Author Topic: How do silenced Topres work?  (Read 2220 times)
Offline bhchiang
« on: Thu, 09 September 2021, 23:35:28 »
I'm new to the community. I recently bought my first Topre board (Realforce R2 PFU Limited), which is silenced (I also tried the regular, non-silenced R2 with variable weighting).
I'm curious about how the silencing mechanism works - what is physically different about the switches that results in the silencing?
Any links / thoughts would be appreciated.
One link I saw: https://deskthority.net/viewtopic.php?t=16610.
Offline Tactile
Re: How do silenced Topres work?
« Reply #1 on: Fri, 10 September 2021, 00:26:20 »
There's a ring of soft material added to the slider so that on the upstroke this softer material makes contact instead of a hard plastic-to-plastic impact. In this illustration this softer material is shown in green.
275930-0
REΛLFORCE
Offline didjamatic
« Reply #2 on: Fri, 10 September 2021, 11:20:04 »
Quietly. :)
Offline sublyme
  • sublyme_keys
« Reply #3 on: Tue, 14 September 2021, 20:30:18 »
While the silencing rings make it nicer to type on its not really what I would call silenced. Not close to anything like what you would get with mx slient blacks.
Offline Riverman
« Reply #4 on: Wed, 15 September 2021, 00:57:44 »
I have both silent Topre and silent MX black keyboards, and they're pretty similar, although the MX black is probably a little quieter.  Neither one is exactly silent, but for mechanical keyboards, they're both pretty quiet.
