Author Topic: key switch puller?  (Read 2810 times)
Offline Eszett
key switch puller?
« on: Sat, 04 September 2021, 22:51:25 »
I'd like to buy a switch key puller ... which one is best - in your opinion?
« Last Edit: Sun, 05 September 2021, 00:09:40 by Eszett »
Re: key switch puller?
« Reply #1 on: Sun, 05 September 2021, 08:11:55 »
https://geekhack.org/index.php?topic=105982.msg2894334#msg2894334
Every switch is different. Orihalcon sells Alps pullers.
https://www.ebay.com/itm/303522186463?hash=item46ab5504df:g:hwIAAOSw1W5eeRn5
edit - I don't use MX style switches and don't really know much about them
« Last Edit: Sun, 05 September 2021, 10:16:27 by fohat.digs »
- D Trump 2026-10-24
Offline Eszett
« Reply #2 on: Sun, 05 September 2021, 09:02:41 »
The linked thread is AFAIK more about keycap pullers I mean a keyswitch puller, for a Cherry MX compatible switches.
Offline Darthbaggins
  • PC Cannibal
« Reply #3 on: Wed, 15 September 2021, 14:57:45 »
The Rama one works well but pretty much search MX style switch puller on Amazon - Also check Kinetic Labs, Novel Keys and any other board part retailer/e-tailer for them.
« Last Edit: Wed, 15 September 2021, 15:01:39 by Darthbaggins »
