Author Topic: need help key not working after desoldering keychron k2 non hot swappable  (Read 3138 times)
Offline gurukedua
hey guys newbie just messed up with the key after desoldering. Trying to replace switch but ended up damage it (probably).
after some googling found this thread https://geekhack.org/index.php?topic=113529.0
same brand keychron , but mine is k2 non hot swap.
broken key is top right for changing rgb light mode
here is my keyboard
how do I bridge like from this thread https://geekhack.org/index.php?topic=113529.0 , I dont know which should be bridge it
any help appreciate it , thank you in advance
Re: need help key not working after desoldering keychron k2 non hot swappable
« Reply #1 on: Fri, 17 September 2021, 15:49:15 »
It's black as usual with Keychron so I'm guessing - touch a wire between the orange pin and the cyan diode and it should activate the dead key.  If it does touch orange to pink pins, if that doesn't work solder a short wire between the pink pin and cyan diode.  If the switch still doesn't work also solder a wire between the orange and green pins.
If orange to cyan doesn't work please post a pic with the shiny bit (right of the 2020 in this pic) over the dead key, hopefully something weird is visible.
Offline gurukedua
« Reply #2 on: Fri, 17 September 2021, 20:26:04 »
it works!!! I did what you said , orange to pink pins, a short wire between the pink pin and cyan diode. Thank you so much!! :)
