewhere along the line the spec for this part has changed from that original pic in the manual, or maybe it's a manufacturer issue, or maybe the photos are playing tricks on my eyes. In any case, this thickness is key - these "caps" are very fragile and under the tension of the metal part in an assembled module, it's enough force to bend or even break off the edges where the metal pushes against that cap. I took a flashlight and closely inspected other modules in my board, all in all about 10 more keys had plastic bits where a stress crack was forming or already formed, leaving a leaf of plastic hanging on by a thread (see other photo for broken off pieces.)
How to fix: Removal of the problematic module is needed, but if you're careful, full disassembly can be avoided and save a lot of time. I doubt many people have this tool, but I used a watchband springbar remover. It's fully metal, long enough to reach into the module from the beam flipper side (while holding the module upside down), very thin, and one end is slightly forked. Absolutely perfect for the job required.
If you dont have this specific tool, try a toothpick or something else that is sturdy, thin, and long enough to get into the module from underneath.
I angled the module to expose the plastic bit about to shear off, and lightly pushed against the broken bit until it flaked off. Flip the module right side up and give the stem a couple taps to get the debris to fall down. Take care to not accidentally break off the entire  cap as you "clean off" these flaking bits, it seems like the metal part won't be able to stay on if it completely breaks. I did not come close to doing that for mine but I could see a heavy hand going too far. Also, the stress line from the weakened plastic caused the break to occur cleanly along that line. Now unfortunately my module is not "whole", but I'd rather have a still functional module than using a spare due to such a tiny fault. Truly the most annoying part was painstakingly inspecting each module while they were in the case to look for hairline cracks and figuring out which key they belong to, then flipping it back over to find the corresponding keycap and removing it, then flipping it back over! And having to screw and unscrew the metal plate+PCB to keep the modules in place as I flipped it over each time. If you are feeling risky (and I highly advise against it) you could just hold the module plate, PCB plate, and PCB tightly together as you turn it over. I tried this once out of impatience, and while everything turned out ok for the most part, I jostled some modules out of place and also accidentally managed to dislocate a beam flipper for a module I had not removed the keycap for, forcing me to turn it over AGAIN and then remove the keycap and the affected module. Whew.
Take care to not push in the bottom of the beam flipper while handling the module upside down as this can cause the metal parts connecting the flipper to dislocate, full disassembly & reassembly is then required!.
Prevention: Well, unfortunately there's not a whole lot one can do to prevent an incredibly thin piece of plastic that undergoes constant movement from developing a crack and breaking, but once adjusted you wont have to do it again for the same module as there is no longer any plastic resting against the moving part! :thumb: What one can do is inspect their modules as I did and look for modules that have cracks already, I highly recommend getting ahead of the issue so you don't have to take the board apart 10 times in a month.
All in all, not every module suffered from the issue, but plenty enough did that I wanted to check every single module, not just those showing an error in the diagnostic tool. Over enough use, as the plastic is exposed to pressure over and over, I'm sure it's an issue I'll have to address again.
Last I'd like to thank Ellipse again for an incredible passion project, and have a couple questions:
1. Could your manufacturer make a slightly thicker plastic cap for the beam barrel part B where the metal part is attached? I'd hazard that a couple extra millimeters would do it.
2. If the above is not an option, is it possible to sell just that part? It's the most fragile piece in the entire module, so it'd be convenient to buy extras of the piece most likely to fail instead of whole modules.
TL;DR The plastic that secures the metal part to beam barrel part B is too thin (at least for my batch of modules) and the tension caused by the bending metal is enough to weaken or straight up break off bits of plastic, causing them to eventually fall down onto the PCB and cause input detection errors.
« Last Edit: Sat, 06 June 2026, 01:00:08 by PlsCrit »
Offline PlsCrit
« Reply #207 on: Sat, 06 June 2026, 00:52:15 »
~Uploaded a duplicate photo instead of the broken off pieces, see below~
If you are a user seeing these inside your case you more than likely have the same issue I did.
Offline Ellipse
« Reply #208 on: Sat, 06 June 2026, 02:24:21 »
Thanks for your investigation!  Since these same parts have been out for years with folks using these keyboards daily and not reporting such an issue, my guess is that the extra force you mentioned installing the keycaps put a lot of pressure on that part, which contacts the beam flipper when pressed.
Fortunately I have a lot of extra Part B's only.  Please email me to arrange for some free replacements once you know how many you need.  If anyone else made such a mistake during setup I'd be happy to mail some Part B replacements your way as a courtesy.  Are you seeing these on your most frequently typed keys, or more so on the keys you remember pressing more forcefully to install?
Again, I want to emphasize that the modules have been out for more than 3 years with zero reports of flaking, but yours started flaking within the first month after installation which is not normal for these keyboards.
Offline PlsCrit
« Reply #209 on: Sat, 06 June 2026, 12:55:03 »
I'm not trying to argue with you or anything, but I don't believe it's from installing keycaps. Even fully compressed there is a sizable gap between the part I highlighted and the beam flipper, see the attached photo. The legs on barrel part B prevent such an impact, so unless I press hard enough to shatter the legs those two contact points should never meet. Additionally, each part that had a weakened or broken off "cap" was exclusively where the metal part bends, if somehow the two parts were contacting and causing damage from impact I would have observed more diverse break patterns, however, every break was identical in it's pattern. I would provide pictures of the modules so you could see this uniform break pattern yourself but I only photographed a single module before putting the rest back into the case.
The keys I had to pull to apply my "fix" were Up-Arrow, Left-Arrow, Page Down, 2, 4, 9, C, V, J, K, T, and the "/?" key.
Thank you for the replacement offer, I will gladly take you up on that!
Offline Ellipse
« Reply #210 on: Sat, 06 June 2026, 13:13:41 »
Thanks, as I mentioned over PM, we will be chatting over email to continue the discussion.  There might be some benefit to adjusting the firmware offsets and calibration bins to provide more leeway for the keys to work despite debris in the keyboards.
Sharing with permission some more feedback (and a photo) on the new B104:
"Shipping to [Europe] went perfectly fine, only one module was broken and one more needed reseating on arrival. MT3 keycaps fit the stems without an issue (see attached photo), software-wise the setup was a breeze. Hardware-wise, well, could definitely have been easier but I succeeded despite having hardly any prior experience assembling keyboards, so I guess it could have been significantly worse as well.  The keyboard feels and sounds glorious, as expected, thank you once again."
317403-0
Offline Ellipse
« Reply #211 on: Mon, 08 June 2026, 14:16:11 »
Rico has released an updated Leyden Jar firmware which adds calibration bins (like the Model F keyboards) to fix issues with modules having varying signal levels (due to debris etc.) not working.  Binning allows keys with different signal level values to have their own activation values, instead of having one value for all keys, so any keys with lower resting values due to debris will have their own values based off this custom value.  As always please email me with feedback.
https://github.com/mymakercorner/vial-qmk/releases
Offline BrendaEM
« Reply #212 on: Sat, 13 June 2026, 23:35:22 »
Hi,
Oddly, I used to use IBM 5251 terminal/keyboard at work.
I had a question: why is there not an option for keys which are grey and black, with white legends?
(as the originals are)
BTW, CAPTCHA after loging in, is just cruel. Probably not going to spend much time here if I have to spell "enthusiasts" every time I go here.
Offline Ellipse
« Reply #213 on: Sun, 14 June 2026, 00:15:05 »
The minimum order quantity was too high for me to pick 3, so I picked what I thought would be the most popular two color options.  The gray does look nice!
Offline copper4eva
« Reply #214 on: Tue, 16 June 2026, 16:44:56 »
Is pressing keys down to hard a concern even after the keycaps and everything are installed?
Offline Ellipse
« Reply #215 on: Tue, 16 June 2026, 17:06:39 »
No, I don't think the keyboard can break even with heavy typists; the main issue is with installing them.  This is also a warning with MX keycaps; they can break the switch stem when installed and they can even break the PCB switch pins from what I'm reading.
Offline Ellipse
« Reply #216 on: Thu, 18 June 2026, 16:43:47 »
Compact B104 update:
I checked all of the compact beam spring keyboard boxes and found a few more compact B104 Round 1 keyboards and have just updated the inventory on the project web site.  First come first served if anyone wanted these.  They are the last ones that are available.
https://www.modelfkeyboards.com/product/beam-spring-round-1-keyboard/
Offline Ellipse
« Reply #217 on: Fri, 19 June 2026, 17:27:54 »
Sharing with permission a nice Round 2 B104 with black case in an office!  Always nice to have a dry erase board in your office!
317529-0
317531-1
Offline chris93372
« Reply #218 on: Sat, 20 June 2026, 12:03:06 »
Good morning-
Received my Round 1 BSSK, and have proceeded to get a solenoid installed. Per your recommendation, I got the 5v Sparkfun solenoid, and it will fit into the case w/o any issue.
The problem I'm running into is that fn+space+t will not toggle the solenoid. The only time it works is when I press Caps Lock. The Yellow LED on the board lights up, and then the solenoid legs energize. When I press Caps Lock down again, then it reverts back to 0v.
I've tried recompiling a new hex file with B3 and B6 swapped, but that didn't fix the issue.
To make things more fun, when I flash the BSSK with the r2 firmware, then the solenoid works...for some of the keys, and I can't toggle it off.
I've read through th thread, and haven't seen anything similar?
Offline Ellipse
« Reply #219 on: Sat, 20 June 2026, 12:19:39 »
I am glad you are pushing these keyboards to their limits!  For the older keyboards with 30 pin controllers such as your model (manufactured before the updated 33 pin controllers were ready), there was no option to allow 3 LED lock lights and a solenoid at the same time, so the default option was to support 3 LEDs; the alternative is to support 2 lock LEDs (Num and Caps Lock) plus the solenoid.  See this comment below from firmware developer NathanA with updates.  It moves the scroll lock to a disconnected pin that can't be used on the 30 pin controllers and moves the solenoid pin to what was the scroll lock pin.
The solution is to update the firmware to change that pin from a lock LED to a solenoid enable pin and then rebuild the firmware.  Edit ploxiln's vial-qmk-latest\keyboards\xwhatsit\brand_new_model_f\beamspring_ssk\xwhatsit\config.h "such that "#define SOLENOID_PIN" is changed from B3 to B6 and "#define LED_SCROLL_LOCK_PIN" is changed from B6 to B3, and then rebuild... take this hex file and replace/overwrite the same-named one in the "firmwares" directory in the extracted QMK Layout Files zip file, before he runs the flash script."
Offline chris93372
« Reply #220 on: Sun, 21 June 2026, 11:20:56 »
Thank you for the quick reply! I had a different config.h built up, so I made the change that NathanA added, and then was able to flash the keyboard. The solenoid did not have an L bracket with it, so I ended up having the plunger mounted with double-sided tape so that the return stroke hits the side of the case.
When looking at the solenoid controller, there's instructions to short pads J3 and J4 for 5v. With the solenoid being a 5v one, I tested it with both. I don't think that leaving the voltage higher for the short period of time will damage the solenoid, so I'm leaving it for now.
When I reflashed the controller, I lost the capability to use Vial for customizing, but Claude suggested that I could edit keymap.c, so I had it code up a mapping sequence where I used the Pause button to toggle the solenoid, run the Fn keys on Layer 1, and map media keys to the function keys on Layer 0. I also used it to remap the orientation of the modifier keys to match up with the Mac keyboard that I'm accustomed to using.
Thanks again for doing this! It's a lot of fun having a beam spring to go with my Unicomp Model M. Good thing I have WFH capabilities, or I may get kicked out of the next Zoom meeting.
Offline Ellipse
« Reply #221 on: Sun, 21 June 2026, 13:06:15 »
Thanks for your feedback and photo!  Would it be ok for me to share them?
There may be an incompatibility between vial and your config changes.  I recommend trying to start from the unaltered ploxiln files, only switch those two pins, compile, and flash as you should have Vial that way; then you can work from there.
Offline chris93372
« Reply #222 on: Sun, 21 June 2026, 13:09:47 »
Feel free to share, and let me know if you have any other questions!
I'll try the re-flash next. Now that it's 'working', I'll use it as-is for now, and then come back to it fresh from the very beginning. I'd like to come up with a better way to mount it than double-sided tape, and clean up the wiring a bit, anyway!
Offline Ellipse
« Reply #223 on: Sat, 27 June 2026, 12:09:02 »
The Chyrosran22 Beam Spring B104 review video has been posted!
There was some discussion in the video about the smoothness of the typing experience and I wanted to share some of the comments on this thread, those emailed to me, and those on other forums, which especially praise the smoothness of the typing:
"I just got mine in, and it's amazing to type on, the feel is buttery smooth yet with that tactile mechanical feedback - I didn't think the Model F repro could be surpassed but this did it.  Setup was painless and I'm more than satisfied - the wait was worth it!"
"got mine today! thanks Ellipse its everything id hoped it would be, incredible."
"The keyboard is a dream to type on, and the solenoid really adds to the experience. I might have to turn it down to the minimum setting, however. If I don't, I may well wake up to the fiancée hitting me over the head with the board."
"Been using it a couple days now and am really enjoying the switches; in setting it up I fortunately only had to reattach the beam flipper for one switch and wiggle another"
"B104 arrived today - worked right out the gate. Very happy with the product and it was worth the wait. This will be replacing my Model F permanently!"
"I just received my keyboard and finished setting it all up and its working great out of the box with no adjustments needed!  It looks and types great, I also like the touch of printing the packing list on a dot matrix printer.  Keep up the good work!"
Offline OCTAGRAM
« Reply #224 on: Sun, 19 July 2026, 11:34:58 »
There are keyboards with ability to detect intermediate positions of keys and convert this into virtual gamepad sticker movements. On some keyboards this is WASD and arrows. Some keyboards have all keys upgraded, but single virtual gamepad sticker can of course only use limited set of keys.
I know about Cooler Master MK850 (AimPad) and Wooting Two HE. The competition is scarce and colors are horrible. Alternative keycaps can fix it to some degree, but keyboard itself stays black.
I read about programmable solenoids in Model F keyboard. And I wonder. Can position measurements be translated to virtual gamepad sticker by just flashing new firmware? Or are solenoids in some isolated enclave, away from sending arbitrary USB signals.
Offline schizobovine
« Reply #225 on: Mon, 20 July 2026, 10:34:28 »
As I understand it, most solenoids in keyboards like the Model F are output devices to make a noise/vibration when a key is hit. The switches themselves are all binary contact/no-contact.
The two main technologies that would be able to detect analog movement like you're talking about would be either hall effect or electrocapacitive (Topre) switches. As it stands, I don't know if there are any full open-source Hall-effect keyboard firmware out there, but cipulot's EC stuff is in QMK main.
Offline Ellipse
« Reply #226 on: Mon, 20 July 2026, 14:14:18 »
Sharing with permission a nice True Red B104, customized with one of the project's Beam Spring metal badges.
317812-0
Offline falcrist
« Reply #227 on: Mon, 20 July 2026, 18:40:24 »
Yes. My recollection (partially backed up by the wikipedia page for the IBM 5250) is that machines like the 5251 incorporated a solenoid specifically to replicate the feel of the IBM Selectric "golf ball" whacking the page. That would provide a smoother transition for typists used to the whole damn room vibrating with every keystroke.
Offline Ellipse
« Reply #228 on: Tue, 21 July 2026, 03:06:38 »
Sharing with permission a kind review of the Round 2 B104 Beam Spring keyboard:
"My B104 arrived yesterday and it is an absolute treat. It's a gorgeous piece of equipment and it's clearly very well made. It required zero repairs or tweaking beyond putting the keycaps on - when I tested it, every key fired correctly the first time.
I am still a regular Selectric user and, with the solenoid on, this thing mimics the feel of one perfectly. Everything from the key profile to the resistance to the cycle clutch "kick" (if the solenoid is on) is dead-on. Which I know was IBM's intent with the original, but it's a feeling I've been chasing in a keyboard for fifteen years, and this is where I finally found it. I recorded myself typing on both and if it weren't for the Selectric's margin bell I'd struggle to tell the difference.
Also, your red powder coat matches my Correcting Selectric II perfectly. Side-by-side, they look like they could have come out of the same factory.
Thank you so much for this labor of love. I'm going to cherish it."
Offline Ellipse
« Reply #229 on: Tue, 28 July 2026, 21:50:51 »
Production update:
I've been working with the factory for more than 10 years now and they know what is expected, so they are good to check to see how to proceed if an issue comes up. The perennial issue with manufacturing is with maintaining quality control. The factory is currently doing some rework on the cases as they continue production and assembly, which has resulted in a delay. They are now expecting to finish up everything except the B122's by the middle of September and then finish the B122 by late October, so the boards are still expected to arrive by year end but a little closer to year end. As I mentioned before, the cases are trickier to assemble because they are laser cut, bent, welded together, polished, and then powdercoated, which is time and labor intensive, as opposed to the other die cast and injection molded parts. As always I say it is better to delay production and fix the cases than to accept the cases and keep to a schedule.
Offline Ellipse
« Reply #230 on: Wed, 05 August 2026, 15:54:26 »
For the Round 2 Beam Spring boards, I wanted to put a production status update all in one post for those reading the forums.  Generally everyone should feel free to email me if they have any questions not shown on the web site.
B104 - first batch in stock (Off-White/Beige, Red, Regular Gray cases).  Second and final batch arriving later this year (the remaining Black and Industrial Gray cases).  Expected completion by end of this month (August).
BSSK and B62 - expected completion in 6 weeks from now (mid-September)
B122 - expected completion by late October
Remember we have 2 months on a container ship after the factory completes them.  I expect the next container shipment once the BSSK and B62 are completed so that every board except the B122 arrives to me in November, and then a separate container shipment arriving in December for the B122s.  Thanks once again to everyone for their continued patience with this project.
Offline Ellipse
« Reply #231 on: Thu, 17 September 2026, 22:46:51 »
Beam Spring Project Update:
B104: The factory is finishing up final assembly this month; I am arranging a container shipment with the remaining B104's around the end of this month. The inner assemblies were completed some time ago but the cases needed a little more time for the issue described below.
B62 and BSSK: all inner assemblies have been fully assembled. Case production is ongoing. The factory has had difficulty meeting the project's welding, deburring, and powdercoating quality standards. I asked them to redo these parts even if it meant a delay and the additional time requirement was longer than expected, which is why it is later than what was noted in July. They need several weeks more than planned and expect to be done by the end of next month (October). I'll probably have another container shipment for this one unless the B104's end up needing a few more weeks (then they'd be finishing up around the same time in October and then they would travel together).
B122: The factory is focused on the other boards so for now they are still making the top and bottom inner assembly plates for the B122's; then they will assemble the inner assemblies, make the cases, and put the inner assemblies in the cases. They expect to be done by the end of November.
In summary, all boards except the B122 are still expected to be in hand by the end of the year; the B122 is now expected to arrive to me in January. As mentioned before, the factory understands the quality requirements and they are working as best as they can to meet them and complete the project as soon as possible. There are no issues with the actual beam spring mechanisms; the only issue at this point is with ensuring quality output with standard manufacturing operations related to the cases.
blackbit if the same key is causing issues, it may be better to replace the module with a spare instead of taking apart the board to fix it each time.
