Author Topic: [IC] Journey Deskmat (Gameboy/Pokemon inspired)  (Read 16899 times)
Offline switchlab.sg
« on: Thu, 23 September 2021, 09:04:50 »
"Every journey begins with a choice."
Hey all, I'm back with a new deskmat design call Journey
Schedule
Interest Check : https://forms.gle/ixWRL3fu7GntxBzt5
Group Buy : 12 November
Inspiration
Inspired by nintendo gameboy and pokemon series. This design aims to journey back to that nostalgia era of the good old days where simple pixel gaming and 8bit battle themes were a thing.
Design elements from gameboy and pokemon into mechanical keyboard switches without overdoing them. Hope you like it!
Renders
Actual product colors might differ from image/renders
Vendors
CA/US - Alphakeys
SEA - ZionStudios
SG - Mechastore
UK - TheKeyCapClub
IN - Rectanglesstore
JP - Basekeys
KR - Monstargear
AU - AllCaps
EU - mykeyboard
CN - Zfrontier
Collaboration
If you're interested in collaborating, contact me via IG or Discord
Signature
If you like and want to support this project, feel free to use this signature to spread the word!
« Last Edit: Mon, 08 November 2021, 21:20:16 by switchlab.sg »
Re: [IC] Journey Deskmat (Gameboy/Pokemon inspired)
« Reply #1 on: Thu, 23 September 2021, 10:29:16 »
UPDATE
24/9 - I have reworked the layout of the text from the previous design and also tweaked a few of the design elements,
added a power indicator which differs slightly from each theme.
25/9 - Changed the color of the middle switch to orange to better match Charmander's color.
25/9 - Charmander and Squirtle switches are now in correct sequence as with the original pokemon.
26/9 - Reduced size of the quotation marks and slightly toned down the quotation so the focus is more towards the switches.
26/9 - Updated renders to show a more accurate deskmat (texture and stitching).
27/9 - Light Theme - Slighty adjusted the outline tones for the switches to make it pop more.
4/10 - Update to vendor lists
5/10 - Changed the borders of the switches to match the respective pokemon colors. Many have commented that the light theme does not pop as much as the dark theme, hopefully this will resolve that!
31/10 - Group buy date 12 November.
Group Buy will include Light and Dark theme and option of having the quote or no quote versions.
« Last Edit: Mon, 01 November 2021, 05:11:58 by switchlab.sg »
Offline Zyrophr
  • https://zyrophr.com
    • zyrophr.com
« Reply #2 on: Thu, 23 September 2021, 10:51:33 »
I like.
French keyboard streamer
Offline trung11.kb
  • Formerly tomkatsuuu
« Reply #3 on: Thu, 23 September 2021, 11:01:58 »
I think the text distracts the design too much. It's also a bit hard to read. Would buy if the text was removed.
Offline MisterPooter
« Reply #4 on: Thu, 23 September 2021, 11:18:21 »
Not a fan of the pixelated font or the fact that it's just laid over the switches like that as it distracts from the art undernearth.
With that said, however, if you MUST keep it as is, I'd suggest changing the text to outline only so you can still see through to the art underneath it.
Offline Cylent
  • Formerly cylentshadows
« Reply #5 on: Thu, 23 September 2021, 11:23:12 »
THIS. I do not like the text over the switches, but if it MUST be kept, please move it down/out of the way, or at least outline the text so I can read it.
« Reply #6 on: Thu, 23 September 2021, 11:36:11 »
Thanks for the feedback, I'll try another approach and update the thread!
« Reply #7 on: Thu, 23 September 2021, 11:54:09 »
Thanks for the valuable feedback! I’ve been cracking my brains to play around with the words, the quote itself is important in the overall design and pokemon nostalgia so it won’t be removed completely but I will try another approach with the text.
Offline JohnYYZ
  • KanataKeys.co
« Reply #8 on: Thu, 23 September 2021, 12:21:33 »
I really like it!
Offline Koobaczech
  • Don't forget to smile :)
    • Pearlboards
« Reply #9 on: Thu, 23 September 2021, 13:08:18 »
Very nice my friend, lots of nostalgia from this one! Pat on the back :) For vendors, If you ever want to give them a look, I know Mechs and Co are a great team here in the USA, and rheset.mx is another stellar one for Latin America
Offline Serval
« Reply #10 on: Thu, 23 September 2021, 15:09:28 »
Looks great. +1 on placing the text behind the design. GLWIC!
Offline adriantan
« Reply #11 on: Thu, 23 September 2021, 20:11:26 »
as a pokemon fan, i like this very much.
« Reply #12 on: Fri, 24 September 2021, 03:25:00 »
Hey man, thanks alot! I do have a US vendor already but Latin America would be nice to have! Link me up. You can msg me over at discord.
Offline Friendship
« Reply #13 on: Fri, 24 September 2021, 07:57:59 »
Both the red and blue switches have the same data callouts (number weight height)
Collection: LZ GHv2, Esheu Fallacy, Moesode Bliss, Daji Ocho Cuatro, Ace Saturn60, Bolsa Midway60, MLI NUM1, MLI VISION, PW ROTR
« Reply #14 on: Fri, 24 September 2021, 09:31:21 »
Thanks for pointing that out!  :thumb: Edited and updated the thread.
Offline EightDiagram
« Reply #15 on: Fri, 24 September 2021, 21:25:35 »
The revision looks nice, though I am a bigger fan of the original pink stem, as well as the pixel font.  The affinity design seems to pop more than the renders. Will the final resemble more of the high contrast (affinity) or the renders?
Offline Tulesto
« Reply #16 on: Fri, 24 September 2021, 22:12:17 »
I really like this revised version!
Sangeo/Suit/Spring/Angle/CW88/Kohaku/Unikorn/Navi/Corsa
« Reply #17 on: Fri, 24 September 2021, 22:29:31 »
Thanks! The design file on Affinity app will definitely pop more as it is more color accurate than the renders as there are no light reflection/refractions. It is still a rough estimate but the colors will be as as close to the design file.
Offline Xemmas
« Reply #18 on: Sat, 25 September 2021, 08:17:52 »
I really like it! It hits a nostalgia feels just right!
Offline Cylent
« Reply #19 on: Sat, 25 September 2021, 09:28:55 »
Revised text is much better. I like it. GLWIC! :thumb:
Offline heavymark96
« Reply #20 on: Mon, 27 September 2021, 10:07:11 »
Never really got into GB for deskmats cause I'm looking for something waterproof/spill resistant so that it is easy to clean with just a wipe of a cloth. Would be great if this could be first to start that, wouldnt be mind if the cost gets increased by a bit. This has an amazing design as a i love pokemon!
Offline alevyish
« Reply #21 on: Mon, 27 September 2021, 11:39:29 »
I would support this too, I really like the revisions and current design.
« Reply #22 on: Tue, 28 September 2021, 02:44:19 »
Thank you and appreciate it!
« Reply #23 on: Fri, 12 November 2021, 21:49:18 »
GB has officially started. Will be closing this thread!
