Author Topic: [IC] DSA PetriKeys ✨ | GB April 5 | Final Kitting + Collaborations Announced!  (Read 79747 times)
Offline geewiz
Re: [IC] DSA PetriKeys ✨ | GB Date Announced + Updates
« Reply #50 on: Thu, 17 February 2022, 11:24:51 »
Looks nice! Can the ortho have two 1.5U space bar keys?
If I'm not mistaken, the 1.75u ones aren't commonly used and could be replaced in the ortho kit.
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #51 on: Mon, 21 February 2022, 22:24:10 »
There is no size given on the spacebars in the TKL Mods. Are those 2.25u and 2.75u, thus Alice compatible?
Offline yooj.key
« Reply #52 on: Wed, 23 February 2022, 09:38:47 »
oop sorry about that, I'll relabel them...but yes they are compatible!
Offline yooj.key
Re: [IC] DSA PetriKeys ✨ | GB April 5 | Collaborations Announced!
« Reply #53 on: Wed, 23 February 2022, 09:43:42 »
02.23.22 UPDATE
Collaborations announced!
Offline Eoen
« Reply #54 on: Thu, 24 February 2022, 12:55:52 »
GB let's gooooo!!
Offline yooj.key
« Reply #55 on: Mon, 07 March 2022, 11:04:48 »
03.07.22 UPDATE
  • Added deskmats
Offline yooj.key
« Reply #56 on: Mon, 07 March 2022, 11:06:14 »
Hello hello! Thank you! Which keyboard are you looking into for the 1.5U spacebars?
Offline rndr
    • Keyboard Enthusiast Writeups
« Reply #57 on: Mon, 07 March 2022, 11:58:40 »
Excellent kitting. What would be the ETA for this after GB?
Offline jiminojimi
« Reply #58 on: Tue, 08 March 2022, 04:56:27 »
I'm keen
Offline geewiz
« Reply #59 on: Wed, 09 March 2022, 15:14:26 »
For example, if you build the inner thumb keys of a Corne keyboard with 1.5u caps, they can be more comfortable to hit. 1.5u caps don't require stabilizers yet, and don't interfere with alu cases like the IMK ones.
Offline sagenju
« Reply #60 on: Sun, 13 March 2022, 23:13:22 »
I just noticed that the coloured Tilde is not included in the kit render but displayed on the keyboard render. Was it removed or just missed on the kit layout?
Offline yooj.key
« Reply #61 on: Thu, 17 March 2022, 11:10:22 »
Thanks for the catch! Will update, the tilde should still be in the kit render.
Offline yooj.key
« Reply #62 on: Thu, 17 March 2022, 11:17:52 »
I see, thank you for the explanation! At this time I would suggest using the novelties, because I have not gotten a lot of feedback about adding 1.5us , and SP cannot do convex 1.5u caps so I am not sure how much adding those to the spacebars kit would help.
Offline yooj.key
« Reply #63 on: Thu, 17 March 2022, 11:20:48 »
03.17.22 UPDATE
  • Kitting renders updated (TKL, Homing, Intl)
Offline glibber
In the international kit, the "ß" seems too large and not correctly alligned. It should be a tall lowercase letter, so I'd expect it to be the same height as and aligned with the numbers in the numrow.
    • Twitchy Homepage
Read the note directly below the picture:
> *International kit will be using SP's current molds, this picture is more for representation of legends.
Intl kit based off of NoPun10did's DSS Late Harvest
Offline yooj.key
03.31.22 UPDATE
Hello hello everyone! Hope you are doing well...with the GB coming up next week, I have updated the final kit renders as well as the collaborations! Pricing will be up soon as well.
  • Kitting renders
  • Collaborations
« Last Edit: Sun, 03 April 2022, 23:27:51 by yooj.key »
Offline yooj.key
04.03.22 UPDATE
EU Vendor has been announced! I am pleased to be working with Lykko Studio as the EU vendor for PetriKeys.
Final collaboration list has been updated as well! Look out for the GB post on the 5th!
Thank you for all the support so far, it means a lot.
I am hoping pricing will be done before GB, but no guarantees at this point unfortunately. Sorry about that!
  • EU Vendor
  • Collaborations
Offline MattVortex
Is there an update on the GB?
