Author Topic: [IC] Ciel - Gasket 60% | CA Vendor and GB Date!  (Read 24909 times)
Offline MIGHTY CHICKEN
« on: Sun, 19 September 2021, 13:25:28 »
GB post is up!
Ciel
Ciel, a budget O-Ring gasket mount based on kkatano’s opensource bakeneko60
Feel free to join my discord and fill out the IC form
IC Form
Discord
The Board
Based on the Bakeneko, much of the original design has been kept. Only changes have been the addition of an internal weight and a slight change in the back profile.
Since the original proto, an engraving has been added, bumpons have also been changed to custom silicone feet.
Layouts
Ciel supports normal 60% ansi as well as tsangan bottom row, split right shift, split backspace, and stepped caps lock.
The plate has been modified so that one should be able to use screw-in stabs, in my testing they have worked although it was a little finicky to get right
Misc
There will be extras going on sale at the time of GB, some of these, but not limited to are
Extra Fr4 plates, hotswap and solder PCBs, 50a and 30a o'rings, and daughterboards.
Colors
Burgundy, Blue Grey, Lilac, Black, E-White
Refer to pictures for colors rather than renders
Specifications
- 6061 Aluminum case
- Internal Brass weight
- 6061 Aluminum plate
- PCB: Hotswap (Solder PCB avail for extras)
- Cost: 180 for all colors except E-White, E-White will be 190
- GB Date: Oct 7-Oct 21
- Unlimited GB
- Lead Time of 3~5 months
Vendors:
   -ParamountKeeb | NA
   -Keygem | EU
   -Thic Thock | Asia
        -Alpha Keys | CA
Soundtest by NearLucid!
More Images
« Last Edit: Wed, 06 October 2021, 21:19:21 by MIGHTY CHICKEN »
Offline wahfuhls
Re: [IC] Ciel - Gasket 60%
« Reply #1 on: Sun, 19 September 2021, 13:26:32 »
hi andy :P
Offline unusuaL_
« Reply #2 on: Sun, 19 September 2021, 13:26:42 »
Good one
collection: hibike 1/1, garderie tkl, casper60, hhkb pro2, matrix 2.0additional, f1-8x og
Offline Dotnick
« Reply #3 on: Sun, 19 September 2021, 13:30:54 »
I'm not sure that's lavender, looks closer to pink or rose gold.
Offline Fraaaan
« Reply #4 on: Sun, 19 September 2021, 13:35:12 »
Will solder PCBs have ISO support?
« Reply #5 on: Sun, 19 September 2021, 13:36:08 »
They will not sadly
« Reply #6 on: Sun, 19 September 2021, 13:38:02 »
In-person, it looks a little more purple, def a bit pink. I've shown the sample to some people irl and people have been saying it's purple half the time and pink the other half.
Offline Faehriss
« Reply #7 on: Sun, 19 September 2021, 13:52:59 »
yikes no ISO
no ISO, no buy :(
church of the POM keeb
Offline chat and team
« Reply #8 on: Sun, 19 September 2021, 14:34:04 »
yes
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline Myrkwood
« Reply #9 on: Sun, 19 September 2021, 18:57:40 »
nice photos
glwic
Offline NotYellow
« Reply #10 on: Sun, 19 September 2021, 23:18:16 »
I love this so much, the colors, the weight, and it being a bakeneko. Just everything is no nice. Just wish that beautiful weight was visible on the outside, but either way I'm most likely gonna buy it.
Offline AASH
« Reply #11 on: Mon, 20 September 2021, 04:05:45 »
Any WKL plans? Looks great overall, nice color palette
40s, with love
Offline The_Boom_Boy
« Reply #12 on: Mon, 20 September 2021, 04:08:38 »
Very nice design. Would love to see an Oceania vendor   :thumb: :thumb:
Offline Bub
    • big bub's beepers
« Reply #13 on: Mon, 20 September 2021, 07:35:01 »
will this be compatible with bakeneko pcb/plate then?
would love to have that option to purchase just the case and maybe daughterboard and transport bakeneko internals
let me know if you need someone to test :P
anyway im interested
« Reply #14 on: Mon, 20 September 2021, 10:09:12 »
Just due to the nature of mount, wkl not the most likely to happen
« Reply #15 on: Mon, 20 September 2021, 10:15:34 »
They are not compatible unfortunately, Cannonkeys uses an older version with unikorn mounting points that was taken down due to the mount. Ciel uses the v2 open source mounts.
Offline AstralYT
« Reply #16 on: Thu, 23 September 2021, 03:57:08 »
There are plenty cnc bakenekos in IC right now, this one looks the best imo. From the two blues shown, definitely prefer the darker, square plate one. What is the thickness of the brass internal weight? Don't even care if it's thin, I hope it does improve acoustics. Would be nice if this came with a carrying case too, even for a little higher price. Do you have CK Bakeneko? A typing test comparison would be nice to compare sound differences due to brass weight and newer V2 open-source mounting points.
Sent from my GM1917 using Tapatalk
Offline jornisen
« Reply #17 on: Thu, 23 September 2021, 14:59:46 »
what keycaps are those on the "more pictures"?
« Last Edit: Thu, 23 September 2021, 15:01:23 by jornisen »
« Reply #18 on: Thu, 23 September 2021, 17:55:20 »
MT3 susuwatari
« Reply #19 on: Thu, 23 September 2021, 17:57:21 »
It's roughly 2.5mm at its thinnest and roughly 6,7 mm at its thickest. I do not have a CK Bakeneko sadly
Re: [IC] Ciel - Gasket 60% | CA Vendor and GB Date!
« Reply #20 on: Thu, 23 September 2021, 18:10:57 »
Alpha Keys will be CA vendor, also GB Date!
« Last Edit: Fri, 24 September 2021, 18:10:08 by MIGHTY CHICKEN »
Offline KFOXE
« Reply #21 on: Thu, 23 September 2021, 21:51:17 »
Would it be possible to see the Pinkish Purpleish Lavender colour sample under a different lighting?
Offline Draxion
« Reply #22 on: Fri, 24 September 2021, 10:57:34 »
for sure getting one
« Reply #23 on: Fri, 24 September 2021, 17:39:06 »
here ya go
edit: was taken on iphone se, the new one, also is pretty cloudy rn, lightning go boom
« Last Edit: Fri, 24 September 2021, 17:44:48 by MIGHTY CHICKEN »
Offline KFOXE
« Reply #24 on: Fri, 24 September 2021, 19:26:26 »
Thanks for posting the extra photos! Now I see the purple, kinda reminds me of Nike ACG's Atomic Purple/Violet colour.
Offline Fardesu
« Reply #25 on: Sat, 25 September 2021, 01:14:25 »
Do you know how much it weighs? Fully built?
« Last Edit: Sat, 25 September 2021, 06:08:55 by Fardesu »
« Reply #26 on: Sat, 25 September 2021, 01:27:58 »
I just bought the Bakeneko60 and I just saw this, nevertheless still gonna cop the black one.
Roughly 1.5 Kg
Offline Fardesu
« Reply #27 on: Sat, 25 September 2021, 01:45:52 »
Is there any sound tests?
Really appreciate it if you can provide us with one.
« Last Edit: Sat, 25 September 2021, 05:55:00 by Fardesu »
Offline AASH
« Reply #28 on: Sun, 26 September 2021, 11:36:55 »
Unfortunate but understandable! Thanks for your answer
40s, with love
40s, with love
« Reply #29 on: Sun, 26 September 2021, 18:11:43 »
There is a sound test in my discord and Paramountkeeb's server too
Offline Fardesu
« Reply #30 on: Mon, 27 September 2021, 08:45:05 »
I saw it, thanks alot for the reply.
Looking forward for the GB!
Offline Senpai_deezy
« Reply #31 on: Mon, 27 September 2021, 19:36:22 »
looks so good, might have to join in on this  :thumb:
Offline AstralYT
« Reply #32 on: Sun, 03 October 2021, 10:38:39 »
Nearlucid soundtest very poggies
Nearlucid make rebiew pls  :D
Offline Fardesu
« Reply #33 on: Mon, 04 October 2021, 05:55:30 »
Sound test got me like :O
« Last Edit: Wed, 06 October 2021, 08:14:46 by Fardesu »
Offline SDKCAMPING
« Reply #34 on: Mon, 04 October 2021, 18:44:47 »
About time we got a CNC bakeneko!
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline growler
« Reply #35 on: Tue, 05 October 2021, 04:06:33 »
No UK vendor?
Sent from my SM-G980F using Tapatalk
Don't just stare at it ...
Offline ClerklyTexas
« Reply #36 on: Wed, 13 October 2021, 09:12:02 »
I'm having a hard time telling what color the burgundy is. Sometimes it looks cranberry to purple, others it looks, well, burgundy. Do you have any color reference (e.g, Pantone) for the color used? Or maybe a photo alongside something that you know to be neutral gray in the frame? A third way would be a photo in sunlight color balanced at 5500 degrees.
« Reply #37 on: Wed, 13 October 2021, 09:32:46 »
I’d look at near lucid’s video, it gives a pretty good color reference imo based off where I’m sitting in front of my monitor
« Reply #38 on: Wed, 13 October 2021, 13:50:28 »
That's super helpful. Thanks! I don't see the video linked anywhere on this page, so here it is:
« Last Edit: Wed, 13 October 2021, 13:52:44 by ClerklyTexas »
