Author Topic: [IC] GMK 1520 | GB Announced!  (Read 413710 times)
Offline jagger27
  • ne 1.5U supers???
Re: [IC] GMK 1520
« Reply #50 on: Thu, 23 September 2021, 13:20:01 »
I decided to keep the extra B in base in order to keep the spacebar kit cheaper and not add two extra colours to the spacebar kit.
Unfortunately I don't think I'll have alice bars in base as I already have 2.25u and 2.75u shift keys that can be used instead.
"can be used" is generous. I think it looks awful, and feels even worse. With respect to the colours, is the doubleshot the concern or the UV print? I think the second B would be fine without the UV print, personally.
Offline mcmcmc
Re: [IC] GMK 1520
« Reply #51 on: Fri, 24 September 2021, 01:36:03 »
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
Re: [IC] GMK 1520
« Reply #52 on: Fri, 24 September 2021, 08:15:18 »
Posting for the first time in two years to say I'm excited for this!
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
Offline Nonnegaard
Re: [IC] GMK 1520
« Reply #53 on: Fri, 24 September 2021, 08:25:45 »
it would be awesome to have a black f row in the base to make it cleaner without having to mix sets. just my take  :thumb:
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline AdisaFolami
Re: [IC] GMK 1520
« Reply #54 on: Fri, 24 September 2021, 08:29:27 »
I love this but it really needs ortho/40's support. Usually one of the first things to go on an ortho board is the numpad, so this set would be perfect. Pleaseeee.
Offline Ella
  • Why is it called an oven
Re: [IC] GMK 1520
« Reply #55 on: Fri, 24 September 2021, 09:20:03 »
Take a look at the inspiration for this keyset.
Making the function row black would make it less faithful to its inspiration.
Offline Yakbats
Re: [IC] GMK 1520
« Reply #56 on: Fri, 24 September 2021, 09:22:11 »
While I'm usually a big fan of 3 key 40s support in the base kit, I don't think it works for this set. The red numpad sub legends on the alphas don't make sense on a 40s board without the top number row. You could remove a few keys from the base kit, and maybe add a separate 40s kit.
Also, I think the key unit sizing text is incorrect on the bottom row to the right of the space bar, and on the pipe key.
Offline ddrfraser1
  • RIP Neil
Re: [IC] GMK 1520
« Reply #57 on: Fri, 24 September 2021, 09:47:45 »
Coming out of hiding to say YES PLEASE!
Also, what is that big boi alice?
Offline hark
Re: [IC] GMK 1520
« Reply #58 on: Fri, 24 September 2021, 10:51:48 »
Sorry this probably won't happen as I'm following the inspiration and prefer how the grey f row looks
Yeah I'm currently working on a standalone 40s kit, I'm not completely sure the best solution however.
Also thanks for noticing the incorrect sizing labels, just fixed that.
Offline OptimusPrime00
Re: [IC] GMK 1520
« Reply #59 on: Fri, 24 September 2021, 21:03:28 »
sso sick! i'm in!
Offline munda
  • Formerly kcao
Re: [IC] GMK 1520 | 7/8 Vendors Announced!
« Reply #60 on: Wed, 29 September 2021, 05:03:56 »
Looks great! Will definitely consider grabbing a set when the gb opens.
How durable are the UV printed sublegends? Will they eventually rub off over long term use?
Offline tintoret
« Reply #61 on: Thu, 30 September 2021, 21:42:16 »
Love it. Was always disappointed that I couldn't get everything together a GB for Azimuth. If this one gets going, I'm in.
Offline _rubik
« Reply #62 on: Fri, 01 October 2021, 00:46:06 »
Vendors! It’s happening!
Offline hark
Re: [IC] GMK 1520 | Vendors Announced and Updated Kitting
« Reply #63 on: Sat, 02 October 2021, 06:43:59 »
Although I don't have any UV printed keys personallly, I've seen the below image going around of GMK Griseann, which shows the ABS having tonnes of shine (and thus wear) while the UV printed legends are all fine.
It is! And I'm very excited for it.
Offline ideus
  • Björkö.
« Reply #64 on: Sat, 02 October 2021, 18:18:27 »
On the shift keys: Why the 1.25u does not have the "Shift" legend? It does not match the others without it.
Offline Neely_12
« Reply #65 on: Sat, 02 October 2021, 18:59:07 »
There is not enough space to make it look good. I would prefer just text only shift, but icon is fine here.
Offline ideus
  • Björkö.
« Reply #66 on: Sat, 02 October 2021, 23:36:16 »
There is enough space for the legend and the icon, I have many OG keys that exemplify it. Icon only shift keys can make it as well, but having one with no legends does not make sense.
Offline Neptune Keys
« Reply #67 on: Sun, 03 October 2021, 09:05:12 »
Unique. Would be cooler on some vintage switches haha
Offline andreiborisov
« Reply #68 on: Sun, 03 October 2021, 12:33:19 »
How durable GMK UV-printed legends are?
Offline hark
« Reply #69 on: Wed, 06 October 2021, 02:05:16 »
As far as I can tell they're perfectly durable, this picture is of GMK Griseann and displays lots of shine but the UV print being fine:
There are many other GMK sets that have the icon + text legend, so there definitely is enough space for it. I just decided against it as I felt it was too cramped on the 1.25u key.
Offline mopaska
« Reply #70 on: Thu, 07 October 2021, 18:50:21 »
Hyped for the set. Also, where can I find out more about that Nine_ board in the renders?
Offline hark
« Reply #71 on: Sat, 23 October 2021, 21:50:22 »
I think the board has been renamed to the DSXT and is currently undergoing a redesign.
https://discord.gg/VRnFgVkXJy
Here's the designer's discord, there's a dedicated channel for updates on it.
Offline Jacey
« Reply #72 on: Sun, 24 October 2021, 02:21:17 »
Please someone tell me where do I find the last two boards used for the renders…. so beautiful
Offline roostrc0gburn
  • its just plastic
« Reply #73 on: Sun, 24 October 2021, 13:05:29 »
thank you! now, what about this one?
Offline HappyB0T
  • I'm a Piggie
« Reply #74 on: Sun, 24 October 2021, 23:38:01 »
Dang - Ram's board is like a keyset showcase
Offline HappyB0T
  • I'm a Piggie
« Reply #75 on: Sun, 24 October 2021, 23:39:09 »
Offline jagger27
  • ne 1.5U supers???
« Reply #76 on: Mon, 25 October 2021, 10:25:54 »
This is going to look so good on my black TKC M0LLY
Offline hark
« Reply #77 on: Mon, 25 October 2021, 22:41:38 »
The WITF will have a private GB at some point, if you're interested in getting a slot I think you should reach out to Ramlord#2733 on discord.
« Reply #78 on: Tue, 26 October 2021, 16:49:50 »
Maybe it’s not completely on the set theme, but would you consider adding a red Esc and Enter? They are nearly impossible to find now and should pair nicely with the set.
Like this:
« Last Edit: Tue, 26 October 2021, 17:02:05 by andreiborisov »
Offline psxndc
« Reply #79 on: Wed, 27 October 2021, 12:22:01 »
No raise/lower? Or am I just missing them?
Ortho. Always.
Offline BlueTongue
« Reply #80 on: Tue, 02 November 2021, 07:42:54 »
Perfect
Offline coolguyzayn
« Reply #81 on: Tue, 02 November 2021, 20:58:40 »
imma just join for the extension kit which has a wob f13 :).
Offline TimKeyLess
    • Twitch
« Reply #82 on: Thu, 04 November 2021, 01:19:16 »
stoketh
Offline BlueTongue
« Reply #83 on: Wed, 10 November 2021, 15:42:47 »
I want to use this on my Mac, so please add Mac keycaps.
Offline DetectiveNio
« Reply #84 on: Wed, 10 November 2021, 15:50:41 »
Just a question on Vala, have they delivered any of the GBs they took on yet?
Sent from my LM-F100 using Tapatalk
Offline normous
« Reply #85 on: Sun, 21 November 2021, 09:04:18 »
Looks great, good colours and I like the sub legends. Would really love a 40s ortho kit.
Offline azzipa
« Reply #86 on: Sun, 21 November 2021, 12:07:22 »
love the design and i love the macos/hhkb support! i’m wondering, however, if the 1.5u System keys in extension should be blue to match blue sublegends? (would seem to make more sense for macos.) if so, then need two 1u Alt in yellow. as is, the sublegends don’t tie together for macos. glwgb  :thumb:
a personal wish would be to add R3 1.75u Function key to extension kit.
edit: feedback form completed
« Last Edit: Sun, 21 November 2021, 12:20:47 by azzipa »
« Reply #87 on: Mon, 22 November 2021, 03:22:47 »
I second this
« Reply #88 on: Mon, 22 November 2021, 16:56:49 »
Another suggestion is to turn black f-keys into m-keys and make them R1-R4. I don’t see a point in having 2 sets of f-keys, while m-keys would cover currently popular XT-layout boards like Zenith. Including Nine_ by Dudeship in your own renders.
Pretty much everyone I know strongly prefer for these keys to be of a proper row instead of all being R1. All R1 just looks like a sore thumb on these boards.
« Last Edit: Sat, 27 November 2021, 05:48:18 by andreiborisov »
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #89 on: Mon, 22 November 2021, 17:25:15 »
I usually don't go for UV or pad printed sets, this set though is so god damned cool I'd be willing to buy two sets so I have backups for when I inevitably wear the printing off! Awesome work OP, GLWGB!
Offline Joshua_VB
« Reply #90 on: Tue, 23 November 2021, 04:20:36 »
The keyboard in WITF by Ramlord render, does that actually exist and where do I buy it?
Edit: I saw the comment about reaching out to Ramlord on Discord
Sent from my CPH2025 using Tapatalk
« Last Edit: Tue, 23 November 2021, 04:22:57 by Joshua_VB »
Offline alevyish
« Reply #91 on: Tue, 23 November 2021, 19:42:43 »
First GB is closed already. But there’s a waiting list for a future (eventual) GB, fingers crossed.
  • its just plastic
« Reply #92 on: Wed, 24 November 2021, 11:29:20 »
so, any ballpark idea when this keyset will go to GB?
Offline hark
« Reply #93 on: Thu, 25 November 2021, 14:20:23 »
I just received quotes for pricing from GMK, so I expect the set to run in either Q1 or Q2 of 2022
The colours are based on the legend rather than the position on the board
The frow can be used as m keys as seen in the Nine_ renders, I don't really think the profile of the keys matters all that much for XT layouts, as they're not constantly used to type. I also feel like there are more people who want a black frow than those who want macro keys, so the black frow has been prioritised in kitting.
Offline azzipa
« Reply #94 on: Thu, 25 November 2021, 14:48:50 »
exactly my point. system keys need to be blue for macos. (we use “command” key, to be replaced by “system” key and not “alt” key.)
Offline hark
« Reply #95 on: Thu, 25 November 2021, 15:06:49 »
My point is that "Alt" is blue and "System" is yellow regardless of position
Offline azzipa
« Reply #96 on: Thu, 25 November 2021, 17:25:55 »
your ic, but you’re wrong. alt is not a thing on macs. the key combo is not alt+c for copy. it’s command+c. peace
edit: alt is relegated to teriary mod status and command (system) is promoted to primary. as a result, alt should be yellow and system should be blue according to the function assigned to these keys in macos.
« Last Edit: Thu, 25 November 2021, 17:43:50 by azzipa »
Offline hark
« Reply #97 on: Fri, 26 November 2021, 00:29:21 »
I'm sorry about the confusion but the colour of each key is determined by their legend ("System", "Alt", or "A"), and not their location when in a layout or their function on any particular OS. The mods are not blue or yellow depending on how important or often used they are, I'm just using the same colours for the same legends used on my inspiration.
Offline azzipa
« Reply #98 on: Fri, 26 November 2021, 07:35:28 »
i think i am misunderstanding your inspiration: it looks to me like the mod key color ties to the sublegend on the alphas. but as currently rendered, a macos user must press a yellow system key to activate blue sublegends. kinda misses the point of color coding. i am struggling to get my head around the idea these are just pretty colors and not a user prompt, so i’ll likely pass. glwgb, this is a poggers set  :thumb:
« Last Edit: Fri, 26 November 2021, 08:16:29 by azzipa »
  • its just plastic
« Reply #99 on: Fri, 26 November 2021, 12:33:15 »
this set is the inspiration. it's in the OP:
my 2c: @hark, don't change a thing. you have nailed it on the design, and i think this is a faithful reproduction of the vintage keyset. looking forward to purchasing every kit.
