Author Topic: When people ask about the typing height of a keyboard where do you messure from?  (Read 5784 times)
Offline Blitzschnitzel
Since keycaps are also different hetghts and at an angle, what is the standard fix point here?
« Last Edit: Sun, 05 September 2021, 12:15:49 by Blitzschnitzel »
Still interested in the answer. ;)
Offline _rubik
I've always thought the most important measurements are 1) typing angle 2) height of the front bezel (desk to "lip) 3) board depth
From that we can figure out 1) the back height 2) typing height (cap + bezel height)
I suppose you could also figure out home row height if you make the assumption that 0.5 * depth == home row
Offline Leslieann
Front height is from desk to top of keycap, this and angle are for ergonomic reasons, not aesthetics.
ISO standard are:
0-15 degrees tilt, preferably 5-12
Keyboard height from desk to top of keycap, MIDDLE ROW should not be more than 30mm.
I believe Japan states the front caps need to be 30mm from desk to top of cap.
This actually means many, if not most high end keyboards are at the limits or out of spec while taller boards like the Keychron K2 (and those like it) way out of spec.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline _rubik
ISO standard are:
Isn't that measurement variable depending on the caps you choose? Sure, if you're manufacturing a keyboard that's sold as a complete unit, adhering to standards is useful. But the difference between, say, SA and LP could be statistically significant.
I guess it also matters from which perspective Blitz is asking the question: a keyboard designer or a consumer sharing the specs of their latest build
« Last Edit: Tue, 21 September 2021, 21:46:59 by _rubik »
Offline Leslieann
ISO standard are:
Yes, but what alternative is there?
On some boards there is no plate, other boards the switch height itself is different.  Where you going to measure a Topre with or without MX caps from? Buckling Spring? How would that translate across to an MX with no switches at all?
Nothing is equal across boards, and more importantly, total height is ultimately what you need anyhow. You may be trying to arrive at it in a different way, but ultimately that's the goal.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Thanks, you helped me a lot. There should be a standard. Like, top of a Cherry key cap on the home row.
