Author Topic: [IC] KAMistry - Group Buy October 10th - November 10th, 2022!  (Read 66430 times)
Offline prconlin
Re: [IC] KAMistry - Update: Digital Carpentry wrist rest collab, with samples!
« Reply #50 on: Sat, 01 January 2022, 11:00:05 »
A few of the symbols are incorrect on the periodic alphas.  Xenon should be Xe, dubnium should be Db, and thulium should be Tm.  Maybe these were changed for aesthetic reasons, but there are a number of other two-letter symbols like Li included, so I'm not sure why some were changed and not others.  In any case, I would prefer the periodic legends be as correct and consistent as possible.  I would also like to nominate titanium for the 'T' key over thulium.
I'm also in the camp that the electron orbital number novelties should not have secondary legends.  That would really mar the aesthetic.
Offline NintendoNoNo
« Reply #51 on: Wed, 05 January 2022, 02:29:50 »
60s definitely need more split space options. I always use left space for shift and right space for space. I use split boards mostly, so whenever I go back to using a board with a full spacebar, my brain has to do some adjusting haha
« Reply #52 on: Wed, 05 January 2022, 22:02:33 »
Yep! Those fixes have all been made apparent and fixed already. I just haven't updated the post yet. The periodic alphas kit was VERY last minute before posting the IC. I did it very quick before posting and unfortunately that resulted in some glaring mistakes.
Re: [IC] KAMistry - Update: PRICING ANNOUNCED, plus new render!
« Reply #53 on: Tue, 11 January 2022, 23:28:15 »
Update: Added new kit and new render
« Last Edit: Wed, 12 January 2022, 00:57:21 by NintendoNoNo »
Offline Klackygears
Re: [IC] KAMistry - Update: New novelty kit and new render!
« Reply #54 on: Mon, 24 January 2022, 20:16:32 »
Really looking forward to this set!
Re: [IC] KAMistry - Update: Slight kitting changes
« Reply #55 on: Mon, 07 February 2022, 15:56:13 »
Update: Fixed a few issues with the kitting, including changing homing to scooped instead of bars. Also, I believe all mistakes on the periodic alphas should be fixed now!
Re: [IC] KAMistry - Update: GB DATE ANNOUNCED! - March 1st - April 5th
« Reply #56 on: Mon, 14 February 2022, 11:09:01 »
Update: GB date announcement
Offline HelloThisIsDog
Re: [IC] KAMistry - Update: GB DATE/PRICING ANNOUNCED! - March 1st - April 5th
« Reply #57 on: Mon, 14 February 2022, 23:14:59 »
I love the periodic alphas!
What is Keyreative saying about production times?
Offline vkeycaps
  • Artisan keycaps maker
    • Website/Store
« Reply #58 on: Wed, 16 February 2022, 14:14:21 »
Looks awesome! Love it
« Reply #59 on: Thu, 17 February 2022, 14:59:05 »
Thanks so much! Last we heard back in October they were still quoting a 1 year turnaround. However, I think that is unreasonable to assume given the state of the hobby at this point. In my opinion, a lead time of 1.5 years is a decent estimate so we are quoting Q3 2023. Could be sooner, could be later, but considering all manus have taken longer than quoted times, I want to try to give a realistic estimate if possible.
Re: [IC] KAMistry - Update: GB date/pricing and French kitting announced
« Reply #60 on: Sun, 20 February 2022, 17:49:19 »
Update: Added French kit
Offline Mr Chrome
« Reply #61 on: Sun, 20 February 2022, 23:39:28 »
This is a good approach. It’s definitely closer to a 1.5 year production time for Keyreative, seeing as Cyberspace ran ‘til September 2020 and is still making its way to vendors. It’s possible the wait time could go down in future though, seeing as a lot of designers aren’t jumping to design sets with them.
Really cool set too! IMO the text novelties clash a bit with text mods, but I like that there are so many choices. Great work with the accent colors, I can’t decide my favorite :confused:
“This plastic rectangle is alright. The plastic rectangles on top of it, though...”
Offline BareSphereMass
« Reply #62 on: Mon, 21 February 2022, 22:25:04 »
This looks cool.  I really like the periodic alphas, the picture novelties and the colored accents.
The Deskmats leave a little to be desired.  I think either a graphic of an exploded chemistry lab, or a literal periodic table of elements could be cool.  Also the 900x400x2mm desk mats are too thin, the 900x400x3mm are way better.
If you could work a brass or metal key cap option in there too, that would be awesome.
Current Keebs:  Atreus 42 (hand wired)  |  Anne Pro 2  |  Prime_E  |  Prime_Meridian
Next Keebs:  Polycarbonate Alice  |  Type-K  |  Wood Case Keeb
Current Keycaps:  OEM (POM & PBT)  |  SA R3 (PBT)  |  DSA (PBT)  |  MT3 Camillo  |  GMK Apollo  |  Deskr Canyon Caps  |  MT3 LotR Elvish  |  GMK Civilizations
Current Artisans:  Dwarf Factory Artisans (2x)  |  Rama x Keycult Brass (1x)  |  Holyoops D.VA Aluminum (cherry R4)  |  Walnut OEM R4  |  3D Printed Pikachu
On Order:   GMK Pharaoh (est. April 2024)
Other:   ZealPC Clickiez
« Reply #63 on: Tue, 22 February 2022, 23:04:08 »
For the deskmats, I talked to a ton of people and they all agreed that simpler was better. I was going to commission an artist for one originally, but the general trend is that mats with lots of artwork don't really sell all that well. Not that I'm in this for the money, but just the fact that commissioning people is expensive. I made these mats myself and I am definitely no artist (I'm a scientist!), but I hope they are simple enough that enough people enjoy their aesthetic. As for the periodic table idea, I also wanted to do that but another set already has mats like that and I didn't want to steal the idea.
Also, there are two metal caps in the work that should be announced just before the GB! Just waiting on the final renders of them.
« Reply #64 on: Wed, 23 February 2022, 14:39:12 »
Update: NZ Caps artisan rotary encoder knob announced
Offline LightenS
Re: [IC] KAMistry - Update: Artisan rotary encoder knob and GB date/pricing!
« Reply #65 on: Thu, 24 February 2022, 12:53:31 »
Typo for Xe
Xeon => Xenon
« Reply #66 on: Thu, 24 February 2022, 12:55:47 »
Typo for Xe
Xeon => Xenon
Thank you for catching that! I asked lot of people to double check all these and nobody caught that. I will make sure that is fixed right away.
« Reply #67 on: Thu, 24 February 2022, 22:02:25 »
Okay, should all be fixed now!
Offline Razer1987
« Reply #68 on: Fri, 25 February 2022, 09:15:00 »
In for French!!!
Re: [IC] KAMistry - GB briefly postponed, please read!
« Reply #69 on: Mon, 28 February 2022, 16:44:52 »
Update: postponement
Offline hulster
« Reply #70 on: Tue, 08 March 2022, 14:17:17 »
What´s the issue?
Re: [IC] KAMistry - Artisan enter and artisan knob announced!
« Reply #71 on: Tue, 08 March 2022, 16:01:07 »
Update: Otakeebs enter artisan
« Reply #72 on: Tue, 08 March 2022, 16:02:37 »
What´s the issue?
We are just waiting to hear back from Keyreative and get a final confirmation that the legends will all be printable. We thought we would have heard back before the date the GB was originally set for, but unfortunately that wasn't the case.
Offline Extra Fox
  • quis qui sais
« Reply #73 on: Tue, 08 March 2022, 22:34:27 »
That "Aluminum" enter key is absolutely awesome.
A-a-ron
Offline hulster
« Reply #74 on: Wed, 09 March 2022, 02:11:14 »
What´s the issue?
Thx. Sorry for initially bothering. Didn't see your update on the start page.
« Reply #75 on: Wed, 09 March 2022, 12:59:31 »
What´s the issue?
No worries! I tried to make it visible, but also everyone formats their Geekhack posts slightly differently, so I don't blame for you checking in the comments for the reason.
Offline LightenS
« Reply #76 on: Thu, 24 March 2022, 18:24:23 »
still no updated?  seem like COVID punched Zfrontier in the face...
« Reply #77 on: Mon, 28 March 2022, 22:35:57 »
Sorry for my late reply! We did get one update from them, and they confirmed the legends for the kits will be printable. However, they still need to give us one more price quote (for the French kit). We have tried messaging them again to remind them we are waiting on it...
Offline Lincolnworks
    • In progress
« Reply #78 on: Thu, 31 March 2022, 19:45:05 »
KAM isn't really my thing but I do like the design and art style  :thumb:
Offline ILogger
« Reply #79 on: Tue, 10 May 2022, 13:00:17 »
Any news? I love this keycaps design and wanna have them already  ;D
« Reply #80 on: Sat, 25 June 2022, 20:02:36 »
Sorry for the incredibly late response! I’m much more active on Discord than on here, so I get around to answering questions there about 1000 times faster haha. But yes, we did hear back from Keyreative! They were in lockdown due to COVID and didn’t have access to their messaging services because of it. So hopefully now that they’re back to work we can move forward with the GB. According to them, the first round of samples should be on the way to me. Granted, some of the Pantone colors have changed since I submitted for those samples over a year ago, but it will at least be nice to check on the detailed lines, which I want to do since it’s reverse dye sub.
Re: [IC] KAMistry - Group Buy on October 10th, 2022!
« Reply #81 on: Fri, 02 September 2022, 12:02:31 »
Update: GB date announced
Offline hulster
« Reply #82 on: Fri, 02 September 2022, 13:59:35 »
 :thumb:
Offline DontStealMyLolipop
« Reply #83 on: Fri, 02 September 2022, 14:51:19 »
I'm in  ;D
Offline FitLabb
    • FitLabb
« Reply #84 on: Fri, 02 September 2022, 20:29:36 »
Glad to see this set back up with a GB date this Fall! Been waiting and hoping this set would come to fruition as it’s too good to not be produced!
Founder of FitLabb.com - an online fitness & nutrition platform
YouTube - FitLabb
« Reply #85 on: Sun, 18 September 2022, 10:12:07 »
Just so everyone knows, the Fluorine spelling mistake has been fixed. Thanks to all who have pointed it out and sorry about that!
« Last Edit: Tue, 20 September 2022, 02:07:08 by NintendoNoNo »
Offline dededecline
    • Linktree
« Reply #86 on: Fri, 30 September 2022, 18:04:17 »
This isn't still being run in KAM is it?
Their communication seems to have gotten worse since 2020, which is not something I thought possible.
Now they're consistently shipping out subpar quality sets with seemingly little to no quality control, as recently as Napoleonic and Explosion just this week. Many of these issues aren't even new, but extensions of issues that cropped up at the time of Milkshake and Eternal.
Honestly it's a disservice to your customers to run a set with Keyreative at this point. They have zero record of delivering sets properly, with good comms, in a timely manner. I know the group buy date is coming up fast but please please reconsider.
Offline keebnewb
« Reply #87 on: Fri, 30 September 2022, 18:16:00 »
Keyreative in the year of our lord 2022? Personally I'm done with Keyreative and I know a lot of other people are too. Might consider another uniform profile like DSA through NicePBT?
Offline hulster
« Reply #88 on: Sat, 01 October 2022, 03:27:17 »
mmmmhhh - I like this set a lot. But it will mean to spent a lot of money. I have no issues with delays, but somehow the quality should be ensured.
« Reply #89 on: Sat, 01 October 2022, 13:00:46 »
GMK a preorders are still available
Offline hulster
« Reply #90 on: Sat, 01 October 2022, 13:07:03 »
« Reply #91 on: Sun, 09 October 2022, 21:15:52 »
Added escape artisan photo
Offline hulster
« Reply #92 on: Wed, 12 October 2022, 03:14:33 »
@NintendoNoNo - can not find it on MyKeyboard.eu yet.
Any idea? Do not like to miss out. So would go for another place to buy it, if need be.
But would be my preference to save custom fees, taxes and international shipping
Offline vrapan
« Reply #93 on: Wed, 12 October 2022, 03:57:48 »
Same for protozoa in the UK is Kamistry still coming to those vendors?
Offline hulster
« Reply #94 on: Wed, 12 October 2022, 12:21:29 »
It is now there, but the Rotary Encoder Knob is missing.  :(
« Reply #95 on: Wed, 12 October 2022, 17:54:05 »
Hey! Sorry for the late reply. It’s up now on their site :)
« Reply #96 on: Wed, 12 October 2022, 17:55:37 »
Oops, ignore my last message. The rotary encoder was ran through NZ caps earlier this year. A lot of people have requested they run it again, so I have been trying to get in contact with them to request it, but I have not heard anything back. If I do hear back then I will be sure to announce it on the discord! It sold out way faster than I thought it would.
« Reply #97 on: Wed, 12 October 2022, 17:57:20 »
It is currently live for most vendors. The main contact I have for Protozoa has been out of town recently so I’ve been trying to get ahold of him to let him know the GB needs to be live. But I was able to get ahold of someone else in the company and they are now contacting him for me. Sorry about that!
Offline hulster
Re: [IC] KAMistry - Group Buy October 10th - November 10th, 2022!
« Reply #98 on: Mon, 17 October 2022, 11:55:34 »
@NintendoNoNo
I maybe overlooked - is there any fair estimate about delivery?
Offline dededecline
    • Linktree
« Reply #99 on: Mon, 17 October 2022, 12:16:34 »
@NintendoNoNo
It’s Keyreative, there’s literally no such thing.
