Author Topic: china shop that offers acrylics lasercutting?  (Read 3547 times)
Offline Eszett
« on: Mon, 23 August 2021, 23:15:18 »
I'm rather frustrated with shops that lasercut acrylic sheets in my country, they are expensive, and they have not much more than white and black in stock, not even matte, and not even in the thickness I need. Can you recommend a good and cheap china shop for acrylics? Wasn't able to find one ... but there must be tons?
Offline MIGHTY CHICKEN
Re: china shop that offers acrylics lasercutting?
« Reply #1 on: Mon, 23 August 2021, 23:43:04 »
You can find plenty on alibaba, just take your design and submit a general RFQ which many companies can pick up and then give you quotes. Just search "acrylic cutting services" or "custom cut acrylic" etc.
Offline 9gel
  • Trying to make it
« Reply #2 on: Wed, 25 August 2021, 21:31:53 »
Where in the world are you?
Given I'm in Hong Kong, I usually go to TaoBao and talk to vendors. They are real low cost. You do need to know Chinese thou... like this shop:
https://item.taobao.com/item.htm?id=526418754222&ali_refid=a3_430620_1006:1109923532:N:IWwN0g0gljOee%2B6O7XTTwFivR6Sav7Gv:0f4d6a084506da6be2c03585d4bdb1c6&ali_trackid=1_0f4d6a084506da6be2c03585d4bdb1c6&spm=a230r.1.14.8#detail
Otherwise it seems there are a few websites
https://www.sculpteo.com/en/lasercutting/
https://www.ponoko.com/
https://sendcutsend.com/
Or perhaps just get your own CNC machine and cut yourself, or a 3D printer.
Daily Driver: MakerDiary m60; Kailh box silent brown; ASCII control character code SA keycaps; wooden casing || chonkerkeys.com
