Advanced search
typing on a cloud of . . .
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
NEW USERS, READ
THIS!
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Marketplace
Group Buys and Preorders
(Moderator:
Signature
[GB] R2 Z40-Pastry 40% full-kit Quarkeys
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [GB] R2 Z40-Pastry 40% full-kit Quarkeys (Read 4668 times)
tommyamoszhao
Thread Starter
on:
Tue, 14 September 2021, 00:09:21 »
Hi, Geekhack! We are excited to announce that round 2 of Z40-Pastry had started. Round 1 GB started on 15th Jul, finished on 15th Aug, production of R1 starts on 2nd Aug(most of the orders happened in first half of R1), thx to full support from factories, we managed to pull off the R1 production way ahead of time, Now, Z40s of R1 is going to be shipped on 15th Sep. We'd like to shout out a big THANK YOU for all the trust and support from buyers.
R2 had already started on 4th Sep, and will end on 4th Oct, lasts a month. We'll place the production order according to situation of sale, lead time is NO MORE THAN 60 days depending on order quantity and factory schedule.
Upgrades from origin IC of Z40-Pastry
Keyboard PCB is no longer lowpro switches exclusive, switch compatibility enlarged to compatible with
regular MX switch, Kailh V1 & V2, Cherry lowpro and TTC lowpro.
Brass stand-offs included in case regular switches is the consideration
Poron Case foam is included
Poron PCB foam is included
A new 'Taro' color Ceramic coating has joined R2 GB
Build and Review videos of Z40-Pastry engineering samples
Thockit channel build & review
Zen the Geek channel build & review
Wan Syazlina channel build & review
Group Buy link
Discord
Dimension:
0°, without brass foot is: 236*84*21mm (height 19.97 without silicon foot pad)
5°, with brass foot is: 236*84*26mm
Specs:
Designed by Quarkeys Studio
QMK driven, VIA support
Infrastructure: Bottom mount with soft dampener
5° or 0° typing angle
Custom PCB design, switch type compatible with all regular MX switch, Kailh V1 & V2, Cherry Lowpro, TTC lowpro
TTC lowpro comes with the package is Modded switch, caps are raised by 0.8-1mm to avoid the most commonly known plate-hitting problem, DSA, XDA, SA cap types were tested and worked perfectly.
Per-Key SMD RGB light
Centered type-C USB socket
Firmware: Custom version downloadable with layer indicator & VIA enabled
original version downloadable without layer indicator
Weight: 480g with brass foot(5° typing angle), 331g without it(0° typing angle)
With caps, rear-height is 2.6CM with brass foot, 2cm without it.
Case Material:CNC Aluminum
Color currently available: Anodized Black, Anodized Dark Blue, E-White, Ceramic Pink, Ceramic Sky Blue, Ceramic Taro
Kit Include:
Key Switches (Modded TTC lowpro) x50pcs(3 extra)
2U PCB-mount low profile Stabiliser x1pc
XDA PBT Key Caps (BoW legends) x1set
Case x1pc: Aluminum CNC machined with glass-blast finishing
Switch Plate x1pc: default is FR4, optional with Carbon Fiber and Brass
Solder PCB x1pc: Compatible with regular MX switch, Kailh V1 & V2, Cherry Lowpro and TTC lowpro
Case Foam x1pc: place between case & pcb
PCB Foam
Accessories:
USB-C Cable x1pc
Screws: M2*5 Titanium coated flat head x6(2 extra); M3*5 Nickel coated flat head x6(2 extra)
Cushion Pads x4pcs: place between case post and switch plate
Silicone foot pads x8pcs, 4 extra when foot mounted, 2 extra when foot removed
USB-C Cable x1pc
Optional Parts:
Switch Plate: Carbon Fiber(Matte surface) or Brass(Send Blast finishing)
Optional Foot: Brass(PVD Mirror finishing)
Pricing:
Default Package: FR4 plate; no foot(0° typing angle); everything else;
$184/kit
Brass Plate (in order):
+$10
, extra brass plate:
$15/pc
Brass Foot (in order):
+$20
, extra brass foot:
$25/pc
Color: E-White, Ceramic Blue/Pink/Taro:
+$7
Extra TTC lowpro Switches(Modded): 50pcs:
$30.5
Extra set of keycaps:
$50
Timeline & Notice:
R2 Group Buy link opened on 4th Sep 2021, lasts a month till 4th Oct.
Latest updates will be always in
discord
first.
No Minimum OQ.
Lead time: estimated production time is the second day R2GB finishes, then 60days lead time is expected, actual shipping day could be ahead of schedule.
Logged
Signature
master of puppers
Moderator
snoozing
Re: [GB] R2 Z40-Pastry 40% full-kit Quarkeys
Reply #1 on:
Tue, 14 September 2021, 06:45:12 »
approved
Logged
tommyamoszhao
Thread Starter
Reply #2 on:
Wed, 29 September 2021, 02:03:16 »
R1 users had received their Z40s, we'll keep posting their proud build
Logged
ShandonCodes
Reply #3 on:
Thu, 30 September 2021, 12:53:24 »
I love the simplicity here, really make you appreciate the core of the ortho layout.
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
(Moderator:
Signature
