Author Topic: Any keycap suggestion for e-white tofu 65% build?  (Read 6423 times)
Offline Kris5105
« on: Tue, 14 September 2021, 06:11:49 »
I am thinking of building a keyboard
Case: Tofu 65% E-White
PCB: Hot-Swap DZ65RGB v2
Stabilizer: Durock Stabilizer V2 PCB Mounted Screw-in
Plate: Aluminium
Switch: Banana-split + Lavender
I currently have 3 keycaps only
1. GMK Laser
2. Akko Neon
3. NP Crayon PBT
So, I want to know if there are any interesting keycaps to use with the new build. ;)
Ps. Ready to ship would be nice  :(
Offline MIGHTY CHICKEN
Re: Any keycap suggestion for e-white tofu 65% build?
« Reply #1 on: Tue, 14 September 2021, 14:06:36 »
Epbt bow perhaps, or MT3 BOW
Offline Kris5105
« Reply #2 on: Wed, 15 September 2021, 01:52:54 »
A minimal white theme? Looks good to me. Thanks! :thumb:
Offline ShePearl
« Reply #3 on: Thu, 16 September 2021, 05:05:21 »
I have ePBT X GOK BOW on my E-white Tofu65 build.
Looks and feels nice.
Offline Kris5105
« Reply #4 on: Thu, 16 September 2021, 10:52:31 »
It looks stunning.
Do you have any suggestions for pink theme keycaps?
Can you tell me the specs? (Sry,for bad grammar)
« Last Edit: Thu, 16 September 2021, 21:58:44 by Kris5105 »
« Reply #5 on: Thu, 16 September 2021, 11:13:51 »
Milkyway PBT 02 is live rn I think
Offline ShePearl
« Reply #6 on: Thu, 16 September 2021, 21:17:58 »
It looks stunning. :eek:
Sorry, I don't have any suggestions for pink as the color is not my cup of tea. :)
As for the specs of my Tofu65:
- E-White
- DZ65RGB V3 hot-swap PCB
- Tealios V2 67g switch
- Gateron PCB mounted screw-in Ink Black stabilizers
- Brass plate
- Deskey switch film
- Krytox GPL205G0 for switch slider
- Krytox GPL205G2 for stabilizers
- PCB foam
- Stupidfish case foam
- O-ring mount mod
- ePBT X GOK BOW keycaps
- Brass weight
Offline Kris5105
« Reply #7 on: Thu, 16 September 2021, 21:53:53 »
- E-White
- Brass plate
- PCB foam
- O-ring mount mod
- Brass weight
Wow, that's a good keyboard right there :).
I will start building my own Tofu65 today. (I hope, I won't make any mistakes TT)
Thank you for your suggestion and build!
« Last Edit: Thu, 16 September 2021, 21:57:55 by Kris5105 »
Offline Kris5105
« Reply #8 on: Thu, 16 September 2021, 21:56:50 »
I already saw it once but I think its too pinkish (I'm not sure if this makes sense to you  ^-^)
I want to build like a white-sakura theme.
So I'm watching Akko Tokyo keycaps.
Thanks for the suggestion :)
