Author Topic: Split Spacebar build help  (Read 4657 times)
Offline sbaer0991
« on: Tue, 21 September 2021, 07:56:07 »
Hello, building my first mechanical keyboard and super excited but I have a question, I'm wanting to do a 3 split spacebar but cant seem to find spacebar kits that would have keycaps for a split space bar.  My keycap set is using SA profile not sure where to purchase spacebar kits or if they will match my profile.  Any help is greatly appreciate!
Offline OhKeycaps
    • OhKeycaps
Re: Split Spacebar build help
« Reply #2 on: Tue, 21 December 2021, 00:59:30 »
[self-plug] OhKeycaps is running a GB for short spacebars if that helps and you are using SA keycaps
