Author Topic: La Baguette - 66% Keyboard - Starting at $250 - Shipped.  (Read 15419 times)
Offline EnjoyMyInSec
  • 60% or bust
« on: Wed, 01 September 2021, 03:42:37 »
La Baguette
Back in 2018, I decided to create my first custom keyboard ever. The idea behind it was pretty simple. Loving the HHKB and the FC660C as well as being French, I was like "Hey maybe we have something cool there ?".
This project wasn't my most accomplished one but for the time it was decent, accoustic and finish were nice but this board deserved better.
Renders and Pictures of the final product
Pricing and where to buy
Link will be updated once the Group buy is live
What's included with the keyboard ?
. Top piece
. Bottom piece
. Brass weight
. 2 Brass Blockers
. Screws
. Bumpons
. Stabs kit x1: 2Ux2, 6Ux1
. Plate : Brass or FR4
. Daughter board
. RGB PCB Hotswap or Soldered USB - C .
PS : Note that the PCB will be slightly different and should have a nice Baguette logo on it !
Extras
. Extra plate : FR4 or Brass
. Extra RGB PCB USB - C :Hotswap or Soldered
Case specifications
. Colors : Black - Grey - Forest green - E.White - Blue
.  Mounting system : Top mount with flex cuts
. Typing angle : 8 degree
. Dimension : 330 x 110 mm
. Materials used : Aluminum 6061 and Brass
. Weight : Case + Plate : 1.5kg
Plate specifications
. Plate material : Brass or FR4
. Plate thickness : 1.5 mm
. Plate finish : Sandblasted
. Layout : Fixed
PCB specifications
. Fixed layout
. QMK support
. RGB Hotswap or Soldered PCB
. USB - C daughterboard
Timeline
The Group Buy for la Baguette will start September 15th and will end on October 15th - This is an unlimited Group buy.
ETA : Will depend on the amount of units that will be sold during this period. If 200-500 keyboards sell, ETA should be around 6-7 months, but it could be more if we manage to go above this number, which is kinda hard to predict.
F.A.Q
Q : Will you add more layouts ?
A : No, this might be hard to hear for some people but that's in my opinion  how the keyboard should be used and looks the best, it is a design choice that I assume.
Q : Will you add more colors ?
A : For this round we won't add more colors but if the demand is there, we will for sure offer more in a future Group Buy ! We tried to have a good color selection to please as many people as possible.
Q : Can I order badges of different colors ? Do they only come in brass ?
A :  Yes they only come in brass for this round, but that may change in a near future if demand is there
Q :  Will you add more plates material ?
A :  For this round no, but I plan on making the plate files open.
Q : Will KBDfans will declare full value while shipping ?
A : Yes
Q : What shipping service will be used ?
A :  Fedex
Q : Is there anything you can do to use a 6.25 or a 7 U ?
A : I wanted to but due to the nature of blockers, I need them to be aligned / symetrical, and it's not possible with a non 6u spacebar without having bigger bezels.
Remerciements
. Thanks to KBDfans for trusting me on this project
. Huge thanks to my friend Scaevola The Chad to help me redesigning this board !
. Merci à toi, mon compatriote, mon ami, Biip pour avoir réalisé cette magnifique Baguette !
Socials
If you want to discuss about this project and want to know the future updates, please join my discord server and follow me on instagram !
« Last Edit: Wed, 23 March 2022, 04:25:46 by EnjoyMyInSec »
  • 60% or bust
Re: La Baguette - 66% Keyboard - Starting at $250 - [Sep. 15th - Oct. 15th]
« Reply #1 on: Wed, 01 September 2021, 03:43:35 »
The boards are shipped, thanks a lot for your support, enjoy you boards  :thumb:
« Last Edit: Wed, 23 March 2022, 04:26:25 by EnjoyMyInSec »
« Reply #2 on: Wed, 01 September 2021, 15:39:35 »
Approved :thumb:
Offline crusader_alex
« Reply #3 on: Wed, 01 September 2021, 15:43:53 »
oulala
« Last Edit: Wed, 01 September 2021, 15:46:05 by crusader_alex »
Offline biip
    • @biipmk
« Reply #4 on: Wed, 01 September 2021, 15:44:56 »
Offline mvkb
  • Designer
    • MVKB
« Reply #5 on: Wed, 01 September 2021, 15:47:52 »
I support weird layouts like this. GLWGB!!
Offline paperassgasket
« Reply #6 on: Wed, 01 September 2021, 16:43:11 »
Offline sagarsiddhpura
« Reply #7 on: Thu, 02 September 2021, 02:03:34 »
Honestly, KBDFans is not the best choice for vendor. I hope you get better vendors in next round. Good luck with GB
Offline darthcapn
« Reply #8 on: Thu, 02 September 2021, 02:41:11 »
The weight is lit
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline AnonymousPlatypus
« Reply #9 on: Thu, 02 September 2021, 05:12:16 »
Really, Baguette keyboard but no ISO layout? :'(
  • 60% or bust
« Reply #10 on: Thu, 02 September 2021, 05:47:30 »
Yeah, my goal was to mix the FC660C and the HHKB, then Iso wasnt an option. Its sadly far from my vision of the board and I did some tests, I think it dosen’t look that great on this specific layout.
You still can use it ! I type on Azerty using split backspace, it’s really confortable  :))
Offline FishyBuisnessmn
  • Inverted space bar gang
« Reply #11 on: Thu, 02 September 2021, 05:51:15 »
Ok, so you're french from France, right ? And you didn't add ISO support ? This is not funny, not funny at all. What kind of sick twisted joke is that ? Btw, looks very good but needs SS weights and blockers, not buying until then
Offline mr_foggy
  • neue = nope
« Reply #12 on: Thu, 02 September 2021, 07:56:24 »
6U spacebar means most base kits will be unsuitable for this board.
consider making it 6.25U. it won't disrupt the board design and would make it more marketable.
Offline RoyalOak88
« Reply #13 on: Thu, 02 September 2021, 08:33:02 »
I see some pictures with a white blocker. Will this be an option or all the colours will be brass?
Offline sefixmm
« Reply #14 on: Thu, 02 September 2021, 08:53:02 »
Second that !
Offline Dinerenblanc
« Reply #15 on: Thu, 02 September 2021, 08:54:40 »
Love the theme, bit of a shame about that layout though . . .
  • 60% or bust
« Reply #16 on: Thu, 02 September 2021, 08:57:25 »
As written in the OP, only brass will be available  :thumb:
Second that !
As said, its a design choice based on the HHKB and the FC660, its a choice to ditch ISO, it sincerly looks not the greatest on this keyboard
  • 60% or bust
Offline ravermeister
« Reply #18 on: Fri, 24 September 2021, 04:59:12 »
fixed plate + fixed PCB is super hot.
I get how this layout might not appeal to everyone, but I rather see something new than the 13th 65% with a blocker.
Offline TeslaFan
« Reply #19 on: Thu, 14 October 2021, 20:52:10 »
HHKB / FC660 frankenboard is actually a cool idea. Reserved.
