Author Topic: Mysterium mega32a not recognized after Bootloader [REMOVE]  (Read 2774 times)
Offline Radiaren
« on: Sat, 11 September 2021, 13:58:35 »
New member, but not new to MK's.
I have been trying to build my own Mysterium with a ATMEGA32A controller. I have fumbled around trying to follow the steps necessary to make a bootloader .hex file and then flash it. I eventually found this https://geekhack.org/index.php?topic=107870.0 old thread on geekhack which I think got me over the hump on finding a .hex file and flashing it to the controller.
I have been using a USBtiny along with ARVDUDESS to verify that the fuses are correct and the bootloader is flashed. I have done this process on two different controllers. However, when I try to connect them via USB instead of ISP header I cannot get it to show up on device manager or in the QMK software. I have even gone so far as to recreate the circuit on a bread board as an easy way of double checking everything.
Is there anything that I am missing that is preventing me from viewing the chips via USB? Do I need some drivers or something? (Running Win10 btw.)
EDIT: I figured out the wiring issue. Please remove post.
« Last Edit: Sat, 11 September 2021, 19:13:41 by Radiaren »
