Author Topic: [GB] Block-67: The budget 65% Gasket Mount - GB ended  (Read 9029 times)
Offline ENG Studio
    • Discord
« on: Sun, 12 September 2021, 08:49:20 »
Block-67: The budget 65% Gasket Mount Full CNC Aluminum Keyboard
Hi everyone! We have just launched our second group buy - Block-67. This board aims to offer a package with all the features the community loves at an accessible price, and without the hollow sound that most budget gasket mount boards have. Sound Test Here
Features and Specifications:
- 65% Layout with arrow blocker
- Gummy worm O-ring gasket mount
- Screw-in stabilizer support (inc. Durock V2)
- VIA Compatible PCB
- USB-C daughterboard
- Seamless case design
- 7 Degree typing angle
- <17mm low front height
- Universal 8mm diameter rubber feet
- Plate cutouts for easy disassembly with your standard wired keycap puller
Group Buy Details:
- 200 A-stock units
- Small number of B-stock units available
- Group buy runs from 12/9 to 25/9
- Lead time of 3 months
- Group buy website: ENGstudio.co
Kit Includes:
- E-white or Anodized Black CNC aluminum keyboard case
- Solder PCB
- FR4 Plate
- Daughterboard, with accompanying screws and cable
- 4x Universal 8mm rubber feet
Pricing:
Block-67 A-stock kit (E-White or Black): 144
B-stock kit: 139
Extras:
Foam kit: 18
Daughterboard: 7.5
FR4 Plate: 10
PCB: 35
Durock V2 Stabilizers: 17
Layouts:
Standard or Split Backspace
Standard or Stepped Caps Lock
ANSI support only
Standard 6.25u bottom row only
Sound test:
Join our Discord for updates
« Last Edit: Sun, 01 May 2022, 09:31:14 by ENG Studio »
Offline ENG Studio
    • Discord
Re: [GB] Block-67: The 144 USD 65% Gasket Mount - GB 12th to 25th of September
« Reply #1 on: Sun, 12 September 2021, 08:49:31 »
Updates:
2/10: GB ended with all A-stock units sold. B-stock units are available for pre-order on our website. Orders for parts have been placed. The estimated delivery time of 3 months from GB end still holds.
27/5: Forgot to update Geekhack for a few months. All units have been shipped in January.
« Last Edit: Fri, 27 May 2022, 16:33:00 by ENG Studio »
« Reply #2 on: Sun, 12 September 2021, 15:22:01 »
Approved :thumb:
Offline totalemon
  • good morning :)
« Reply #3 on: Tue, 14 September 2021, 21:26:05 »
This looks really good, especially for the price. Just wondering if there are any renders of the bottom?
Offline ENG Studio
    • Discord
« Reply #4 on: Wed, 15 September 2021, 16:44:48 »
Unfortunately not, but the bottom is kept minimal with just the slots for the 4 round rubber feet.
Offline bricks
« Reply #5 on: Thu, 16 September 2021, 23:08:03 »
Sounds good, Round 2 is supposed to be launched promptly after R1 right?
Offline ENG Studio
    • Discord
« Reply #6 on: Fri, 17 September 2021, 09:44:31 »
Yes. We will send review units to streamers in round 2, so the R2 schedule will be based on that.
Offline dante257
« Reply #7 on: Mon, 27 September 2021, 15:59:58 »
Maybe ISO Support for R2?
Offline ENG Studio
    • Discord
« Reply #8 on: Sat, 02 October 2021, 12:54:22 »
Yes, definitely!
