Author Topic: [IC] Phaethon - Solar powered through-hole PCB Kit. Prototype final!  (Read 10617 times)
Offline mrninhvn
Impressed by the beauty of the Lumberjack keyboard, I wanted to make a wireless version for myself, it's called Phaethon.
289978-0
Specs:
* 5x12 (split Preonic) layout, full grid or 2x2u spacebars.
* Fit in 60% tray mount case.
* Wireless USB receiver and Bluetooth 5.2 from receiver.
* Built-in solar battery charger, works with artificial light
* Ultra low energy consumption: ~1 year without any light or doesn't need to plug in the charger in a bright room.
* Switch footprint: Cherry MX, Cherry low profile, TTC low profile (KS32).
* Supported stabilizer: Cherry PCB Screw-in, Costar Plate mount for low profile.
* Assembled MCU + Solar board and USB receiver.
* All through hole components for keyboard PCB.
Firmware:
* ZMK
Price:
* 149$
Production number: ≤100.
IC Form: https://forms.gle/ZUm72Ac8P2t9jBvB8
[07/08/2022] Due to the PCB seeming too complicated for mass production and global chip shortage, I regret it will stop at prototype for now.
Design photos:
274838-1
Layout:
274850-2
Receiver:
276008-3
Solar and MCU PCB compatible with arduino pro micro and atmega32a pinout.
275563-4
« Last Edit: Sun, 07 August 2022, 06:20:34 by mrninhvn »
Offline thuc
Re: [IC] Phaethon - Solar powered through-hole 5x12 ortholinear PCB Kit
« Reply #1 on: Wed, 25 August 2021, 07:52:08 »
let's go
Offline d3adc3II
« Reply #2 on: Wed, 25 August 2021, 09:36:44 »
Awesome idea, hope it comes into life.
Offline missylo
« Reply #3 on: Wed, 25 August 2021, 10:14:55 »
So neat!!!
Offline Darth_munkee
« Reply #4 on: Wed, 25 August 2021, 11:20:03 »
I love this. 2 questions about it.
1. Will there be a way to store the wireless receiver on the board?
2. What is that component that sits just north of the resistors?
Specs:
Firmware:
* ZMK
Price:
* 149$
Design photos:
Layout:
Receiver:
Solar PCB test, solar charger works as expected:
Offline mrninhvn
« Reply #5 on: Wed, 25 August 2021, 11:25:47 »
Specs:
Firmware:
* ZMK
Price:
* 149$
Design photos:
Layout:
Receiver:
Thank you for your praise.
1. I haven't thought of it at the moment because it will fit 60% normal cases, i will also open source receiver so people can design cases for it. Also, I'm also planning for a smaller usb-c receiver.
2. That is toggle switch for on off power.
« Last Edit: Wed, 25 August 2021, 11:27:53 by mrninhvn »
Offline mrninhvn
« Reply #6 on: Wed, 25 August 2021, 14:24:54 »
Updated answer some questions.
1. What’s the case going to be like?
* Any 60% tray mount case, aluminum case is ok because of antenna is placed above PCB.
2. 2.4ghz instead of bluetooth?
* Both, 2.4ghz from keyboard to receiver, and bluetooth from receiver to other device.
3. Will you have an UK vendor?
* I'm afraid not, direct shipping from Vietnam.
Offline Arch4Life
« Reply #7 on: Wed, 25 August 2021, 22:52:38 »
nice design, glwic!!!
Sent from my SM-N960U using Tapatalk
Offline lingoc
« Reply #8 on: Wed, 25 August 2021, 22:59:58 »
Nice
Offline kaznai
  • Choc v1 are valid
« Reply #9 on: Thu, 26 August 2021, 01:44:31 »
Well this is freakin rad. Is that a supercap? Those scare me...
2 Corne, a Preonic, a Trailmix, and an older Rosewill
One big pile of MBK colored blanks; if I had red I'd recreate:
Offline mrninhvn
Re: [IC] Phaethon - Solar powered through-hole PCB Kit. Update Solar PCB!
« Reply #10 on: Tue, 31 August 2021, 12:05:21 »
Solar PCB has arrived, pinout compatible with pro micro and atmega32a  :cool:
275566-0
Offline mrninhvn
Re: [IC] Phaethon - Solar powered through-hole PCB Kit. Update PCB prototype!
« Reply #11 on: Mon, 13 September 2021, 09:35:26 »
PCB Prototype:
276006-0
Offline learntoletgo
« Reply #12 on: Sat, 23 October 2021, 06:23:27 »
looks good so far
Sent from my Pixel 5 using Tapatalk
Offline mrninhvn
Re: [IC] Phaethon - Solar powered through-hole PCB Kit. Prototype final!
« Reply #13 on: Sun, 07 August 2022, 06:29:21 »
Assembled in the sun.
289980-0
Offline AllieMaxwell
« Reply #14 on: Fri, 24 March 2023, 07:49:46 »
The Phaethon solar-powered through-hole PCB kit looks fantastic! It’s super cool that you’ve got the prototype all set. Solar power is an intelligent way to go, especially with everything around energy. I mean, who wouldn’t want to harness the sun’s energy? Plus, it’s great to see more DIY projects like this that can inspire others to get into solar tech. If you’re looking for tips or ideas, maybe check out solar panels ireland for inspiration. They have tons of resources that could help you refine your project. I can't wait to see how it all turns out! Keep us posted on your progress, and if you need a sounding board for ideas, I’m here for it!
« Last Edit: Wed, 16 October 2024, 07:12:42 by AllieMaxwell »
