Author Topic: Escape - f4 is not working please help  (Read 3568 times)
Offline Riftx
« on: Sat, 21 August 2021, 09:26:22 »
I was modding my razer black widow v2, plugging it in Esc f1 f2 f3 and f4 did not work when I plugged it in please help
Re: Escape - f4 is not working please help
« Reply #1 on: Sun, 22 August 2021, 18:39:07 »
No diodes and no visible traces - this will not be fun.
Do you have a multimeter or continuity tester?  If you do check to see if the upper or lower pins of the dead switches are connected (or at least Esc-F3 as F4 is possibly damaged) and if they are touch a wire from that pin (top or bottom) of F5 to the other pin on a dead switch and if you're lucky it will type the right key.
If that makes no sense let me know and I'll add some dots.
Offline Leslieann
« Reply #2 on: Sun, 22 August 2021, 21:09:16 »
That is a lot of splatter.
Clean off the splatter, it's possible some of that is causing a short.  I doubt that's the problem but it's possible and is hiding traces.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
